Question about GE Profile ASM10AA Air Conditioner
Compressor runs for short time then kicks off and blows warm air
  • GE Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Sep 27, 2010
4 Suggested Answers
  • 4 Answers
SOURCE: Blowing hot air, compressor not kicking on, just fan ? ?
are you speaking of the outside fan or inside? compressor should be a little warm but not boiling hot. the unit could be low on freon. if low it will run a while but the compressor will overheat and shut off leaving the fan running by itself ouside. if nothing outside is running check power. if you have power check the contacted outside to make sure it's pulled in. contacters are bad about going out on goodman untis. Also ants can get under contacts.
Posted on Jun 18, 2009
  • 587 Answers
SOURCE: Compressor appears to kick in, runs for short time
It sounds like your unit may have a bad run capacitor or start capacitor and relay. Low voltage will also cause this problem. First you need to make sure that you have the full rated voltages at the unit, if you do, then, have the run and start capacitors checked out and the start relay.
Posted on Jun 01, 2010
InMrFixIt
  • 121 Answers
SOURCE: i have an rv that has a roof mount ac unit that
If there is no air moving when you turn on just the fan the fan control sw, connections to the fan, or fan motor is bad
Posted on Sep 29, 2011
Why does my ac not blow cold air?
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds After you turn it back on the system should reset. If you need any other assistance check us out online at Boca AC Service we are always happy to lend a helping hand
May 26, 2016 | Heating & Cooling
2003 Pontiac GT1 3.4
Not exactly.
The compressor can run until it begins to freeze up depending on the system, or until pressure readings get too high or too low.
Most cars today are designed to run the compressor as long as the switch is engaged and just add hot air from the heater to adjust cabin temp. There is a sensor in the evap to prevent the system from freezing up.
As long as it is warm outside and the system is not freezing up then yes the compressor will run constantly.
Jul 04, 2012 | Cars & Trucks
Runs loud when the compressor kicks in? Why?
Check vibration eliminators on the feet of the compressors, over time of running in tough conditions they wear out and cause rattling. If this does not fix the problem see below
-check amp draw, if amp draw is high windings are wearing out and compressor is running harder, may need replaced
- check to make sure your refrigerant charge is correct you could be slugging the compressor
-find other ways to isolate compressor operations
May 29, 2017 | Maytag M6P09S2ACOM Air Conditioner
May 31, 2010 | Dometic Rooftop RV Air Conditioner
Kitchenaid Side by Side Refrigerator minus the cold air?
your compressor has issues. some times the start relay goes bad or the compressor windings are shot. thats why it clicks on then off .a service tech can install a "3-n-1 hard start on it. sometimes that works. good luck
Dec 10, 2009 | Washing Machines
A/c trouble 2001 silverado
you havent check the pressior of the compressor make sure is full loaded
Aug 11, 2009 | 2001 Chevrolet Silverado 2500HD
Will not cool properly.
You have either a faulty thermostat, dirty condenser and evaporator or a faulty run capacitor. Need to service soon before the compressor is damaged. Sea Breeze
Jul 31, 2008 | Kenmore 75101 Wall/Window Air Conditioner
GE Profile ASM10AA Air Conditioner Logo
127 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
