Question about Microsoft Windows XP Home Edition
My Windows XP Home Edition(licensed version) does not boot (hangs) does not go beyond desktop, I have to reset which leads to checking the drives. A windows 7 has been copied to a drive which is working fine but MS Office programmes like MS word, MS Excel are not there. How to remove/uninstal this windows 7 and reactivate XP
  • 480 Answers
First of all you need to have the Windows XP cd to install it on your computer. And also if you have the copy of the of the product key to reacvtivate it again. that is all you need to reinstall XP again on your computer. You will also need the drivers cd for the computer to function again normally.
thank you for using Fixya. you recommendation is highly appreciated.
Posted on Sep 27, 2010
Blue creen with blinking cursor
you can do a clean install from your usb. i use this setup for all my flash drive boots.
WinSetupFromUSB - Install Windows XP from USB Flash Drive
This guide will show you, how to use WinSetupFromUSB to create a bootable USB Flash Drive including all Windows source files, plus the following installation of Windows XP. Compare to the different USB_Multiboot versions, WinSetupFromUSB comes with a Graphical User Interface (GUI) and is in my opinion easier to use.
Here you can get the latest version of the program and you will also find many detailed informations about WinSetupFromUSB.
I've tested this guide with a 32-bit version of Windows XP and a 64-bit version of Windows Vista and it worked flawlessly.
Prerequisites:
All you need is:
a USB Flash Drive with at least 1GB of storage
the original Windows XP Setup CD
WinSetupFromUSB
If you use nLite to slim down your version of Windows XP, please keep the following in mind:
DO NOT remove "Manual Install and Upgrade"
under Operating System Options!
I also recommend to integrate Service Pack 3 into your Windows XP source files.
1. Preparations
Download and install WinSetupFromUSB. Default installation path is C:\WinSetupFromUSB.
Create a new folder with the name WINXPCD in the root directory of drive C:\ and copy all files from your Windows XP Setup CD into this folder. Depending on your version of Windows XP, the content of C:\WINXPCD should look approximately like this:
Content of WINXPCD
The following files will show you, which Service Pack is already integrated into your CD:
WIN51IC.SP1, Sevice Pack 1
WIN51IC.SP2, Sevice Pack 2
WIN51IC.SP3, Sevice Pack 3
2. Start WinSetupFromUSB
Connect the USB Flash Drive to your PC and start WinSetupFromUSB. It should show up under USB Disk Selection :
WinSetupFromUSB - main window
3. Select your Source Path
Click on Browse under Windows 2000/XP/2003 Source and navigate to the folder with your Windows XP Source Files. It should be C:\WINXPCD:
Browse to Folder
Click OK and C:\WINXPCD should show up under Windows 2000/XP/2003 Source :
WinSetupFromUSB - source path
4. Format USB Flash Drive
PeToUSB or HP Format Tool are used to format the USB Flash Drive. There is no need to download these programs seperately as they are already included in WinSetupFromUSB.
USB Flash Drives up to 2GB should be formatted with PeToUSB in FAT16, USB Flash Drives with 4GB or more with HP Format Tool in FAT32.
I will use PeToUSB to format my Kingston Data Traveler with 2GB.
In the main window of WinSetupFromUSB click PeToUSB under Format target using to start the program. The USB Flash Drive should show up under Destination Drive. Check USB Removable, Enable Disk Format and Quick Format. Uncheck Enable File Copy under File Copy Options :
PeToUSB
Click Start and answer the following two questions "Continue?" with Yes.
All existing volumes and data will be lost!
If everything goes well, the message "Operation Completed Successfully!" should appear. Click OK and close PeToUSB.
The process with HP Format Tool is similar.
5. Copy Windows XP Source Files
To start the process of copying the Windows XP source files to the USB Flash Drive, click GO in the main window of WinSetupFromUSB. Depending on the write speed of your USB Flash drive it may take a while to copy all files.
WinSetupFromUSB - file copy
At the end the following notice about the Windows installation process should be displayed:
WinSetupFromUSB - notice
Click OK and close WinSetupFromUSB with EXIT.
6. Windows Installation - Part 1
Connect the USB Flash Drive to your PC and turn on the computer. Press ESC at the boot screen and you will be able to select the USB Flash Drive as your boot device from the boot menu.
The ESC key is used by ASUS for the Eee PC series.
Other manufacturers may use other keys, e.g. F8 or F12.
After booting from USB Flash Drive, the following menu should be displayed:
Windows XP/2000/2003 Setup - First and Second parts
Press Enter or wait 10 seconds to get to the next menu:
First part of Windows XP Home Edition setup
Second part of XP Home Edition setup+Start Windows for first time
First part of Windows XP Home Edition setup is already selected. Press Enter or wait 10 seconds to start the Text mode part of setup. During this part you can create, delete and format partitions and finally the setup files are copied to your hard disk. At the end the system will restart automatically.
7. Windows Installation - Part 2
After restart, boot the PC again from your USB Flash Drive. The same menu should be displayed:
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to start the GUI mode part of setup. During this part you will be asked for your product key, timezone, usernames and other necessary informations. At the end the system will restart automatically.
8. Windows Installation - Part 3
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to Start Windows for the first time. The Windows installation process will be finished and finally the Windows Desktop will appear.
DO NOT disconnect the USB Flash Drive too early!
At next startup you can boot into Windows from your hard disk.
Notes:
After successsful installation, the following boot menu will always be displayed during startup:
Please select the operating system to start:
USB Repair NOT to Start Microsoft Windows XP Home Edition
If you don't plan to use the repair option and want to boot directly into windows, you have to do the following:
Open the file boot.ini in the root directory of drive C:\ with Notepad:
[Boot Loader]timeout=30
Default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[Operating Systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(1)partition(1)WINDOWS="USB Repair NOT to Start Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Delete the following line:
DO NOT delete the wrong line!
Your computer may not boot the next time!
Save changes to the file.
At next startup the boot menu will not be displayed.
If you want to keep the repair option, you can reduce the time to display the operating system options from 30 to 5 seconds:
[Boot Loader]
timeout=5
At next startup the boot menu will be displayed only 5 seconds.
gd luck
Mar 09, 2014 | Computers & Internet
I need to do a windows repair but I cannot find my cd. Can I download one and save it to a disk and install it on a different computer
Ask your friends to borrow either a "retail" Windows XP Home Edition CD-ROM (bought when XP was available in retail stores) or an "OEM" (Original Equipment Manufacturer) version. The OEM version was used by Microsoft-licensed "system-builders" (small computer-stores that assemble computers from the individual components, and then install this "generic" version of Windows).
If you have the "genuine Windows" decal on the side of your desktop, use that 25-character product-key and the "borrowed" CD-ROM to reinstall Windows.
Nov 18, 2010 | Dell Microsoft Windows XP Home Edition
I want to change my windows xp to Home edition
You can also do a clean installation by following the procedure as listed below:To perform a clean installation of Windows XP, follow these steps:Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.At the Welcome to Setup screen, press ENTER to start Windows XP Setup.Read the Microsoft Software License Terms, and then press F8.Follow the instructions on the screen to select and format a partition where you want to install Windows XP.Follow the instructions on the screen to complete the Windows XP Setup.
Oct 27, 2010 | Microsoft Windows XP Professional
I want to know that "is how many Windows XP version is publish So far"? any one answer detail i know only 2 one is HOME edition and 2nd is Professional " IS it ???? what about Media Center Edition...
to your amasement one answer is 8 versions
Windows XP Starter Edition
This edition is aimed for first-time desktop PC users in developing countries. This edition can only run three applications at once.
A version of Windows XP for home users. This edition replaced Windows 9x/ME
Windows XP Home Edition N
This is a special edition of Windows XP Home Edition for the european market
without media player
A version of Windows XP for both businesses and home users. This edition replaced Windows 2000 Professional
Windows XP Professional N
This is a special edition of Windows XP Professional for the european market without media player
Windows XP Media Center Edition
A Windows XP version for Media Center PCs with an easy to use interface and remote control support
Windows XP Tablet PC Edition
This is a Windows XP version for Tablet PCs with pen and speech capabilities
Windows XP Professional x86 Edition
This edition is for AMD64/EMT64 64-bit processors
guess you didn't knew that.
nice question and thanks for using fixya.
Please vote if satisfied.
Jun 03, 2010 | Microsoft Windows XP Professional for PC
Black Screen on Dell Dimension 3100 on boot up. Running Windows XP Home Edition. This happen before you get to the Windows login screen.
If you have a black screen it means the system cannot boot into your master boot record, you should reinstall the system using a bootable Windows XP CD, and perform a repair,( not the Repair Console).
When youre in the Windows XP Wizard screen, press enter , accept the license agreement, and then it will check for existing windows xp partitions, press R to repair the existing Windows XP installation, and wait til it gets your system restored.
Jan 10, 2010 | Computers & Internet
Would like to know if there is a way to install GIga Pocket without wiping wIndows Professional XP3 clean just to install Windows Xp Home Media Edition
XP Home Media Edition is technically a customized version of XP Pro. If you want to install the two versions side by side, you'll need to Dual Boot the computer, which requires changing the partition. There are various utilities out there that can do this, but it may end up causing problems for the older version of Windows. Do some research on setting up dual booting and decide if you're comfortable going that route. If not, consider having a technical friend or professional doing it for you.
Oct 24, 2009 | Sony VAIO PCV-RS530G (PCVRS530GFS) PC...
I have an hp pavilion a1410y. the computers harddrive doesnot do anything but make noise so i installed two other harddrives out of other computers one of the harddrives has xp professional and the other...
The reason it wont boot from your other hard drive is because windows is expecting some different hardware on *********** bored, gets stumped and falls down.
On your computer there should be a license sticker. This will be rectangular with a green pattern on it. It will have your product key for what ever version of XP you are licensed for. You can place the drive which matches your version in your computer. Then, in order to get that install running on the new board, you will need an OEM copy of the appropriate windows disk. you may have received one with your HP, or talk to your geek friends who may have one.
to repair the load, boot off the cd. You will come to a window where you can press R (dont press R) for recovery console, F3 to quit, and Enter to continue. Then you will see a license. Press F8 to accept it. Then you will see a thingy that says "serching for previous versions of microsoft windows". Then it will show you the partions on the drive. select the OS one, usually marked "C". And there should be an option to press R for repair. Now you can press R. It will ask you for a product key. That is the one on the license on the side of the computer, also known as a COA (Certificate of Authenticicty). It will ask you for some other things too, like user names etc. Then you get to go hunt for drivers on the HP website. Lots of fun.
Sep 01, 2009 | HP Computers & Internet
Not loosing data
No problem at all. Go ahead.
Do rate this fixya!
Jun 01, 2009 | Microsoft Windows XP Professional With...
Password restore for window home xp
You do need a little tool called NT Passwords which has to be burned to a CD after unzipping it. You can use tools like Nero Burning Rom to burn the ISO file. The tool works with Windows 2000 and XP only, no Vista support yet. Boot your system from CD and you should see a prompt that asks for user input. The first step would be to select the partition of your Windows installation. After that the program asks for the path to the Windows registry, this depends on your version. For xp it would be “windows/system32/config”, for Windows 2000 “winnt/system32/config”.
Just press enter in the next dialog which will lead to the password reset options. Press enter again because choice [1] “Edit User Data and Passwords” is what we want.
Enter the username that you want to change the password from, remember it is case sensitive. You will be prompted to enter a new password. If you want you can change the passwords for other accounts as well or leave the program by hitting “!”, then “q” to quit and Y to accept the changes.
May 20, 2009 | Microsoft Windows XP Home Edition
Microsoft Windows XP Home Edition Logo
52 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
