Yes the PC runs on AC pack for eternity,. Is my battery bad, really?
My dell laptop doenot want to turn on even though it gives the green light
Dell Latitude D620 battery Specs:
Fit Model:
dell latitude d620, dell latitude d630, dell precision m2300,
Compatible Model:
dell 310-9080, dell 312-0383, dell 312-0386, dell 312-0653, dell 451-10297, dell 451-10298, dell 451-10299, dell gd775, dell gd776, dell gd787, dell jd605, dell jd606, dell jd610, dell jd616, dell jd634, dell jd775, dell kd489, dell kd491, dell kd492, dell kd494, dell kd495, dell nt379, dell pc764, dell pc765, dell pd685, dell rd300, dell rd301, dell tc030, dell td116, dell td117, dell td175, dell tg226, dell ud088,
url:
(US)
http://www.sales-battery.com/laptop-batteries/dell-latitude-d620.htm
(UK)
http://www.global-battery.co.uk/laptop-batteries/dell-latitude-d620.htm
The batteries eventually wear out and quit taking a charge. You can run the system without a battery with no ill effects. replacements are about $100 for a new battery
$15 now.
Mine is dell latitude d620 laptop.battery is new.problem is it was running both on ac and battery.suddenly battrey is not taking the charge but my laptop runs on ac power. can i remove the battery and run it on ac for some time and then will put the battery?is it risky ?
This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you:
6832151100 02 PTB 1511 Dell 5021365 6430 Power Supply Backlight Inverter
