I bought wilo water pump less than a year, when i switch it on it stop working make no sound at all. I wonder what could happen to it. please if you have any idial please let me know
  • 43,501 Answers
In most cases problems with the circulator pump boil down to two problems.
The most common is air in the lines causing an air lock.
The next problem is that the pump gets stuck and is not running even though itmay be hot and seem to be running. In this cause the pump can sometimes betaken apart, cleaned and it will work, but usually it needs to be replaced.
Here is a tip that I wrote that will explain circulator pump problems in moredetail.
Heating Circulating Water Pump Problems
heatman101
Posted on Sep 27, 2010
My Aqualisa Quartz shower stopped working suddenly. Pump is on, but no water
can offer no information on this but to call a local plumber .sounds like you possibly need a new pump
Aug 01, 2016 | Home
Does anybody have a diagram for the flow of a back boiler pump
Did you install the pump so it flows in the correct direction? Check the arrows on the unit.
Dec 06, 2014 | Water Water Heaters
Wire wilo pump
Check your thermostat wiring, it sounds like you have it set up for cooling.
Mar 07, 2014 | Water Heaters
Brew switch not responding
your not far,
test your switch with a test light
or you could always jumps the wire direct to your pump
if nothing works check for parts on ebay.
Jan 06, 2014 | Gaggia 102534 Espresso-Color...
I bought a pump for my fountain 4 months ago, it stopped working
This sounds like you should check your suction pipeing again and with fish be sure to get a screen for it. Then also check the impeller on the pump to be sure nothing inside it. You will need to open the pump to do this. If it has been working their is probally nothing wrong with the pump itself.
Dec 14, 2009 | Aqua Garden
Triton Shower is not working at all after a years great service.
FIRST TURN OFF POWER SUPPLY THEN OPEN UP THE CASE AND INSPECT THE WATER PUMP FOR ANY BUILD UP OF SCALE IF SO CLEAN WITH A GOOD SCALE REMOVER, ALSO CHECK THE PUMP IS NOT FAULTY AS THIS COULD BE THE CAUSE OF YOUR PROBLEM , ALSO CHECK FOR ANY LOOSE WIRE CONECTIONS .
Nov 11, 2009 | Home
Wilo 3speed recirt pump for my wood stove
I wasn't aware that you would put a citculating pump on a tankless water heater, but as long as the arrow goes in the direction of the water flow that is how it needs to be,, putting a circulator on a tankless kind of goes against what it is for, the tankless will never shut off and once it is on how will it ever satisfy itself to shut down?
May 26, 2009 | Grundfos RCP-96 Recirculation Pump for...
3 speed Recirculation pump lost middle speed
It sounds like you might have had a power surge and burnt the windings on the medium speed. If it is bothersome, you will need to replace either the motor or the whole pump. (not sure if replacing just the motor is an option.)
Mar 05, 2009 | Grundfos RCP-96 Recirculation Pump for...
Heating & Cooling Logo
428 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
