Question about SySTOR Systems (400S52) Burner
HI,I have a Grant 50/90 Euroflame.I ran out of oil,and it stopped.I refilled,and blead the boiler,but it still will will not fire up.It trys to start,but after 10 sec it shuts down.
2 Suggested Answers
SOURCE: oil boiler won't run
What make and model burner do you have?
Posted on Apr 17, 2008
Ran out of oil, when refilled managed to get heating working but oven not
How to bleed and restart your oil heating. - Instructables
www.instructables.com/.../How-to-bleed-and-restart-your-oil...
InstructablesGo to the oil tank and make sure there's oil in it, or you'll be wasting your time. ... you to get lucky but it has happened to me and it seems to help get the fuel moving a ... I am thinking the boiler is not working so do not want to spend money buying lots of ... Bleeding brilliant - now the wife doesn't have to know we ran out of oil!Missing: oven
how to mend it .com - Clearing airlock from riello oil burner?
www.howtomendit.com > Heating, Oil Filled Radiators
The temp knob on my bosch oven has stopped working. ? Search: Go ... I've now replensihed the oil but the system keeps cutting out after a few moments trying to ignite the oil. ... With guests arriving to rent my house yesterday, I ran out if fuel,refilled and ... Have now managed to restore heating and hot water to my house.
My Craftsman lawn mower wont start after it ran out of gas ...
www.shopyourway.com > Manage My Life > Questions
Dec 21, 2015 | Ovens
My boiler is losing pressure every day. Any ideas please.
Hi,If you have blead all the air out of the rads and there is no leaks from the rads and the boiler,then perhaps an exspantion valve or maybe the the pipe work,if under the floor a presure test is neaded.
hope was some help,hope you get it fixed.
Mar 28, 2015 | Cars & Trucks
Danesmoor slpj20-25
Hi try this link and go to page 16 fault finding it should give you a clue, I think it may just need bleeding. http://www.bhspares.co.uk/wp-content/themes/RevampV3/manuals/Worcester%20Bosch/DanesmoorSLPJ15-19.pdf Cheers Andy
Dec 30, 2013 | Heating & Cooling
Drain and refill of New Yorker forced hot water furnace
Draining is the easy part. Isolate the water feeder (shut off). Open hose bib @ boiler, & open the expansion tank valve to pull air in to allow more water out.
Refilling- let the water feeder fill -should be around 12 Psi, then go around the building to all the baseboards or radiators & open the bleeder key valves to let the air out until you get a steady stream of water. Most of the air should work its way to the expansion tank. Turn the boiler on & test your new pump.
Nov 12, 2013 | Heating & Cooling
Wallstar boiler
it pops a lot and is noise when I turned it on, it's a NEW ONE
Oct 21, 2013 | Heating & Cooling
Ran out of oil, now refilled, but boiler won't ignite. Tried all as owners manual instructs, but still keeps locking out - help please
After running out of fuel,you need to bleed the oil pump on your burner.There should be a 3/8 bleed port on the bottom of your burner pump. The bleeder valve looks like a nipple. A 3/8 opened end will fit over it.Put a can or cup under it,open it a bit and reset your control.when pure oil comes out close it and burner will fire.If your not good with it you should get a tech or handy man to do it.
Nov 27, 2010 | Heating & Cooling
My Ariston STT150 is dribbling water out of the overflow pipe
Are you talking about the T&P valve? This is the relief valve and yes, it will need to be replaced. You will have to shut down the unit drain it partially or at least below the level of the valve. Remove and replace it and that should stop it. The reason why it leaks when its heating is because the heat makes the pressure rise in the unit and pushes the water out. You had better replace this pretty soon or it could open up like a gusher at some point.
Mar 22, 2009 | Water Heaters
I need to restart my boiler after running out of oil
Try a website called www.repairclinic.com and see if that will answer your problem.
Jan 19, 2009 | Water Heaters
Starting a pilot light on a hot water heater
Hi blaineandhea,
I'm Harvey the Master Plumber.
Your statement is: You ran out of oil,so got more oil in tank.blead the lines.but now you cant get pilot to start
Every oil burner I ever worked on had a type of spark ignition. No standing pilot. If this is the case for you then the only reason it won't turn on is that the lines weren't properly bled. It only takes a little bubble to ruin the day. Don't be afraid to blead lots of oil, you should be catching it anyway to put back in the tank.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 13, 2008 | Water Heaters
My oil boiler is a Danesmoor SLPJ 20-25 with an Electro Oil Inter 2011 burner. The oil tank ran out and after refilling the burner ran ok for approximately 6 minutes, the control box chattered and the...
you could have a problem with a temperature sensor.
it would not be the flame sensor since it could not wait 6 mins to sense that there is flame in the unit.
could be a temperature sensor problem where it is sensing a temperature which could be correct but it is sending a wrong signal to the controller to turn off the flame and start another cycle.
tnx 4 using fixya,
drcool
Oct 04, 2008 | Heating & Cooling
Computers & Internet Logo
334 people viewed this question
Top SySTOR Systems Computers & Internet Experts
David Payne
David Payne
Are you a SySTOR Systems Computer and Internet Expert? Answer questions, earn points and help others
