Question about Kenmore Washing Machines
I have a Kenmore Elite 3-Speed Automatic Washer with Triple Smart Dispenser (Model #110.22972101). The Problem: Won't finish filling with water during wash cycle; just stops and hums. I can get it to go (clever girl that I am) by using the Rinse cycle to fill it, then immediately switch over to the Wash cycle and it will wash and finish. What's wrong with my 8-year-old machine?
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
jsrock516
  • 5911 Answers
SOURCE: kennmore elite model #110 just buzzes
I would recommend checking your lid switch. If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain, this is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If not activated by a lid strike, other models have the lid switch located under the washer casing next to one of the lid hinges. It is activated by a rod contacting an actuator. The mounting scews for this type are located under the operator console.
If you determine the switch to be defective, the following link explains how to access the washer interior and replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com.
If you need further assistance, please post back with a complete model number so that I may be able to assist you better. I hope this helps you.
Posted on Aug 17, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore 70 series washer won't fill during rinse cycle
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
blueextc3221
  • 15935 Answers
SOURCE: When my machine goes through the rinse cycle it will only fill with hot water. It fills with warm water during the wash cycle.
Your hoses are reversed.
blueextc3221
  • 15935 Answers
SOURCE: automatic bleach dispenser fills up with water during fill cycle
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Posted on Sep 15, 2010
Water is still in my liquid bleach dispenser after load is finished. is this normal?
If it is just water then it could be OK. Most companies use a water stream to flush the bleach and also the fabric softener out of the dispenser systems and into the washer tubs. Some water left over is probably normal as long as the bleach or fabric softener has dispensed.
Sep 19, 2014 | Kenmore Oasis153; Agitator 4.5 cu. ft....
Sears washer elite he3 fills back up with water when off
You have to shut your wall inlet pipe after your wash is over. If the leak persists you only have to change the inlet valve, which you can do yourself, see internet for spares quoting your washer number, model. It is good to keep the valve closed when the machine has finished it's wash.
For unlocking hold down "end of cycle" button at right side of panel for 3 - 5 seconds. The door remains locked when there is water in the machine, it does not want to wet your floor. Today's machines are smart. Helped?
Mar 05, 2013 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite 5t shows an F30 code, water fill solenoid is making a noise like its not opening
This is a dispenser motor issue. If you pull the unit out and remove the 3 screws coming into the back of the top panel, you can remove the top panel to access the top of the dispenser. There is a motor that turns a plastic lever on the dispenser. you might be able to manually help the arm move to get past the error code, but ultimately you will need to replace the dispenser motor. Here is the part to order.
Dec 03, 2012 | Kenmore Elite HE5t Washer
My kenmore elite HE, smart pack is not dispensing the fabric softner? Can you help?
The softener water flow is clogged. You know, open the dispenser while it's filling in the final rinse and look over the softener dispenser. Is there water flowing?
Jun 09, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Calypso Washer fills then doesn't advance..
You can get a replacement pump at pcappliancerepair.com - part # 285990 - and a lifetime replacement warranty on the pump - for (at this time, July 2009) about $124 total.
However, before you do anything you can run the washer diagnostics by pressing the following key sequence to put the washer into the Automatic Service Diagnostic mode (make sure the washer is EMPTY of clothing when you do this):
Prewash Options --> Wash time --> Prewash Options --> Wash Time (also known as a "Key Dance"). You have to press the 4 keys within 5 seconds for the washer to enter the diagnostic mode.
The washer will start counting down from 99 on the LED display and will run through the following steps:
Display 99-81, Nutate & Fill (washer plate rocking motion is called Nutate), Cold Water, Drive Motor Speed 300
Display 80-61, Nutate & Recirculate, Cold Water, Fabric Softener Dispenser, Pump in Recirculate mode (wash), Drive Motor Speed 275
Display 60-41, Nutate, Fill & Drain, Hot and Cold water, Bleach Dispenser, Pump in Drain Mode - LISTEN FOR IT TO RUN, Drive Motor Speed 250
Display 40-21, Nutate, Fill & Drain, Hot Water, Detergent Dispenser, Pump in Drain Mode, Drive Motor Speed 225
Display 20-01, Spin & Drain, no water fill, no dispenser solenoids, Pump in Drain Mode, Drive Motor Spin Speed 500
Return to Standby at the end of the countdown.
You can press Cancel at any time.
Also, if you can get the washer drained, when you tip it on its side and open the bottom cover (unplug the AC power first and secure the water lines & drain), if you shine a bright flashlight up inside the outer case of the washer, look for a plastic sleeve with some paperwork in it.
If it is there, you will find the washer's Service Diagnostic Paperwork, a large fold-out sheet that shows all the keystrokes, like those documented above, for putting the washer through a bunch of diagnostics.
Jul 24, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 Washer fabric dispenser not working
This is usually just as simple as adjusting the syphone up and down. releveling your machine or cleaning the dispenser itself. when the water enters the dispenser gravity syphones the water out . nothing really machanical about it. unless the water is not filling up the cup enough to go above the max line. you can test it by putting water in the dispenser above the max line and adjusting the syphone cap up and down.this should grab a suction.
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Oasis washer - water accumulates in bleach dispenser
somethinf clooging dispenser, remove water from dispenser and get small straw and un clogg,,,,,,,, thats it
Nov 19, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite he5 - error code F30
F 30 code can be reset by un plugging power cord for 5 minutes also pull out the detergent dispenser and reach all the way in to the back there is a small plastic flapper valve move it from side to side with your finger this will rest code f30 and save a tech visit..
Nov 10, 2008 | Kenmore Elite 45986 Front Load Washer
The washer stops after it fills with water?
You need a new SWITCH, LID 8318084 the bad lid switch is keeping your washer from sorking.. let me know if you want to repair it yourself.. let me know?
Aug 25, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
182 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
