Question about Canon PowerShot SD1100 IS Digital Camera
I have a Canon SD1100 IS that suddenly shows a small out of focus dot or blur in the viewscreen. It appears just above the upper left intersection thinking of the rule of thirds. Are there any solutions? Thanks Don
  • Canon Master
  • 19,396 Answers
Hi Don.
The defect is only incidentally located in rule of thirds intersection. The problem is either concerning the lens or the CCD sensor.
If problem is concerning lens you will get a fixed shadow or a proper out-of-focus blur spot.
If problem is CCD the blur will be a deformation of the image in that area rather than a proper optical blur.
In either case the problem may be difficult to fix, as repair involves taking apart and cleaning lens, and eventually replacing the optical sensor if needed.
To get a quote on repair call Canon, or get a quote from a third party service here:Repair.
Regards.
Ginko.
Posted on Sep 27, 2010
My cannon power shotA4000IS suddenly stop showing/focused pictures the scree show a blurred image of photo taken?
If you are convinced you did not switch the camera to manual settings, and the blur stays, please contact the nearest Canon certified service centre close to you. But before check the settings on the camera and start putting it on automatic.
Sep 11, 2014 | Cameras
Hi there, I don't know if it's a problem or not (I can live with it :) ). I just got a Canon EF 50mm f1.8 II lens, and I really love it. But: When I'm using the eye-level viewfinder (and not...
You may just have the left auto focus points selected. You don't say which camera model you have. If on the back of your camera you can see a button with an icon showing 5 small white blocks in a plus sign in a white box press this to select the auto focus points. It should show the available auto focus points and then use the left/right (wheel) button to change the selection
Jul 01, 2011 | Canon EF 50mm f/1.8 II Lens
Camera on XDA trion focusses correctly for neat focus, but shows a blurred screen for distant focus. When originally switched on to the camera and '1x' focus appears by default, a blurred green...
Most likely you have activated the Macro function. Usually this function is illustrated by a flower icon. This function is used to shoot from very small distances. Deactivate the macro function.
May 07, 2011 | O2 Xda Trion Smartphone
When I press the shutter half-way, it is my understanding I should see a red light in the window telling me it is focused....there's no light. Also, my BEEP is turned ON, but it never beeps??? Canon...
The Canon Rebel XS is a digital camera not film. Most of your problems may stem back to not having a media card installed. Here is a great link for the Canon EOS Rebel XS showing important functions http://www.dcresource.com/reviews/canon/eos_rebel_xs-review/ If you have a media card installed and it has been formatted to the camera then the red light you mention will only flicker for an instant on your focus point, you got to be pretty quick to see it. The in focus light you want to see is a small green dot in the lower right corner of the viewfinder. This "green dot" needs to be solidly lit not flickering. When the camera has achieved focus the "beep" should sound, I suspect you haven't reached focus yet. Not focusing could be as simple as having the lens switch set to manual focus or the camera set to manual focus.
Nov 17, 2010 | Canon EOS Rebel XS 35mm SLR Camera
My camera is showing blurred pictures when taking pictures help
Try reseting all menus to default, then try again to test.
Make sure the lens is clean.
Do the menus appear clear?
Has the camera ever been dropped or had any other damage? This could get the lens out of focus, and would need repair.
Does blurring happen when zooming or when taking a picture of any kind?
Sep 09, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
I have a Canon Powershot sd1100, it suddenly stopped focusing.
did you set to Macro, change to Infinity. or goto SETUP MENU, then perform RESET ALL.
Apr 06, 2009 | Canon PowerShot SD1100 IS Digital Camera
Canon EOS 500n 35 mm film camera green display info blurred
Are you able to adjust the camera viewfinder diopter setting. it should be a small wheel or lever near the viewfinder.
Dec 11, 2008 | Canon EOS 500n 35mm Film Camera
Blurred pink LCD picture
This is a manufacturing defect. Send the camera to canon repairing shop.The will do it free of cost.
I had the same problem,
Jul 14, 2008 | Canon PowerShot A95 Digital Camera
Canon Powershot A75 blurred LCD display
It sounds like the focus element in your lens is not functioning properly. Does the lens retract completely when you turn off the camera? When you push the button does the camera attempt to focus the image? If you do not see any change in the image when you push the button, and do not hear any sound - then your focus motor is either jammed or malfunctioning. David Millier Advance Camera Repair
Feb 13, 2007 | Canon PowerShot A75 Digital Camera
Canon PowerShot SD1100 IS Digital Camera Logo
66 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
