Question about Amana ALE866SB Electric Dryer
I have a ALE 866 dryer and everytime we run it, it is making a loud squeeking sound
  • 205 Answers
Hello- The squeak is most likely coming from the drum rollers which are located under the drum in the rear; these often become sticky due to the heat and dust inside the dryer. It is usually best to replace them once the machine is opened up though sometimes the bearings are ok and one can just remove the wheels and clean the roller shaft with a green kitchen scrubber. The best lube to use is graphite because it does not break-down and get gummy with the heat generated by the dryer. The drum has to be removed in order to perform the service and Maytag (AMANA) belts are very tricky to put back on so I would suggest having a Tech out to accomplish this. They could also clean the inside of the dryer cabinet of lint and check the belt and other components for wear at the same time. Best regards.
Posted on Sep 27, 2010
I have a 5 yr old KitchenAid front load dry that just started to make loud squeaking sound when running or even if I turn the drum when the dry is off. Drys clothing good, just making noise and want to...
You will need to check the tub roller wheels. This is a common noise when the wheel bearings start to ware down. They are not expensive, and you should be able to do this yourself. Good Luck Friend.
Feb 22, 2018 | KitchenAid KEHS02R Electric Dryer
The barrel makes a rubbing squeeking sound as it turns. Sometimes it is really loud and other times it doesn't make the noise.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up
May 20, 2010 | Dryers
Dryer has been squeeking lous when its running?
YES IT IS THE MOST COMMON REPAIR FOR THIS BRAND. PART NUMBER IS 5303281153. REPAIR BEFORE IT BREAKS OFF AND SHORTS OUT THE HEATING ELEMENT.
http://www.searspartsdirect.com
Apr 25, 2010 | Frigidaire Dryers
Loud sqeaking sound when running
check to see if the idler puller is keeping tension in the belt
Jan 17, 2010 | GE Dryers
My GE gas dryer makes a loud squeeking noise running
WE 3X 75 is the part number you need. Take a look at these repair pix
Sep 09, 2009 | GE Dryers
Loud squeeking sound. Figure its the back
Well I do not know which brand you have but I have pictorials on all kinds of dryers at my website. I am guessing yours is a GE. Check out my repair PICTORIAL.
Note: Not pictured is a WE3X75 bearing that goes on the rear of the drum and fits into the center hole pictured above.
WE3X75 drum bearing.
Jul 06, 2009 | Dryers
Dryer was squeeking now not spinning
It sounds like the dryer belt is wore out or broken, you can usually order a replacement belt from the maker of your dryer at there website.
Mar 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool GEW9200 dryer makes loud whining noise...
It might be metal on metal. It is possible that something worked it's way from inside the drum it between the drum and the rest of the dryer. There's just a couple of srcews that holds the back and top on to the dryer. Take them out after un-plugging the dryer, and consider plugging it back in and running it to see if you can here where the squeek is coming from.
Feb 16, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer started out squeeling and now is making loud sounds?
This is very likely due to bad drum support rollers which is really not a difficult repair on these dryers.
Whirlpool Dryer Repair Manual
www.RepairClinic.com
Feb 02, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore Elite model: 22932
Washing machine works fine UNTIL spin cycle. Loud engaging sound and then it makes a squeek, squeek sound...not really a squeek, but if you were to listen to it, eee, eee, eee, eee, eee and loud.
Dec 10, 2007 | Washing Machines
Amana ALE866SB Electric Dryer Logo
97 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
