Question about Dishwashers
I Have dishwasher Electra EDW-9213W my problem is error 004 what is this problem?
2 Suggested Answers
SOURCE: heller dishwasher error 004
Hi all, this error (004) means that there is an overflow....To solve it do this:
1) Disconnect the power to the dishwasher
2) Remove the left cover (to do it remove all the screws..2 are located under the top and 3 behind the front lower cover)
3) Dry very well the bottom plates where is the motor and the electrics wires.
4) The overflow switch is a floating contact, so check that there is no water under it. (You can check it pushing gently the contact).
Before reinstall the cover check that the dishwasher is working fine!
IF YES.....WELL DONE MATE YOU SAVED YOUR MONEY!
Cheers....Aldo
Posted on Mar 11, 2010
What is err1 and err3 in elekta dishwasher?
Electra Dishwasher Error Codes and other critical errors can occur when your Windows operating system becomes corrupted. Opening programs will be slower and response times will lag. When you have multiple applications running, you may experience crashes and freezes. There can be numerous causes of this error including excessive startup entries, registry errors, hardware/RAM decline, fragmented files, unnecessary or redundant program installations and so on.follow the instruction on the link below to find your solution http://www.saetechnologies.com/electra-dishwasher-error-codes/
Mar 03, 2015 | Dishwashers
Everything comes out with a milky film all over the place. No lights are indicating lack of salt or Finish. The model is No. EDW 46 W. It is a three-quarters size, i.e. not full size.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Apr 21, 2011 | Dishwashers
Beaumark bm-dw9702-ss dishwasher error code 004??
I had a error 004 on a Beaumark Model: BM-DW9702-WH Dishwasher which caused it not to run. The Manual stated it was To MUCH INLET WATER. I replaced the Inlet Valve with Part#: DW-53. The Dishwasher now runs great!
Oct 28, 2010 | Dishwashers
Baumatic WQP12-9213 - Error Code 004?
hello
The "004" error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
mean while 004 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F).
however,what you need to do tp fix up the problem is to unscrew the washer then clean up all forms of dry and water you can seen in it with this the problem of the 004 error code is solve .
please make sure that all form of power supply is put OFF before you can do this
thank you and thanks for using fixya.
Jun 03, 2010 | Washing Machines
Grinding noise in Electrolux edw550 dishwasher
One cause can be if the seal failed and allowed some watter to get into the motor bearings. Look to see if this might have occured. The other thing is if debris got into the pump impellers and cannot clear. This can tear up the impellers.
Feb 12, 2010 | Electrolux EDW5505SS Dishwasher
Heller dishwasher error 004
Cheers....Aldo
Sep 20, 2009 | Dishwashers
Error Code: 004
shut off power to the unit first or unplug it after 1 min turn back on this may solve the problem
Aug 19, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Error message 004
Simple fix for me
Simply look at right side of machine get a flash light pull the insulation away from machine stick the light in look for the white little resovoir and the styrofoam float switch.
syphon the 1/2 cup collection this allows the float in the attached
cup to drop kicking the sensor out....
I dont suggest disconnection the sensor as im sure it will come back to haunt you. =)
worked for me takes 5 minutes
enjoy
Nov 12, 2006 | Danby DDW1805W Designer Series...
Dishwashers Logo
126 people viewed this question
Top Dishwashers Experts
Owen Barnes
