Question about HP Hewlett Packard Compaq dx2400 Microtower - KR596UTABA PC Desktop
Notreached: The SCP network is not part of the LAN.
2004 navigator rpm mph gauges quit working
Speedometer
The instrument cluster receives the vehicle speed sensor (VSS) signal from the PCM through the SCP communication network. The instrument cluster micro-processor monitors the VSS input from the PCM and commands the speedometer with a corresponding movement of the pointer.
Tachometer
The instrument cluster receives the tachometer data from the PCM through the SCP network and commands the tachometer according to the data.
Taking your vehicle to a qualified repair shop that has diagnostic tool to scan the instrument cluster for DTC'S - diagnostic trouble codes an also view sensor input data to the PCM engine computer an the I/C would be your best bet .
Nov 16, 2017 | Cars & Trucks
I have multiple codes instrument cluster codes: u1073, u1262, u1059, u1123, u1041; ABS/TCS codes: u1073, u1262, C1805, B2900;
Did you change any modules on the vehicle ?
B2900 VIN Mismatched ABS Module VERIFY that the module has the correct as-built data.
CHECK for correct powertrain control module (PCM) and ABS module configuration using the diagnostic tool. RECONFIGURE the component as necessary. FOLLOW the diagnostic tool directions for the ABS module configuration or REFER to Section 303-01A or Section 303-01B for the PCM. CLEAR the DTC. REPEAT the C1805 Mismatched PCM and/or ABS/TC Module ABS Module CHECK for correct PCM and ABS module configuration using the diagnostic tool. RECONFIGURE the component as necessary. FOLLOW the diagnostic tool directions for the ABS module configuration or REFER to Section 303-01A or Section 303-01B for the PCM. CLEAR the DTC. REPEAT the self-test. U1073 SCP (J1850) Invalid or Missing Data for Engine Coolant PCM REFER to Powertrain Control/Emissions Diagnosis (PC/ED) manual. U1262 SCP (J1850) Communication Bus Fault Network Fault REFER to Section 418-00 . Can a scan tool communicate with all the modules on the vehicle ?
  • The anti-lock brake system (ABS) module or stability assist module (if equipped) does not respond to the diagnostic tool
  • Circuit or connection in the standard corporate protocol (SCP) network.
  • ABS module.
  • Go To Pinpoint Test A .
U1123 Invalid or Missing Data For Odometer Instrument Cluster Go To Pinpoint Test G . U1059 SCP (J1850) Invalid or Missing Data for Transmission/Transaxle/PRNDL PCM REFER to Powertrain Control/Emissions Diagnosis (PC/ED) manual. U1041 SCP (J1850) Invalid Or Missing Data For Vehicle Speed Instrument Cluster REFER to Section 413-01 . U1041 SCP (J1850) Invalid Or Missing Data For Vehicle Speed Tire Pressure Monitoring System Module REFER to Section 204-04 . You need to take it to the dealer , not a transmission shop. Your vehicle could have a ground issue , could have power issue , could have a control module issue . It needs to be hooked up to the factory scan tool ! It is for sure it has a communication problem on the SCP data bus , do you know what serial data communication is ?
The vehicle has 3 module communication networks:
  • the standard corporate protocol (SCP) communications network
  • the international standards organization (ISO) 9141 communications network
  • the universal asynchronous receiver-transmitter (UART) based protocol (UBP) communications network
The diagnostic tool connects to all 3 networks through the data link connector (DLC). This makes diagnosis and testing of these systems easier by allowing one diagnostic tester to be able to diagnose and control any module on the 3 networks from one connector. The DLC can be found under the instrument panel between the steering column and the radio.
The SCP communications network will remain operational even with the severing of one of the bus wires. Communications will also continue if one of the bus wires is shorted to ground or voltage, or if some but not all termination resistors are lost. The SCP communications network allows inter-module communication.
The ISO 9141 communications network does not permit intermodule communication. When the diagnostic tool communicates to modules on the ISO 9141 communication network, the diagnostic tool must request all information, or initiate module commands.
The ISO 9141 communications network will not function if the wire is shorted to ground or battery voltage. Also, if one of the modules on the ISO 9141 communications network loses power or shorts internally, communications to that module will fail.
The UBP communications network will not function if the wire is shorted to ground or voltage. The UBP is different from the ISO communication network in that it allows intermodule communication.
Sep 13, 2015 | 2004 Lincoln Aviator
Define the code...how to repair, estimated repair cos t
U1000 SCP (J1850) Invalid or Missing Data for Primary Id U1001 SCP (J1850) Invalid or Missing Data for Primary Id U1002 SCP (J1850) Invalid or Missing Data for Primary Id U1003 SCP (J1850) Invalid or Missing Data for Primary Id U1004 SCP (J1850) Invalid or Missing Data for EEC Programming U1005 SCP (J1850) Invalid or Missing Data for EEC Programming U1006 SCP (J1850) Invalid or Missing Data for Primary Id U1007 SCP (J1850) Invalid or Missing Data for Primary Id U1008 SCP (J1850) Invalid or Missing Data for Engine Torque U1009 SCP (J1850) Invalid or Missing Data for Engine Torque U1010 SCP (J1850) Invalid or Missing Data for Engine Air Intake U1011 SCP (J1850) Invalid or Missing Data for Engine Air Intake U1012 SCP (J1850) Invalid or Missing Data for Primary Id U1013 SCP (J1850) Invalid or Missing Data for Primary Id U1014 SCP (J1850) Invalid or Missing Data for Primary Id U1015 SCP (J1850) Invalid or Missing Data for Primary Id U1016 SCP (J1850) Invalid or Missing Data for Primary Id U1017 SCP (J1850) Invalid or Missing Data for Primary Id U1018 SCP (J1850) Invalid or Missing Data for Throttle U1019 SCP (J1850) Invalid or Missing Data for Throttle U1020 SCP (J1850) Invalid or Missing Data for Air Conditioning Clutch U1021 SCP (J1850) Invalid or Missing Data for Air Conditioning Clutch U1022 SCP (J1850) Invalid or Missing Data for Primary Id U1023 SCP (J1850) Invalid or Missing Data for Primary Id U1024 SCP (J1850) Invalid or Missing Data for Primary Id U1025 SCP (J1850) Invalid or Missing Data for Primary Id U1026 SCP (J1850) Invalid or Missing Data for Engine RPM U1027 SCP (J1850) Invalid or Missing Data for Engine RPM U1028 SCP (J1850) Invalid or Missing Data for Primary Id U1029 SCP (J1850) Invalid or Missing Data for Primary Id U1030 SCP (J1850) Invalid or Missing Data for Experimental #1 U1031 SCP (J1850) Invalid or Missing Data for Experimental #1 U1032 SCP (J1850) Invalid or Missing Data for Primary Id U1033 SCP (J1850) Invalid or Missing Data for Primary Id U1034 SCP (J1850) Invalid or Missing Data for Primary Id U1035 SCP (J1850) Invalid or Missing Data for Primary Id U1036 SCP (J1850) Invalid or Missing Data for Wheels U1037 SCP (J1850) Invalid or Missing Data for Wheels U1038 SCP (J1850) Invalid or Missing Data for Primary Id U1039 SCP (J1850) Invalid or Missing Data for Primary Id / Vehicle Speed U1040 SCP (J1850) Invalid or Missing Data for Vehicle Speed U1041 SCP (J1850) Invalid or Missing Data for Vehicle Speed U1042 SCP (J1850) Invalid or Missing Data for Traction Control U1043 SCP (J1850) Invalid or Missing Data for Traction Control U1044 SCP (J1850) Invalid or Missing Data for Traction Motor U1045 SCP (J1850) Invalid or Missing Data for Traction Motor U1046 SCP (J1850) Invalid or Missing Data for Primary Id U1047 SCP (J1850) Invalid or Missing Data for Primary Id U1048 SCP (J1850) Invalid or Missing Data for Primary Id U1049 SCP (J1850) Invalid or Missing Data for Primary Id U1050 SCP (J1850) Invalid or Missing Data for Brakes
Mar 14, 2015 | 2008 Lincoln Navigator
Electrical problems 2001 Lincoln Contental
The electronic's , control modules , driver door electronic control module ,the lighting control module , SCP serial data communication network . You have no way of fixing this . A factory scan tool would be needed to check communication on the SCP data network .
010 Ford SCP Communications
You would need factory service info. to find control moduels , there power an ground circuits to do electrical testing . Voltage drop testing etc....
You could very easily make thing's worst , short out the network an the vehicle will do nothing . You have no idea of the complexity of this .
Jun 24, 2017 | 2001 Lincoln Continental
When dialing voice i get busy signal on scp 2400 sanyo
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Aug 12, 2012 | Sprint PCS Phone SCP-2400 by Sanyo(r)...
How do i unlock my sanyo incognito 6760 so it will work anywhere that a sim carded boost phone works?
The Boost sim card network is the iden network. The incagnito is the CDMA network.
They'll only work where they have service for them. Other then that their two totally separate networks.
Aug 22, 2011 | Sanyo Incognito Scp-6760
What is the MSL Code
Get the Unlock code for the SANYO SCP 3100 model mobile at
http://www.superunlockcodes.com/sanyo-scp-3100/rs12wp9/ and Unlock it from the Network lock.
Nov 10, 2010 | Sanyo SCP-3100 Cellular Phone
1996 ford taurus dlc problem
These other garages you took it to , were there scan tools able to connect to any module on the vehicle ? Checking for codes in the GEM - genaric electronic module , instrument cluster etc.... All the modules on your vehicle talk an share information over a SCP - serial data bus . If a module is down it set's a DTC in one of these other modules . You would need a factory or a professional grade scan tool to talk with these other modules . That would be the first step if this came to my place of employment .If no modules on the data network communicate , checking the network would be the next step .
For a quick check of the SCP network, simply place your voltmeter across the SCP pins at the data link connector (top row second from left and bottom row second from left).
SCP voltage will usually range between 4.5 and 5.0 volts. If there is no voltage present at these pins when the key is on, unplug one module at a time until this voltage returns. In some cases, a shorted module will load down the network.
If the voltage is low no matter what module is unplugged, there is likely SCP wiring damage. There needs to be at least one module plugged in to get the voltage on the network.
When testing the CAN network, both voltage and resistance can be checked. Place a voltmeter or an ohmmeter across pins 6 and 14 to check the high speed CAN network.
When checking voltage, the CAN network will normally be around 2.5 volts. When checking resistance, ensure that the key is off. The resistance of the CAN network will be around 60 ohms. An explanation of this resistance can help diagnose a high speed CAN problem.
On a Ford vehicle, there are two termination resistors on the CAN network. These resistors are usually found in the PCM and the instrument cluster. Each resistor is 120 ohms.
When they are put together on the network, the network will show 60 ohms. With this in mind, if you check the resistance and it reads 120 ohms, you know that one of the modules is not on the network. Simply unplug the cluster or the PCM to see which one is on the network.
A low resistance value will usually indicate a shorted CAN circuit, or a shorted CAN module. Unplug all of the modules except the PCM and the instrument cluster and then see if, at any point, the resistance returns to 60 ohms. A high resistance will usually indicate a connector issue, corrosion or wiring issue.
Information courtesy of Identifix Inc. tech department. See www.identifix.com.
also check pin 13 at the DLC to pin 13 connector C 191 at the PCM for a open circuit .
You can find a wiring diagram here http://www.bbbind.com/free_tsb.html
Apr 02, 2017 | 1996 Ford Taurus
Lan Problem
Goto control panel and work your way through the network Set-up Wizard.
If this is not a separte Icon in control panel then look under "network Connection" Icon.
Feb 26, 2008 | D-Link DFE-530TX+ Ethernet ED100W Network...
HP Hewlett Packard Compaq dx2400 Microtower - KR596UTABA  PC Desktop Logo
60 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
