Question about Kitchen Ranges
I need to know how long my suntom 6.5 gf-lge petrol generator will run for on a full tank of fuel
  • Kitchen Ranges Master
  • 17,129 Answers
It will depend on the load on the generator and the setting of the RPM.
but on an average the consumption can be about a litre for every hour with an increase of about 25 % on load.
Posted on Sep 27, 2010
Why is my fuel gauge stuck on full even though there is only 50% of petrol in the petrol tank
Hi,it must be that the gauge or sender unit are faulty,check sender unit first.
Apr 09, 2016 | Cars & Trucks
1989 range rover not pumping petrol 3,9 runs on gas but will not pump petrol
Hi there, did you run the petrol low or out, the fuel pump will keep pumping while the key is on and if your running on gas them it's still running, I would say the fuel pump has failed due to no lubrication from fuel, be sure to keep your petrol tank at least at 1/4 of tank full
Mar 06, 2014 | Cars & Trucks
Running a stihl saw on neat petrol
With no 2 stroke oil in the fuel, it probably wouldn't last a tank of fuel before damaging the machine. Oil is mixed in the fuel as a lubricating agent as the machine generates alot of heat throught the friction of the piston and cylinder.
Mar 09, 2013 | Garden
I cant get any petrol to pump into the mantles
If the petrol doesn't come through first check that you have enough in the tank. If the tank is not full enough it won't come through. If it still fails to come through it's likely that the generator is blocked. This is the tube which the mantle sits on and it has a very narrow opening to force the petrol to convert to vapour when it's warm. Try heating it for a while and it may clear it. Otherwise you'll need to buy a new generator.
Note: while the dual fuel lanterns can burn petrol you should be aware that it gives off poisonous fumes, like cars did before they had catalytic converters. The lantern should not be used indoors with petrol. They are safe with coleman fuel. If you live in the USA, Coleman fuel is cheap but if you're in Europe it's much too expensive. Rather than buying a new generator, if you live in Europe, you could buy a parafin burning lantern like the Petromax 500 available from http://www.pelam.de/index.php?cPath=28_31&language=en&gclid=CIOe46DQnqYCFQkf4QodQxz2Zg
and other sites, or you can pick up second hand Optimus lanterns on Ebay. Both burn parafin, though they need to be primed, and provide at least as much light as the Coleman.
Jan 03, 2011 | Coleman Northstar Dual Fuel Lantern
My 1988 Nissan Sentra E16i will not run. The Engine turns over and may start to run but slowly begins to cough before dying. There is very old fuel in the tank but I have added a fuel stabilizer and mixed...
Water condenses in tanks not completely full & petrol degrades to "near enough" kerosine if left for too long. Also lacquer in the petrol forms a film on filters etc. So you probably have a system filled with water & lacquer now. Suggest drain tank & full flush of lines & filters.
Injectors (if fitted) may need cleaning too. It ran before all the gunk worked loose and clogged everything.
May 27, 2010 | 1988 Nissan Sentra 2 Door
Left petrol tank stays full, not feeding/emptying - BMW X5 4.6is
inside the tank there are 2 or 3 hoses that transfers the fuel to where the fuel pump is. check for leaky hoses.
Mar 10, 2017 | 2003 BMW 5 Series
COLEMAN 5500 GENERATOR. IVE HAD IT 3 YEARS,
Gasoline goes stale after sitting a while and makes starting hard. Three years worth, it's more like jelly! You need to clean the tank, lines, filter, and carburetor. Run it for a while on a little fresh fuel after cleaning, then let it run out of fuel. That will remove most of the fuel from the carburetor. When you want to run it again, add whatever fuel you need, but allow it to run dry again. That's not prefect, but workable.
Aug 19, 2009 | Electrical Supplies
When i Have half a tank of petrol bike cuts out
check fuel tank vent,fuel filter,float bowl vent
Aug 10, 2009 | 2008 Derbi Cross city
My 1990 Cadillac Seville is stalling out
Try a can of dry gas and a full tank of premium
Mar 26, 2009 | 1990 Cadillac Deville
Kitchen Ranges Logo
189 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
