Question about ViewSonic VA902b 19" Monitor
When the display is turn on show for a few seconf the imagin after that back to blak display
  • Kandi Cook Sep 27, 2010
    After the picture comes on the screen, does it say "no video" or "no video connection" before going black? Or does it just go black while going through the normal start up functions? Please clarify and I will help you solve this problem now.
  • 11,361 Answers
Look for bad caps.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 28, 2010
My tv will not turn on. it shows the sleeping red light and sometimes will turn blue but the picture and sound will not turn on? what's going on?
your tv has a bad power supply module. with the model and serial number look it up on ebay, they are like $60. buy a new one and replace it.
Dec 27, 2014 | LG 32LG40 32 in. LCD HDTV
Liquid cristals on the display become blak. maybe a loss of watertightness
Exposure to direct sunlight can damage the display and turn the screen dark.
Sep 08, 2013 | Simrad Is15 Multi Display Only
Sony ericsson w580i screen blaks out when i try to turn it on
hi , what i think is the problem is there is a fault in the circit board ! ur best off having an expert look at it !
Mar 08, 2010 | Sony Ericsson w580i Cellular Phone
When my xps m140 laptop boot up after few minite lcd screen blak out. how to fic this?
There could either be a problem on your LCD screen, or Graphics card, to determine it. Try plugging an external monitor on your laptop and see if the display turns black also on the other monitor. If no, the problem is the LCD, but if yes (still black screen on the external monitor) it means the problem is on the graphics card.
Dec 15, 2009 | Dell Inspiron XPS M140 Notebook
I have 2 ibm thinkpads t40, on one of the systems the lcd inverter and screen get no power but when i take the lcd and connect it to the 2nd ibm tkpad it works fine, What would be wrong with the one lap...
On the second Thinkpad laptop, that doesn't show a display with an LCD screen.
Plug a VGA monitor into the VGA port on the back of the laptop.
Hold the Fn key down, tap once on the F7 key (Toggle your display over to an external monitor)
Give the VGA monitor a few seconds to come on. (It's a VGA monitor)
Do you have a display on the external monitor? No? You May have a bad GPU then. (Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU )
Fix? Change out the motherboard. Possibly Ebay has one, dunno.
VGA monitor has a display? Then you may have a bad Inverter. The Inverter provides power for the LCD screen. Inverters go bad.
Are both Inverters the same? (Laptop to laptop)
BE SURE. The Inverter MUST match the LCD screen!
Check the numbers on both Inverters. If they are the same, switch the good one over to the 2nd laptop. See if you have display now.
No?
Then it's the GPU.
Service Manual for IBM Thinkpad T40,
http://tim.id.au/laptops/thinkpad/T40-T40p-T41-T41p-T42-T42p.pdf
Copy and paste the above link into your Address bar. Press the Enter key. (I don't post direct links that you just click on. I want the asker to be able to see where the link takes them, by looking at the link. I feel it helps make the asker more comfortable with my solution, knowing I have their best interest in mind.
Regards,
joecoolsvette)
(If this link doesn't work for you, come back, and let me know)
Nov 20, 2009 | IBM ThinkPad T40 2373 Notebook
Yamaha HTR 6130 turns on briefly and then off again...
If you have "disconnected" all the speaker wires at the receiver then tested and this still happens, your receivers protection circuit has a problem and needs to be repaired. That is the only way to be certain it's not a short in a wire or a partially bad voice coil in a speaker. Hope this helps
Jul 22, 2009 | Yamaha HTR-6130 Receiver
T.v. wont stay on
hello it sound's like you have a power supply problem. need's to be replaced. "good luck"
Aug 14, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Message: Remove and check print cartridges
Hi Natalia,
Please click on the web link given below and perform the steps as provided in the web page to fix the issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00054461&cc=us&lc=en&dlc=en&product=303753
Perform the steps carefully.
Have a great day!
Mar 02, 2008 | HP PSC 2410 All-In-One InkJet Printer
KRZR K1m Display wallpaper is killing my battery
There's only one light, it shows through on both sides.  Does the verizon load have a screen saver? if so, you might want to disable that.
if it continues, I suggest calling up verizon and telling 'em you've got a defective phone, and want another under warranty, because it shouldn't pop on like that, unless something's happening in the phone.  (for example, transferring files via usb, bluetooth logging on or off, etc).  Mine will go a few days between charges.
good luck!
Sep 27, 2007 | Motorola Mobility MoroKRZR K1m Cellular...
ViewSonic VA902b 19" Monitor Logo
98 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
