Question about Maytag Neptune FAV6800AW Top Load Washer
My Neptune TL FAV6800AWW not responde at all. I can see light come on but no click sound after push start bottan. Before that it was working but some function was not work like a supper wwash, spine only, quick wash, delicate, wrinkle control........ and tempture control as well. Any thought for this? Do i need New main control board????? Thanks
  • 2,272 Answers
Yes its possible.that main control board is faulty. There are 3 possibilities for this problem. 1) Door not closed properly or faulty door lid switch. 2) The Front /membrane(also called the touch pad assembly) is faulty. 3) The main control board faulty. ----------- So first open the door and check the door assembly.On the door side as well as on the machine frame where the door connected.If there is any dust or some thing blocking the door to get connected to the door frame on the machine.If all is clean an ok then check the door latch which open/close.Is this latch looking cracked or broken any where.If that also looks OK then check the door close noise.When the door is closed you will hear a noise.That is a "CLICK" nose.See if that noise is coming.If not then its the indication of faulty door closing assembly,it has to be replaced.Press the door to close bit tightly then check.if the same beep comes.Many cases the door do not close properly causes this.Now in case door and its latch and assembly all checked OK then,in most cases the control board check out faulty.The touch pad is in doubt because ,you do not hear a beep when any button is pressed.as its faulty.But still in some rare cases the front membrane touch pad is faulty.Otherwise its either the door lid switch or the main control board. ---------------
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 27, 2010
Neptune TL Washer FAV6800AWW need owners manual
Google This ""Neptune TL Washer FAV6800AWW""
5th post down is a link for the FAV6800A/FAV9800A SM.
Aug 18, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Fav6800aww machine wont stay balanced move the clothes around it starts back up for about one minute then stops code comes up dc thanks earl
Google this; Neptune TL Washer FAV6800AWW
This is a DIY Appliance repair forum and you can get the Service Manual and repair support at that site..
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with. I'm an owner of a FAV6800AWW top load machine.
In that Sticky I discuss what is the cause of DC or UC unbalance errors and the fix.
Apr 14, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have a Maytag Neptune TL ( Model # FAV6800AWW) washing machine does spend but clothes still soak after it done. when you spend it by hand, it only spend in counterclockwise.
Any error codes. What happens if you start a Spin Only Cycle witht the same load? Does the times stay stuck at xx minutes in the LED display and the machine constantely starts and stops?
The more info on your problem the better.
Do you want to DIY the fix? Google this; Neptune TL Washer FAV6800AWW see the 5th post down here for general info and the Service Manual. If you want to try to DIY the repair I will help.
Apr 04, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I keep getting error code dc and it wont spin
Somewhere on this forum I have a response to DC or UC unbalance errors and the fix. It's hard to find my past post on this forum.
This is a DIY Appliance repair forum and you can get the Service Manual and repair support posted in the sticky at that site.
Apr 03, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag Neptune TL ( purchased in 2005) is grinding during the wash cycle only. Spin cycle is quiet. Once the entire wash/rinse spin completed I opened the washer to retrieve the load and found a piece...
Jose,
I'm an owner of three FAV6800A machines and I'll respond to help because you want to roll up your sleeves and try to save your $1K machine.
1st No direct links Google this Neptune TL Washer FAV6800AWW
Post in that forum your machine Model which I assume is an FAV6800A (LED Console) or FAV9800A (LCD Console)
Include the first two digits of you machines model number. That is the series of your machine.
Give a description of the issue as you did here. I hope the grinding is during wash/agitate if so it may be something as simple as tumbler removal to clear out debris. If the grinding is in Spin Cycle it could be a bit more work like Outer Tub bearing failure.
The Forum in my opinion is geared more toward the DIY owner as I am and as you sound. The forum is free like this and my support is free..........Good Luck D*ick
Mar 26, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I start load of wash, with setting of Max Extract being ON. Clothes come out very wet
I would put the machine in Service Mode with that Wet Wash Load in the wash basket and do a Quick Spin Test on page 14 of the Service Manual and record the fastest RPM that the wash basket will pin up too.
If you don't have the Service Manual Google this Neptune TL Washer FAV6800AWW
If you want help post your issue in that Maytag DIY froum and I will help you......or stay here and see how it's goes.
Mar 21, 2011 | Maytag Neptune FAV6800AW Top Load Washer
GETTING DC ERROR CODE WITH A GRINDING SOUND AND THEN IT STOPS COMPLETELY
The DC error code is 9 time out of 10 caused by a Clutch Pulley malfunction. The grinding may ne Outer Tub Bearings but need more info. Open the Washer Lid. Spin the wash basket CCW. Do you hear and grinding noise?
The noise may be coming from under neath the tumblers. Further troubleshooting is required.
Do you have basic DIY mech. skills and do you want to save your $1K machine?
If so Google Neptune TL Washer FAV6800AWW
Good luck.
Mar 17, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My MAytag will not spin the water outta my clothes on spin cycle
If you machine is a FAV6800A or FAV9800A don't worry about the last two letters of the model number.
If you need help post in the Maytag/Magic Chef/Admiral/Jenn-Air forum with your issue and we will try to help.
Feb 28, 2011 | Maytag Neptune FAV6800AW Top Load Washer
WHERE CAN I GET THE SERVCICE MANUAL FOR FAV6800AWW IT HAS BEEN DISCONTINUED/IS THERE A PDF SITE
Yep
Google "Sticky: Neptune TL Washer FAV6800AWW"
5th post down I start with Sticky DIY info this site has the 16022808 Revision 0 December 2003
My site of choice for helping owners with FAV6800A/FAV9800A issues.
Feb 04, 2011 | Maytag Neptune FAV6800AW Top Load Washer
How to get front panel off neptune fav6800aww washing machine
Just a quick search in this forum fot "Front Panel" returned this post which says it better then I could.
http://www.fixya.com/support/t538238-remove_front_panel
Jan 18, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
27 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
