Question about Linksys Wireless-G Broadband Router
Router I recently moved but I forgot how to hook my router back up to my computer. Can someone please help me?
    Sergeant:
    Champion:
  • 427 Answers
Yea, if you have your initial run CD, use that but here is how you do it.
MODEM-ROUTER-COMPUTER
I
Other wireless devices.
You plug the ethernet cable going from the modem into the plug on the router labeled internet. Then give it a cable from ethernet slot 1 to the computer. You should be good 2 go.
Posted on May 24, 2008
I have a dell 2400 desktop computer. I recently got FIOS and they hooked my wife's computer to their router with an ethernet cable. Can I also hook my dell up the same way?
Depends on the hardware. Is it a router or modem? Does is have extra ports in the back,
Router with extra ports, just connect new device with wire or even wireless if it has wireless.
Modem, most likey you have to buy a router.
Dec 28, 2012 | Dell Dimension 2400 PC Desktop
I recently moved from Cable ISP to DSL ISP service. For the DSL service, I was asked to configure my Router to use PPPoE with Dynamic IP addressing. I also provided the router with my username and password...
The reason you have no internet is because the router is specifically for cable. your description contains errors what i think you mean is that you have gone from cable dsl to an adsl, correct me if i am wrong. Basically your modem connected to your router via an ethernet cable and then the router fed the wireless signal to your wireless devices or via ethernet through the 4 ports in the back. With adsl you have a feed from your phone line to an adsl modem so the only way for you to get the dsl router working is to have two ethernet leads connecting to your pc, one from the modem to the pc and one from the pc to the router. You would also need to setup internet sharing on the pc thats connected to both devices.
Either do it that way or buy an adsl router
Nov 10, 2010 | D-Link DI-624M Router (DI624MRE)
Please help me install the above router. I bought
First connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
If you cant access it with above link then reset it to defaults.
For that check in back panel of router you find reset button press it for 10 seconds so all settings goes to defaults.
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page for router.
Enable dhcp if you want to get ip from router.
check wireless settings .
Check wep password if it is enable for security.
Let me know if you need further assistance.
Thanks.
Oct 26, 2009 | Linksys Wireless-G Broadband Router
I moved my computer - unhooked the modem and wireless router and
Powerdown the PC, router, and modem then start the modem first then the router and finally power-on the computer... That should do it! Hope it helps!
-- Joshua79
Apr 04, 2009 | Belkin (F5D7230-4) Router (587009)
No internet signal from router in other ports
Hello, Under the wireless menu on router you must give a ssid name and enable and save to turn on wireless , hoe this helps?
Mar 21, 2009 | Linksys Wireless-G WRT54G Router
Wireless router pass word
sakoz,
You have to reset your router. There is a small reset button on the back, which you have to hold in for at least 15 to 20 seconds if I remember correctly.
You should be able to then log back into it with the factory preset it came with.
Please let me know if this helps. Good luck!
Mar 01, 2008 | Linksys Wireless-G WRT54G Router
Hooking up xbox live
Well, it's very possible if you are using a wireless router that your connection may not be strong enough. XBOX Live and most online gaming requires a steady. strong, high bandwith connection. A weak singnal, OR someone else using up the bandwith (i.e. someone downloading music on another computer connected to your router) can cause the problem.
If you're using a wireless connection, try moving the router and wireless game adapter closer to each other.
If you're using a hardwire connection from one of the routers outgong ports then make sure other's aren't on the internet (Or at least aren't using alot of bandwith) while XBOX Live is being used.
Please remember also that if you have a wireless network and you haven't implimented wireless secruity (i.e. WEP or WPA encryption) then your network is "Open" and anyone within range can connect and use up your bandwith,
Feb 24, 2008 | Belkin (F5D7230-4) Router (587009)
Having a problem with netgear
Hook up the Cable from the DSL or Cable modem to the Router. Run one cable from the router to your main computer.
Open up Internet explorer and type in 192.168.0.1. or 192.168.1.0 to access the router setup . Run the setup wizard,
Dec 04, 2007 | NetGear WGR614 Wireless Router
Linksys Wireless-G Broadband Router Logo
37 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
