Question about Kitchen Ranges
The front wheel carriage for my Hoover cyclonic mach 3(U5180-910W) needs replacing - again. I have the replacement part but I need detailed instruction on how to install it. Thanks.
SOURCE: Mach 3 cyclone hoover vac
I have a MACH 3 Cyclone that is only a few months old that just suddenly stopped working and went totally dead like there was no power going to it.
I tested the power switch and noticed that there was no power running to the switch.
I then noticed that the switch sat on top of a very long adjustable handle so I figured I would check the pwer connection at the base of the handle.
1) I unscrewed the 2 screws closest to where the power cord goes into the vacuum.
2) Pulled the small blue cover partially out (it wouldn't come out all the way)
3) I found that there is a power cord (looked like a really small extension cord) that runs through the inside of the handle. Adjusting the height of the handle must have made it come uplugged at some point. I plugged this cord back in.
4) I reattached the small blue cover and screwed the 2 screws back in.
This fixed the problem.
I am willing to be that this is a common issue with this vacuum cleaner. Its a 5 minute very easy fix and strongly suggest checking this if your vaccuum suddenly goes completely dead without warning.
Posted on Dec 07, 2008
  • 8 Answers
SOURCE: Replacement carriage belt for HP DesignJet 800 Printer
It is not recommended that the user replace the carriage belt, on any HP printer. Any damage caused by the user, won't be covered by the warranty and will likely result in a completely useless, but very expensive doorstop. Or paperweight..
I do believe your printer has since been discontinued for support, however only an HP Customer Service Representative would be able to confirm that. I would suggest phoning HP for technical support or to at least confirm whether support is available.
Even if your printer is no longer a) under warranty, which I suspect it's not, or b) out of support completely, they may be able to provide you with a list of Authorized Service Providers (ASPs) within your area.
1-800-474-6836
Best Of Luck.
Posted on Dec 15, 2008
  • 3 Answers
SOURCE: Replacing front turn signal bulb on 2006 Cadillac SRX
wow i feel sorry for you because Cadillac designed this bulb to be a don't get to bulb but OK here's what you do take the bottom cover off or skid plastic panel under neath the front end theirs little plastic clips holding it on just get come dikes and don't cut them but just use it to help pull them out. after you get that off use a flash light and locate your light housing you should see two screws holding the house in i think those screws are 8mm i cant remember remove those two screws and be careful the metal from the bumper cuts you pull the light housing out and remove all the screws around the housing and open the housing up replace the bulb and make sure your contact to the bulbs clean and then reassemble the way you took apart. if you cant get it well then best bet is take it somewhere i know Cadillac charges an arm and a leg so you can go somewhere else.
Posted on Jan 25, 2009
  • 3 Answers
SOURCE: hoover mach 3 cyclone vacuum
I had same problem. Turned out to be the filter that sits above the waste cannister. Remove the waste cannister. There is a little orange lever that releases the filter. It was caked with dirt not allowing any air flow causing the motor to overheat.
This foam filter gets dirty pretty fast.
Posted on Mar 01, 2009
  • 204 Answers
SOURCE: need detailed diagram and instructions alternator replacement
if you go to your local auto parts store you can buy a chiltons manual for the vehicle for around $15-25 and this will tell you how to do it. hope this helps you out. and please rate my solution
thank you
Posted on Apr 21, 2009
Replacing the filters in a hoover mach 5
The filter is located under a cover directly under the bag in the bag compartment. That's the only one I can think of.
May 15, 2012 | Hoover U5194-900 Mach5 Multi-Chamber...
Hoover Mach 3 (Fusion): Dirt Will not enter dirt cup
The dirt in my vacuum keeps getting stuck into the hose and dosent reach the chamber, its a constant problem even if i clean out the clog!!
Jul 31, 2009 | Hoover Elite Rewind Bagless Upright...
Our Mach 5 turns off after running for about 5 minutes and smells hot!! Help!!! We have 3 kids and I need to Vacumn.
Hello:
Go here
Then find the clean filter section and clean all the filters especially the secondary filters. i think this will solve your problem.
Jul 07, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Hoover mach6 the brushes don't turn
Replace the skinny belt, but here's the kicker. turn the belt inside out so that the writing is on the inside and sits against everything. Thats what I did and I have used it once and it worked well, Lets hope it'll keep working.
May 20, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
I have no suction with my Hoover Mach 5 vacuum.
I had a similar problem. Two things to try. There is a lock symbol on the canister you need to ling it up with the mark on the top (the silver part has a line on it). It can be assembles 3 different ways. Also I over looked the sticker in the back of the canister compartment indicating a filter in the top of the canister compartment. There is an orange lever there to release the filter. Hope this helps.
Mar 19, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
My hoover mach 6 bagless overheats, shuts off for about an 1 hr will run again, all filters are clean, no blocks in hoses, how can i fix this problem
This is telling you that there is poor air flow or a blockage somewhere. To simply check for proper suction, remove the accessory hose to see if there is normal suction, if not then your problem is further in the unit. Troubleshooting from there will tell you where the problem is. Another possibility is that your thermal overload circuit is faulty. in this case a pro vac shop needs to service the issue.
Feb 28, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Brush won't spin on my Hoover Mach 5
I love this vacuum but had the same problem.
SOLUTION:
take the roller off and flip the thin belt inside out. This fixed my vac and works great again.
Oct 12, 2008 | Hoover U5194-900 Mach5 Multi-Chamber...
How to fix wheels on hoover vaccum cleaner
i cant get the back wheels off my mach 3 hoover vacuum can anyone help?
Jul 14, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Hoover mach 5 only used 3 times
If the filters are ok, and there is no clog in the hose or dirt inlet down by the brushroll, then the motor protector is probably bad.
Mar 13, 2008 | Hoover Commercial C1660-900 Bagless...
Kitchen Ranges Logo
65 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
