Question about Singer 3116 Simple
When running the machine, the needle does not grab the bobbin.
  • Singer Master
  • 7,365 Answers
Check your needle to see if it's damaged
make sure you have a 3-5 inch tail on the bobbin thread
then make sure you have a 3-5 inch top thread tail, then hold the top thread tail in your fingers (away from the needle) & turn the handwheel on the right hand side of the machine slowly letting the needle down in the bobbin area & see if the bobbin thread will pick up that way
Posted on Sep 27, 2010
Consew 206rb bobbin won't loop and grab needle thread
the needle thread should form the loop which is grabbed by the hook. before getting too involved with timing etc, clean bobbin area a fit a new needle
Feb 02, 2014 | Sewing Machines
My needle does not pick up the bobbin thread. I double checked that I threaded the needle correctly and the bobbin seems to be in the right position. The needle doesn't look like it's making contact with...
Make sure that you have the needle's flat side facing the rear of the machine, or else it will never grab the thread. Also, make sure you hold the top thread in your left hand until it grabs the thread and you pull the bobbin thread up
Sep 07, 2010 | Euro-Pro Shark 60 - 384
Needle won't grab thread from bobbin
Sometimes you have inserted the needle wrong, make sure that the needle faces the rear, if that is not it, try a new needle. Make sure that you have threaded the bobbin right, by your manual, and have at least a 6 inch tail, hold your top thread and move your handwheel towards you, not away from you and it will grab the thread. If any questions go to euro-pro.com
Sep 06, 2010 | Euro-Pro 9130 Sewing Machine
How do I fix skipped stitches?
i work on this kind of machine all the time.but i have never set one up for this type of material.if i was having this kind of trouble on a machine i would make sure the tension for the thread is not to tight because this can cause it to skip.if the material is real heavy it will push the needle away from the bobbin hook causing it to skip .is the needle depth set right.tilt the machine up and watch the bobbin as you spin the machine by hand.the needle should just start to come up then the hook on the bobbin should grab the thread.the hook on the bobbin should be as close as you can get it to the needle with out touching the needle.try putting some of the material on the machine while you run it by hand and watch needle and bobbin.if you need to adjust the machine their are two bolts on the bobbin block.if you loosen the screws you can move the bobbin closer to the needle. also their is a screw on the needle bar to adjust the needle depth up or down, i hope this will help you out.
Apr 05, 2009 | Consew 255RB-3 Mechanical Sewing Machine
Needle hits the bobbin holder and doesn't grab the bobbin thread
Check you have the right size bobbin case the gap where the needle enters should be 13mm approx at the widest point. A lot of other pfaff bobbin cases seem to fit and can be easily be mistaken. I have two pfaffs and have accidentally mixed the cases and had a similar problem.
Mar 04, 2009 | PfaFF Creative 7570
Bobbin holder problem. Needle hits bobbin holder and doesn't grab the bobbin thread. It will break the needles if persisted.
Is the needle all the way up in the holder? Have you checked the timing with the bobbin and the needle. Look in your manual for needle timing
Mar 04, 2009 | PfaFF Sewing Machines
Top & bobbin thread will not sew
Most likely the needle is in backwards. Weird I know, I have no idea why but if the needle is in wrong, it either hits the bobbin and breaks or won't grab the thread at all. Good luck.
Jan 06, 2009 | Brother LS-1520 Mechanical Sewing Machine
Needle won't grab bobbin thread
Check the position of the needle. Some machines have to have the needle in a certain way or they won't pick up the thread from the bobbin. Make sure the screw on the bobbin is tight but not to tight you may have to adjust it a few times to get it where it needs to be. Also make sure the bobbin is wound tight
Jun 17, 2008 | Kenmore 15208 Mechanical Sewing Machine
Picking up bobbin thread
First easy thing to check, are you using the correct length needle.
If this is not the problem then somehow the needle bar has moved and the the needle depth is to high or the timing is wrong..
Unless you really know what you are doing then I am afraid a sewing machine tech needs to reset the needle depth and subsequently the timing.
Mar 30, 2008 | Singer CE-100 Futura Computerized Sewing...
Singer 3116 Simple Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
