Question about RCA R52WH73 Projection Television
Can not find the convergence setup on the tv.
  • RCA Master
  • 5,138 Answers
Try this with TV off Press and hold Vol- and CH- at same time untill TV comes on release this should be in service menu now. No Convergence in menu means Blowed Fuse FL231
It is located on right side of FBT flyback transfomer there is 3 of them in a roll smallm brown rectrangler looking caps BUT are Fuses it will be the one in the Middle. Partstore .com has them.
Posted on Sep 27, 2010
Looking for Setup guide on Convergence
look for the auto convergence in the menue of the tv, and if you have any star wars dvd's, they have a set-up feature, some test patterns to adjust contrast, brightness, etc
Mar 06, 2013 | Philips 50P8341 50" Rear Projection...
52" rca hdtv has a shadow ghost when it plays. It
convergence issue. Press menu and then scroll down to the setup option enter setup and scroll to Autoconvergence and activate the auto convergence feature that will realign the convergence . If that doesnt correct the issue you will need a Convergence power board, If the auto convergence feature is missing from the setup menu then you need the convergence option missing repair kit. Both the board and the repair kit are available from
Jun 18, 2011 | RCA D52W23 52" HDTV CRT TV
My Zenith tv picture on the screen looks like a bowtie red green and blue are seperated on screen
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 24, 2010 | RCA D52W23 52" HDTV CRT TV
Color is warped and the convergence colors setup on the setup screen will not reslove the issue, Problems was most like caused by an electrical surge.
Could be?Might not,these are very common problems on DLP tvs convergence board are dead.The tv have convergence problems,it dead.The tv convergence board require the 2 STK convergence ICS and some or all it resistors are dead.These parts require changing,to solved convergence problems.The shop will $300-350 for parts and labors.
Jul 12, 2010 | Panasonic PT-47WX49 47" Rear Projection...
I have a PT-47WX53 that has one vertical bar down the middle of the screen. Barely visible in a purple hue and about 3-4 inches wide. I'm looking for some suggestions. Thanks
A few simple things you may try. Under your menu on the tv look for convergence or it also may be under setup. Run the convergence setup and follow the on screen instructions. If the tv fails to converge while in setup you may need to replace some things however the parts are very very cheap. If your convergence setup works and you still have a bad picture, and or both, meaning the tv's convergence wont align then you may need 1 or 2 IC's and maybe need to change your coolant in the tv's RGB lens...all can be done with little experience and for under 50 bucks. I can give more detail if needed.
Dec 28, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Convergence wont show up in the setup page on T.V.
this convergence is in the sub menu for repair shops
Dec 25, 2008 | RCA HD52W59 HDTV Projection Television
Convergence problem on rca model d52w23
Replace convergence board or repair it. Try this with TV off Press and hold vol-and ch- at same time hold untill set comes on Now you should be in service menu Go to convergence Adjust the 16x9 mode.
Dec 21, 2008 | RCA D52W23 52" HDTV CRT TV
Green rainbow streak on bottom of TV PT-47Wx49E
If Convergence on setup dosen't work, And you think its not STK Convergence chips!, Then "Yes" It more then likely will have a few open Resistors!... (Near STK chips)
Jun 24, 2008 | Panasonic PT-47WX49 47" Rear Projection...
RCA HD52W59 Projection Big Screen TV
This problem is commonly refered to as a CONVERGENCE problem. Question 1 do you have convergence seting in setup menu...if you do NOT it could be a special small fuse. 2 if you go into setup then convergence. then can you move crosshairs in setup. Since you have a arcing picture this indicates convergence power supply which has to be replaced or repaired,
May 09, 2008 | RCA HD52W59 HDTV Projection Television
RCA R52WH73 Projection Television Logo
48 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
