Question about Panasonic Microwave Ovens
Panasonic NN-A574S microwave trips power when plugged in, earth to neutral short at 134ohm with earth disconnected micorwave wil not power up, case is not live, was cooking poataoes when it failed, internal boards do not show signs of blown components and when removing case earth bonds internally I cannot fine one that removes the earth leak? any ideas where to look, what to replace first?
  • 525 Answers
You may have a faulty door switch. 1 of 3 switches is a direct short switch which protects the user from an open door scenario.You could also have a shorted H.V. capacitor. Use caution as a severe shock injury could occur.
Posted on May 24, 2008
  • Panasonic Master
  • 9,086 Answers
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
Earth and neutral are tied together in your breaker box, so they should read virtually zero anyway.
The 134 ohms you're reading is probably from line (hot) to neutral and it's probably the normal resistance of the primary low voltage transformer on the control board. Unplugging the power connector to the board then measuring again would tell you that.
We have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
I have a panasonic model nn-sd277 microwave. I changed the fuse and now it has power again. The fan and light all work. It trips my breaker and sometimes blows the fuse when you try to heat anything.
time to take it to an appliance repair shop for a quote
it is blowing fuses and tripping breakers because it has a serious short in the electrics
Jan 03, 2016 | Panasonic Microwave Ovens
We have a Panasonic NN-CT579SBPQ. Using it last night there was several cracking noises then it stopped. The display showed the message you get when it is first plugged in. Tried it again, turntable...
The microwave oven needs to be replaced, the magnetron is the most likely problem, there is also a high voltage transformer, capacitor, and diode that are potential issues. But by your description it sounds like more than one part is involved.
Feb 23, 2011 | Panasonic Microwave Ovens
My model is nn-s253wf, micowave stopped working, no power, checked circuit breaker, is ok ?, unplugged, then plugged back in, still no power ?
Inside the external case and usually to the right left ( from Front) in some models There is a 30 amp fuse ( This may vatry on oven output amperage) Replace that and you should be back in cook mode.
Removing the case you should remember to disconnect from the power plug.
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Panasonic NN-S252WF Microwave Oven
Panasonic NN-CD997S microwave
i have microwave problems power trip when switch on the unit. please help me.
Jan 06, 2010 | Panasonic Microwave Ovens
My new microwave is completely dead
good day,
hope this link below will solve your problem.
kitchen appliances
May 24, 2009 | Panasonic NN-H504WF Microwave Oven
Panasonic nn-s558ba microwave won't power on
Lee,
Have Landlord replace unit after verifying that outlet has power.
In the future, follow manufacturer's cleaning instructions and DO NOT
run microwave without something in it (even a microwave safe cup of water).
Larry Hanson EH&S Specialist
Apr 04, 2009 | Panasonic NN-S558BA/WA Microwave Oven
Panasonic microwave oven NN-S235WF modle
just replace micorwave power out let.
Dec 30, 2008 | Microwave Ovens
I have a Panasonic microwave model nn-sa616wx sn 58100747 it keeps triping the breaker after it operates for awhile we have taken a amp reading and it draws 17.2 amp.This is a new microwave.
Safety first, unplug your microwave from socket outlet.Needs to troubleshoots series of components using eliminating method to know which component(s) that causes breaker to trip off. It is obvious that a componet(s) "shorted out".Remove your fuse and replace it with resetable breaker tested.
Remove leads of the transformer output(secondary side). plug power cord run the microwave.If does not trip off the cct breaker change your transformer. do the same to capacitor lead, one after the other until you discover which component that shorted and cause your cct breaker to trip off.
Jul 24, 2008 | Panasonic Microwave Ovens
Panasonic NN-S254B How fried is it?
There is an internal fuse, so check that first. If the fuse checks ok, definitely buy a new microwave - losing a neutral usually damages the main circuit board. Given the cost of the board and the distance involved, it just wouldn't pay to chase the parts down
Jun 18, 2008 | Panasonic NN-S254BF Microwave Oven
Microwave causes GFCI on another circuit to trip
You may have a shorted High voltage component. Possibly a recttifier,aka, diode. This should only be replaced by an experienced repairman as an extremely high voltage shock potential exists.
May 27, 2008 | Panasonic NN-H764 Microwave Oven
Microwave Ovens Logo
190 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
