Question about Samsung 932BW Monitor
Can someone tell me how to open the case of my Samsung 932BW? There are no screws on the back or front. I need to open it up to take a look at the capacitors. Thanks.
  • 33 Answers
1.follow this first
2.Turn the monitor so the front section is facing
upwards. after completely pulling this front cover,
Turn the monitor so the back of it is facing
upwards. Lift up and remove the back cover.
Posted on Oct 03, 2010
Open case of samsung writemaster external dvd drive how to
I just had the same problem and this is how to do it:
1: Carefully pry the silver trim off. Begin at the back of the unit. You might need to use a knife or small screwdriver to pry it loose.
2: Unscrew the small philips screws, two on each side.
3: Press the plastic tabs (three on each side) to release the top.
4: lift off the metal cover at the back.
If you need to, you can lift out the optical unit from the front since it's not fastened in any other way than the standard IDE and molex connectors.
Feb 04, 2014 | Samsung SE-S184 DVD Writer DVDR/RW...
How to put samsung 932bw back on the stand
With a large screen device, it is best to have someone help you place it face down on a soft surface such as a blanket for installation of the metric mounting screws
Sep 28, 2013 | Samsung 932BW Monitor
Have a samsung 203b (R) C lcd monitor that i believe needs caps replaced cant figure out how to open case no screws probably just plastic clips holding bezel on
The case is held together with plastic finger hooks type setup, it goes together real easy but hard to separate. I use thin flat blade screw driver to crack it open starting at the center bottom edge and then work your way around, when you get the bottom, left and right side part way open, you will then lay it face down and then pull the back up, just watch out for the cable attached to the front bezel.
http://s807.photobucket.com/albums/yy352/budm/SAMSUNG/
Jun 30, 2011 | Samsung SyncMaster 203B LCD Monitor
Turns on then picture disappears
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 13, 2010 | Samsung 932BW Monitor
I have a samsung Syncmaster 932bw and turned it on and noticed a real bad flicker ran all the tests i could find other then your flashlight test cause i dont think it pertains to my certain problem. after...
The flickering picture usually indicates that the power supply is failing. The most likely cause of the power supply failure like this is capacitors either drying out or bulging from over heating. We have a page on our web site at: http://www.ccl-la.com/blog/index.php/capacitors/ This article wexplains what capacitors are, what you will need to look for to identify the failures and which brand and series to get tof rht replacements. In most cases you can open the monitor and look over the power supply and see obvious bulging on the capacitors that are failing. If you replace them you should be back in business. If you have additional questions just let us know.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
May 01, 2010 | Samsung 932BW Monitor
I have owned a Samsung 932BW a couple of years. First symptom noticed was a blank screen and a blinking blue light around the on switch. From another desktop computer, I have swapped video cards,...
reynolds3d, Nothing new here. Happens a lot. 932BW will need to have some work done to the unit's SMPS probably. Read my fixya profile and make decision on what you will do based on info found there. 12fixlouie
Feb 20, 2010 | Samsung SyncMaster 932B LCD Monitor
How do I open cover of Acer AL2021 Monitor ?
This is a bit tricky, but not impossible.
1. Remove the two visible screws near the bottom. 2. Pull the plastic covers off the stand: Pull from the inside (nearest where the stand is attached to the monitor. 3. Undo the screws and remove the bracket. 4. Under the bracket is the final screw. 5. Try pulling the front off the back starting at the bottom. It'll require a little force. 6. Now you should be able to get a knife in to pull the rest of the case off. Leaver by pushing the front outwards and back inwards and the clips should come off ok.
Aug 06, 2008 | Samsung SyncMaster 550S Monitor
How to open up the casing on this monitor.
It is not initially obvious how to access this insides of the monitor Unusually, access is only available through the front of the screen. The stand cannot be removed on this model. You need to pry a screw driver (or two) through the four holes located at the rear base of the monitor and remove the front panel surround. The LCD panel and all electronics can be lifted out after removing four screws.
Oct 03, 2006 | Tatung CLT-L50 15" Flat Panel LCD Monitor
Samsung 932BW Monitor Logo
715 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
