Question about Kyocera CopyStar CS-3060 Black and White Copier
In the starting error c3100 - Kyocera CopyStar CS-3060 Black and White Copier
  • 113 Answers
Error associated with the optical section. Check if the exposure lamp is coming on or clean the exposure lamp and optics when machine is off state. after cleaning put on the machine and test.
Posted on Nov 17, 2010
How to repair kyocera 1024mfp error code c3100
http://www.fixya.com/support/t6140540-also_need_service#solution-section
Feb 14, 2015 | Kyocera Office Equipment & Supplies
Error C3100
This code means machine's scanner home possition error. Try to check scanner home possition sensor if fixed in its possition. if not try to check scanner lamp unit movement .
Jan 20, 2013 | Kyocera FS-1035MFP
Canon Imagerunner C3100 shows error code E00012-0001
Drum motor error
Check the connector and replace the motor
Jan 17, 2013 | Canon imageRunner C3100 Copier
When i get my c3100 started i get an error code e 000013-0000 . can you tell me what the problem is
Waste toner bottle full, open front door, one screw, make sure small cut out in the neck of the bottle is clean afterwards.
Oct 31, 2010 | Canon imageRunner C3100 Copier
I am geting an error code of c3100 call for service I am geting an error code of c3100 call for...
C3100 Scanner carriage problem
The home position is not correct when
the power is turned on or at the start of
copying using the table.
Poor contact in the
connector terminals.
Check the connection of connector YC4 on
the scanner PWB and the connector on the
scanner home position switch, and the continuity
across the connector terminals. Repair
or replace if necessary.
Defective scanner
PWB.
Replace the scanner PWB and check for
correct operation.
Defective scanner
home position
switch.
Replace the scanner home position switch.
Defective scanner
motor.
Replace the scanner motor.
The mirror frame,
exposure lamp, or
scanner wire is
defective.
Check if the mirror flames and exposure
lamp are on the rail. And check the scanner
wire winds correctly.
took this from a diffirent kyocera copier but it will be the same scanner related code
Oct 13, 2010 | Kyocera Copystar CS-1820 Black and White...
Error codes of my kyocera KM 1635
c3100 is a scanner home position error, does the scanner move when turned on with lid up? if not its the motor, if it moves then it mat be a sensor (usually "U" shaped in rear left under glass, or it could be "locked" for shipping, look for a switch on left side or under scanner unit. hope this helps.
Jan 11, 2010 | Office Equipment & Supplies
KM-2050 / error c3100
• The home position is not correct
when the power is turned on or copying
the document placed on the contact
glass. Poor contact of
Defective scanner
home position
switch.
Defective engine
PCB.
Defective scanner
motor.
Sep 30, 2009 | Kyocera Mita KM-2050 Printer
E070-003
when i open the printer the unit will int.rot. and then the error will appear. tnx...From Canon Support Product : imageRUNNER C3100 / C3170 Title : E00351-0000 Problem
May 05, 2009 | Canon iRC3100 Printer
Kyocera CopyStar CS-3060 Black and White Copier Logo
381 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
