Question about Dell Vostro 1000 Laptop
My laptop won't power with or without the AC power chord
    Brigadier General:
  • 10,406 Answers
Take the power-adapter and the computer to a qualified technician.
There's nothing you can do by yourself to "fix" the problem.
A technician can test the voltage/amperage output from the power-adapter, and can try a different power-adapter, or try to recharge the laptop's battery.
Posted on Sep 27, 2010
2 Suggested Answers
SOURCE: not powering on
This is a common fault with all HP/Compaq laptops in the NX and NC range, which affects the motherboard. I can fix this motherboard fault and replace all the required components, strip the device down and reassemble it, then fully test the hardware and stress test the entire system for just £50 plus return postage.
If you are interested in this service please contact me on liamcrayden@gmail.com - the average turn around is 5 working days and there is no fee if your laptop cannot be repaired. Note that we have large success especially in the NX6310 and NX6325 ranges.
Posted on Jan 23, 2009
My battery is fully charged but there is no power
The power on the main board may be fried or you just aren't really charged. Check your ac adapter chord these can go and not charge anything replace ac chord and battery and if that isn't working it's probably your motherboard and then it's new laptop time!! Exciting isn't it.
Apr 18, 2015 | Computers & Internet
Stuck in sleep mode
remove the battery and unplug your power chord for 1 min. then plug your power chord back in and try to turn it back on.
if it works then plug your battery back in and see if it boots your system up without the power chord.
if everything works fine then go into your control panel and change your power options.
Feb 12, 2014 | HP Pavilion Dv7-4065Dx Laptop Lcd Screen...
Toshiba A205-S5809 Wont power on
Try another cord/charger with the EXACT same power specs. If you have a multimeter, verify DC voltage at the AC jack plug. If the AC jack, in the laptop, has been pulled, damaged, it's may have a loose connection. You didn' say if ANY LED's, battery charge, work? If the battery is charged and it doesn't start on battery only, then you have other issues. It may need a ride to a Qualified Computer Tech.
Jan 08, 2013 | Toshiba Satellite A205-S5809 Notebook
No power
Hello, If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems. 1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose Hope this helps
http://www.chargerbuy.com/laptop-ac-adapter/toshiba-ac-adapters.html
Nov 10, 2012 | Toshiba Computers & Internet
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
My HP Pavillion laptop g61 wont turn on or off. There is no fan running it doesnt sound like it is on but the power button light is on and wont turn off. The screen just stays black. I have tried charging...
I had trouble looking up that model on the HP page, but you should check this page and see if this model is affected by this NVidia litigation. If it is, you can get it fixed/replaced on NVidia's dime.
http://www.nvidiasettlement.com/affectedmodels.html
Oct 15, 2010 | HEWLETT-PACKARD Pavilion G61631NR Notebook
I HAVE A LAPTOP ACER AND THE POWER DOES NOT TURN ON
It could be a battery problem. Try switching to AC mode by plugging in to an AC outlet using your Acer power chord (battery charger also). If the charger led don't light, it means it's defective and it can't charge your battery. Please try another power chord or battery charger then. Just remember to take out your battery when using your laptop in AC mode to lengthen your battery life. Regards!
Jul 05, 2009 | E-Machines eMachines Desktop PC
Powering up a dell d610 laptop
remove the battery and start the machine on AC power only, see if this helps
keep us informed
regards
Nov 24, 2008 | Dell Latitude D610 Notebook
Dell 620 Battery Issues
Chances are pretty good that your battery just needs to be replaced. Over time all rechargeable batteries loose their ability to hold a charge. It's also possible, but less likely, that there could be an issue with your AC power adapter or the charging circuitry inside the laptop.
Best bet would be to find a similar laptop with a battery that does charge and switch. If the problem follows the battery then you need a new one.
Dec 19, 2007 | Dell Latitude D620 Notebook
Power on
u go to acer service center
lot of acer service center in all areas
Oct 22, 2007 | Acer Aspire 9500 Notebook
Dell Vostro 1000 Laptop Logo
106 people viewed this question
Alun Cox
