Question about Denon AVR-1100 Receiver
The subwoofer output has no signal on my Denon AVR110 Receiver
5 Suggested Answers
ttech
  • 139 Answers
SOURCE: connecting a PASSIVE subwoofer to the denon AVR-1507
Yes on B Connect Left+ Right+ Equals Mono And Turn on B Side with A
Posted on Jul 20, 2007
SOURCE: no HDMI video output from AVR-588 receiver to plasma TV ???
the avr-588 apparently cannot carry sound via hdmi - don't know why; just what i found out from the geek squad at best buy; solved the problem by connecting optical cable from cable box to receiver; be sure to change the input on the receiver for opt-2 (system setup >2 inputs) to correlate with tv
Posted on Feb 17, 2008
OnlyOneN
  • 86 Answers
SOURCE: Is there any way you can connect two subwwofers to this receiver?
Certainly... the easiest way is to purchase an RCA Y adapter to split the pre-out subwoofer connection to both subs.
Here's a link to what you need: (Best Buy)
http://tinyurl.com/ctp44j
This will not, however, give you a discrete left and right sub. You'll need a receiver with 7.2 capability to do that.
Make sure the phase is set the same on both subwoofers, or they'll cancel each other out and you'll end up with less bass than you had before with one sub.
If this answers your question, would you rate it for me?
Posted on Apr 20, 2009
hattonhall
  • 349 Answers
SOURCE: Subwoofer playing in stereo sound
When Stereo was the only "2 channel audio output" available. We never had Sub-Woofers and relied upon Bass and Treble controls to give an overall balance and Bass Depth to suit one's preference.
A Bass Sub-woofer is intrinsically part of a Multi-channel audio system. It is the " .1" part of the 2.1, 5.1, 6.1 sound system/s.
That is why you do not get Woofer Signal and thus output, unless you use more than just "Stereo Audio Amplification".
Posted on Oct 30, 2011
Subwoofer will not produce sound. Connections are correct. I do hear a hum or a crackel as I pull the connection on and off. AVR-689 model
In order to ensure output to your subwoofer: make sure the subwoofer is connected to the subwoofer out of your amplifier and make sure that your amplifier/receiver is set to output multi channel sound
May 07, 2011 | Denon AVR-689 Receiver
Conncet a sony sub to a denon reciver
Depending on the model, there are two ways to connect a subwoofer to an amplifier, receiver or processor. The best way is to connect the subwoofer to the SUB OUT or LFE output of a receiver, but some subwoofers can be connected to the speaker level outputs of the receiver or amplifier.
1. How to Connect a Subwoofer to the Subwoofer Output
The preferred method of connecting a subwoofer is through the LFE or Subwoofer output (SUB OUT) of a receiver. Almost all home theater receivers (or processors) and some stereo receivers have a subwoofer output. The LFE (Low Frequency Effects) is a special output for subwoofers and is often labeled 'SUBWOOFER' not LFE. 5.1 channel programs on DVD discs have a dedicated .1 channel output with bass-only content that is best reproduced by a subwoofer. Connect the output of the LFE or Subwoofer jack to the Line In jacks of the subwoofer using a single RCA cable (the two jacks on the left in the photo). A 'Y-Cable' may be necessary to connect the LFE output to both the left and right channels of the subwoofer.
2. How to Connect a Subwoofer to Speaker Level Outputs
Some receivers and amplifiers do not have an LFE or Subwoofer output. In this case you can use the speaker outputs of the receiver to connect the subwoofer. Using speaker wire, connect the left and right channel speaker outputs of the receiver to the left and right channel speaker level inputs on the subwoofer (the speaker inputs on the right side of the photo). Using speaker wire, connect the left and right channel speaker outputs on the back of the subwoofer to the left and right channel front speakers.
Hope it helped..
Apr 20, 2011 | Denon Audio Players & Recorders
My subwoofer output is not working properly. I have a sunfire signature that worked all the time. Now the power on the Sunfire will not come. Research says no signal from receiver. I swithed the...
You can prove the sub pre-output works by running an RCA cable from it to the input of a tape deck, TV or any other device that accepts Line In and will either display it or play it. Test it on VERY LOW volume at the receiving device.
Different sub pre-out cable?
Feb 11, 2011 | Denon AVR-4800 Receiver
My subwoofer is connected correctly (test mode it works fine). The Denon 589 receiver, however, when everything is set up and ready to go, doesnt seem to send any output to it, so there is no base sound. ...
What's the make and model of the subwoofer? It sounds like it's a passive (unpowered) speaker.
http://www.retrevo.com/support/Denon-AVR-589-Receivers-manual/id/23110dj893/t/2/
See page 9
I seriously doubt your test mode worked fine on the subwoofer level adjustmnent.
Get a powered (active) sub.
Jan 18, 2011 | Denon AVR-589 Receiver
My Denon AVR-1709 was professionally installed. It lasted less than 2 years, then the speakers started popping, then a few days later there is no signal to any of the 5 speakers or subwoofer. same for all...
This is a case where the audio output ic's have failed, you describe a popping sound which is a classic sign of total audio collapse. Since this was a professional installation, I recommend a top of the line audio technician with an estimate in mind.
Jan 07, 2011 | Denon AVR-1709 Receiver
I have a velodyne VA 806 subwoofer which I would like to connect to my AV receiver Denon AVR 391. In my receiver, I have a subwoofer out female connector (one) and where do I connect this line to the...
Get an RCA Y-adapter to feed both INputs on the sub. Define the sub in the Denon and set your other speaker settings as required to redirect the bass/LFE if they can't handle it.
Dec 23, 2010 | Audio Players & Recorders
I just purchased a . Samsung 50
No, you would be better off sending the video signal from your sources(satellite,digital cable,DVD,BluRay player,any digital HD source,etc.)directly to your Samsung TV, and then use the fiber optic output from the TV to transfer the audio signal to your Denon receiver, or another way is to send all video signal to your TV and send all audio signal to your Denon receiver seperately, keep in mind that there really isn't a good reason to send video into a Denon receiver, that processes sound not picture! Good Luck !
Jan 05, 2010 | Denon AVR-3805 Receiver
No sound from Sub.... from my Denon AVR-2700, not AVR-3300, Yeah its old!
if the subwoofer is on in the reciecer settings then maybe the amp is not getting the signal or the amp is not amplifying
try unplugging the output of the sub then turn off the reciever for a min. then turn it on wait , then plug the sub in
if that don't work then test the sub output with a stereo that has a audio input
also test the subwoofer with a audio output to it( only a positive and a negitive wire for sub)
Oct 26, 2008 | Denon AVR-3300 Receiver
No subwoofer signal
your out put signal circut bord is shorted out. It happens when there is static feed back from output continuity to an electric overload inside the unit. Then when you have a shorted board then it will eventually go into a protect mode and nothing will work ...just the power light will turn red and blink.
Just a suggestion.....Get rid of it while it has a bad sub output signal. you can get some money out of it.
I can always use extra parts for the other denons I work on....call me if you want...630-742-6587
Rick
Jul 07, 2008 | Denon AVR-1705 Receiver
i think uyou have to got to stereo mode and turn ion the subwoofer option. i have a h/k thats wart i had to do in evvery mode is designate the s/w. rating please
Jan 24, 2008 | Denon AVR-1907 Receiver
Denon AVR-1100 Receiver Logo
205 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
