Msi cr610 flickering screen when on the net had laptop back twice for repair to argos people
Have the same laptop and also had same problem.
Solved problem by downloading latest graphic driver, no trouble since.
Good luck.
Posted on Oct 31, 2010
Msi wind broken dc power connector port
1) http://www.bit-tech.net/hardware/laptops/2008/07/05/breaking-wind/1
2) http://www.radioshack.com/product/index.jsp?productId=2103245
3) http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
[You don't need a Soldering Station though. Use a 25 Watt soldering iron, or so. Rosin core solder, Rosin flux paste, etc ]
4) http://laptopjacks.com/product/MSI-Laptop-DC-Power-Jacks.html
So, who is going to do the job?
Post back in a Comment.
Regards,
joecoolvette
Mar 14, 2013 | MSI Wind U100 Netbook
I have a MSI CX420 laptop with 320GB hard disk, can i replace the 320GB hard disk to 640GB toshiba hard disk?
Hi znehbeurt_12
Yes you can replace your 320 for a 640 hd....
It will partition itself at the start when you install your operating system
Please rate me
Bud
Sep 25, 2012 | MSI 500GB Hard Drive for CR400, CR410,...
Msi laptop screen flicker
The flicker is more than likely caused by the built in backlight, behind the LCD display.
Jun 16, 2012 | MSI A4000068US PC Notebook
Where can i buy an msi CR610 motherboard for my laptop please
honestly it will be hard to get a motherboard for a MSI laptop
You should check Ebay often but its hard for a MSI to be spare parts
Jun 07, 2011 | MSI Computers & Internet
I have an msi cr610 laptop can you give me the serial number of the motherboard which needs replacing
under your laptop there is written S/N and Model: S/N its your serial number, .
Jun 03, 2011 | Intel Motherboard
The screen of my msi notebook u100 turned white after turned it on.. before that happened, a small portion of the screen flickers which results to minimal distortion in display.. for example, the fine...
exactly the same for me, I turned it on recently, and the screen is just plain white? Do i need to send it in for repairs? or is there a way to solve this problem, please reply A.S.A.P!!!!!!!!!!!?
Aug 04, 2010 | MSI WIND U100 Notebook
Msi cr400 screen flicker problem
There is a big difference between hibernate and sleep mode. One will not wake just by opening the lid. You can get a full answer from this web site:
http://www.mydigitallife.info/2007/10/12/what-is-the-differences-between-sleep-standby-and-hibernate-in-vista/
I suggest visiting that site for a full explanation. It just might be the answer for which you are searching.
Good luck,
-a.
Jul 23, 2010 | Computers & Internet
My screen is dark
You could have a defective LCD screen, If the laptop appears to be running and the hard disk is spinning but the screen is dark then, to determine if you have a LCD screen or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jun 21, 2009 | MSI M670 Notebook
My Gateway mx7118 lcd flickers whenever screen is opened,closed,
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the laptop's LCD screen it means you have a backlight problem.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 13, 2009 | Gateway MX7118 Notebook
Acer screen flickers all the time and looks dark
2 years are nthing, surely get it repaired mine is 10 years old and i had the same problem twice and repaired it, its alomst costless.
Jan 11, 2009 | Acer Aspire 5100 Notebook
Computers & Internet Logo
294 people viewed this question
David Payne
David Payne
