Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
What's a good temp. setting for the food/beverage section
  • Frigidaire Master
  • 43,501 Answers
If you set the temperature below about 37 you run the risk of somethings freezing...but milk should be as close to 40 as possible, so I usually recommend a setting of about 39.
heatman101
Posted on Sep 27, 2010
Have replaced the main control board, and all the control panel lights now work, compressor comes on, fan inside comes on, but fan at bottom of refrig does not. Checked all connections and all is good....
Set you refrigerator controls at their middle settings. Put a thermometer in both sections. Check after several hrs. Freezer temp should read near 0 and fresh food temp between 38 and 42 degrees. Those are normal operating temps on most refrigerators.
Mar 06, 2015 | Refrigerators
GE Profile pss26mgpa. Food keeps freezing no matter the temp setting
Set the temp to the lowest setting and see if the damper is closed and not letting air into the food section. If it is, then you will need to replace the damper. Here is that part to order.
Jan 19, 2013 | Refrigerators
What should the temp be for freezer and refrigerator?
dont know model, do know temps. The fridges highest temp is 5deg c, preferably between 1 and 4, if freezer goes above minus(-)18deg c your are in danger zone, there should be a regulator control in the fridge, usually on left or right hand side near front(door)
Jan 25, 2012 | Kenmore Refrigerators
I have a Bev Air MT-27 cooler for home use. Is it possible to have it rewired so it functions more like a refrigerator so the fan doesn't run 24/7? And if that isn't possible, could I use a timer so that...
On commercial coolers, the fans are designed to run 24/7 to prevent the coils from freezing up. If the unit only runs 4 times a day, it will not maintain proper temps. Domestic units utilize the freezer compartment air to keep the refrigerator section at temp. Totally different set ups. I wouldn't do what you are suggesting with a commercial unit.
Nov 23, 2010 | Beverage-Air MT27 Beverage Cooler...
Fridge not keeping temp. goes from 30 degrees up to 65 and back down again at random. losing food. help
I would investigate the thermostat first. It sounds like the most likely place to start based on the symtom
Sep 06, 2010 | Carrier Beverage-Air UR30GEFD Beverage...
Hotpoint fridge freezer freezer ok but fridge not working temp is always 21 degrees tried to set to 4 degrees but just keeps going to 21 freezer is fine -22 degrees
Merv -
Most manufacturer's fridges are designed for 34 degrees F in the fresh food compartment and 0 degrees F in the freezer compartment. Setting the fresh food compartment to a value lower than 32 degrees will freeze any moisture in foods, fruits and vegetables and freeze water in juices and other beverages resulting in broken containers, exploding cans, etc.
What you need is another freezer. Trying to convert a refrigerator into a freezer is going to be very difficult - especially without ruining it.
Aug 09, 2010 | Hotpoint Refrigerators
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
Freezer does not get as cold as the setting made but refrigerator
If the unit is working correctly, it could be that you are trying to adjust the freezer with the wrong knob. The fresh food section is cooled by forced air from the freezer and can get about as cold as the freezer if not adjusted correctly. The thermostat its self controls only the temp in the freezer. Some times telling which is which is confusing. Here is the best way to tell the difference.
The knob that will turn the unit off is the thermostat. The other one controls how much air can be forced into the fresh food section. The thermostat should be adjusted to where the freezer stays around -10 degrees. The other knob should be set so the the fresh food section stays between 35 and 38 degrees. If this does not help or if you find that there is indeed a problem with you unit, please get back with me and I'll be glade to walk you through diagnosing the problem.
Please post a rating if solution is helpful. Thanks
Aug 21, 2009 | GE Profile Arctica Stainless Steel Top...
Appliaance shuts off at low temperatures
Most refrigerators cycle on and off based on the fresh foods temp. If the ambient temp is 10C and you have it set for 4C, the unit does not have to run much to satisfy the temperature control, and the temp in the freezer section will warm to + C range. (likewise, if the ambient drops to -C range, it won't mater if you set the fresh food section to +4C, it won't heat the air, and the fresh food section will eventually reach the -C ambient temp.) The only solution is to move the appliance to a warmer location or heat the room it is in. This is the only Fix-Ya for your refrigerator.
Jan 03, 2009 | Refrigerators
Zanussi zx99/5 freezer working fine but my fridge is too warm
This may be an airflow problem. These are things to check. Make sure the temp control in the fresh food section for both the freezer and the fresh food is set half way between coldest and warmest temp setting. Over adjusting these settings can cause poor air circulation and make the fresh food section too warm. When openning the freezer, the evaporator fan should be on or start shortly. If the evaporator fan stops working, there will be no circulation to cool the fresh food section and will need to be checked to see if it is bad. If bad it will need to be replaced. The evaporator in the freezer section may be iced over causing poor air flow to the fresh food section. You may need a service tech to check this part. If the evaporator is iced over, stopping air circulation, the button thermostat or defrost element may on the evaporator may be bad and could possibly reqiure a technician to replace it Check the first two things and let me know what you find and how it is doing after reseting the temp control. I will be happy to help you in any way I can..
Nov 10, 2008 | Zanussi Refrigerators
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
253 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
