Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
My Lawnboy mower runs great one weekend and then the next weekend I have to struggle to get it going. At this time it doesn't even act if it wants to start. Any ideas
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 338 Answers
If the problem is not the proximity switch it is most likely in the fuel system. In such a case I would take the machine to a dealer like www.arcolawn.com and get the machine looked at to see if warranty.
Good luck
Posted on Mar 01, 2011
What is wrong with my push mower?
Sounds like something relating to the engine is overheating and the heat sensor switches off the machine.
Jun 18, 2014 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
Lawnboy 10665 won't self-propel and impossible to push
If you have the smell of rubber burning the belt isn't gripping. Make sure that there isn't anything stopping the wheels turning like old grass or even a piece of twig. If their clear try adjusting the tension on the drive pully.
Jun 28, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
Lawn mower will only run if you keep primer button going
Collect your model and serial numbers and look up a carburetor kit at a dealer site like www.arcolawn.com. clean the carburetor and you will be up and running in no time.
Oct 18, 2010 | Toro 89885 "lawnboy" Premium 4cycle Oil...
Rough low throttle on Lawnboy Dura Force Pro 6.5
IT HAS A WEAK SPRING THATS ALL IT IS
Sep 28, 2009 | Garden
Lawnmower throttles up and down
locate the carberator the unscrew the 1/2' bolt under the float bowl to remove the bowl empty and clean out the bowl reinstall making sure the o-ring is centered for the bowl it acts as a sealing ring for the bowl screw the bolt back in and tighten, this should solve the surging problem.
Sep 12, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
I have a 1987 commercial lawnboy walk behind mower that has stopped running. I gradually lost power over the summer and now it will not start. I have installed a new plug and filter earlier in the spring....
I would try and remove carb and clean it thuroughly. You can soak the parts in solvent or equivelant. The carb would be right after the air filter tube to the intake of engine.
Aug 25, 2009 | Garden
I would push the prime button 3 or 4 times it starts then quiet
I took my carburetor off and blew it out with compressed air. Runs great now. Make sure to get all of it. Little screw on bottom has a hole in it too!
Apr 18, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Lawnboy F series Engine - how to remove PLATE AND COLLAR ASM
shaft is tapered plate just slides up on shaft, tap with hammer several times if want break loose,sometimes moisture has rusted it or excess heat has swelled it on tight, i had to take a drimel tool will cutting disk to remove mine,then clean up shaft with file or sandpaper to smooth,little grease an new collar ready for blade.
Apr 12, 2009 | Garden
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
164 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
itsman
Rick Oudette
Rick Oudette
Level 1 Expert
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
