Question about Reliance Water Heaters
The water does not heat, or does not stay hot for long, however if I turn the breaker off and then right back on again it will start to heat. It is a Reliance 501 electric water heater, it has worked great for aprox. 15 years.
  • Reliance Master
  • 43,501 Answers
This sounds like a bad electrical connection internally in the heater...
With a heater of this age, I would replace it...
heatman101
Posted on Sep 27, 2010
The light on my power star tankless hot water heater will not stay on and i do not have hot water
look at breakers, there is two sets one in unit and one in breaker box. check presure to unit need 95 pis to set relay for heat, some have adjustment for this
Jan 03, 2018 | Water Water Heaters
My water will be turned off for an hour. Do I need to shut my breaker off to my electric water heater??
There is some ambiguity in your statement. To be safe, it is a good idea to turn the breaker off to an electric hot water tank. However, to give a technical answer; if there is no draw on the system, then the tank will remain full of water, so no damage to the heating element will occur. Again, to be safe, you will certainly do no harm in turning the breaker off.
Oct 31, 2014 | Water Heaters
Rheem 50 gallon Electric Water Heater 81V52D C repair ideas needed
It could be element shorted to ground through steel tank, so don't touch tank when breaker is ON.
Or you have undersized 12 gauge wire and 20 amp breaker and the heat has loosened breaker on the busbar. Breaker trips when heat exceeds breaker limit. Jiggle breaker and listen for crackling sound.
To restore hot water now:
Turn off circuit breaker, and open top cover then Push in reset button on top of heater to restore functionality. Put back insulation and factory cover.
To fix water heater: test and replace bad element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
If problems continue
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
http://waterheatertimer.org/Troubleshoot-household-electricity.html
Sep 25, 2012 | Rheem 81V52D Water Heaters FOR 220 VOLTS
I have a 50 gallon electric water heater..trying to fix a leak elsewhere in the house we had to shut off main valve,turned back on no hot water,,reset breaker and reset button worked fine,but no today no...
If you're having to reset the breaker, then most likely you have a bad heating element. Usually the bottom element burns out first, however if you had the water off, and the level dropped in the tank, the heater might have come on without water in it. This will cause it to overheat and burn out. Now when you turn the breaker on, the current is going to ground, tripping the breaker. If you are handy you can replace them, but be sure water heater electric is off or disconnected, and then drain water below the element level. While you're replacing one element replace them both.
Oct 13, 2010 | Whirlpool Water Heaters
Water heater not working after turning up heat
Did you turn the breaker completely off, then back on? When a breaker trips it is in a middle position, and nust be turned off to reset it, then it can be turned back on.
Mar 14, 2010 | Stiebel Eltron TEMPRA 24 Tankless Water...
Stiebel Eltron tankless 24. Problem:No hot water.Tempature display dead.Single LED on right side comes on when cold water flows thru system.Have cleaned fine mesh input filter.No pressure problems. CCt...
Take off front cover, on the top of the two cylinders in there (the heating system) there will be a small red button. That is the Safety Thermal Cut out, depress that red button. It is similar to a circuit breaker. If the red LED comes on when you turn on hot water at a sink then that was the problem. I have on that trips periodically. Its annoying but not enough to replace the part yet. Good luck.
Oct 11, 2009 | Stiebel Eltron TEMPRA 24 Tankless Water...
Kenmore Electric Water Heater/ Economizer 6
it usaly takes a few hours to heat up depending on water size check our breaker to see if it tripped out make sure all your wire connections are good u could take the front plate off and hit reset if you dont get hot water in a few hours ull probibly have to replace the trermostats and maby the elements its not hard to do good luck
Mar 06, 2009 | General Electric GE SmartWater Household...
Water Heaters Logo
170 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
