Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Over door locked won't open. F9 error code. Frigidaire.
    President:
  • 1,932 Answers
The "F9" error code means the EOC (electronic oven control) has found the lock motor switches to be out of sequence or shorted.
Test switches and if there is nothing wrong then replace the EOC.
Thank You
Posted on Sep 27, 2010
F9 still appears after unplunging and replug
Hi Don, this is Z. Thank you for your post!
If you are receiving error code F9, it typically indicates that the maximum oven door unlock time has exceeded. If resetting the power did not clear the error code, it would be advisable to contact an experienced appliance repair tech to assist further since your range may possibly have a communication error with the EOC (Electronic Oven Control), lock motor assembly, door light switch or door latch assembly. Hope this helps!
Jul 19, 2014 | Frigidaire Ovens
My frigidaire oven wont stop beeping and it has a f9 code
Hi
F9 is a door lock error and to solve this issue you can hold the light switch for 15 seconds, this will reset the control. If it won't work then hold the light switch in and set the unit to clean and after a minute press cancel to cancel the clean cycle. If still it won't work then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 24, 2011 | Frigidaire FEB27S5A Electric Single Oven
Code f9 on frigidaire self cleaning oven. what does it mean. i went to clean the oven and the door locked and the code f9 came up and keeps beeping. i unplugged the stove for 1/2 hour and plugged it...
Hi
Thanks for using FixYa. F9 error in your oven/range indicates an issue with the door locks assembly and/or the door latch. To start with check the door lock circuit, you can also try to jump start it to see if it's working. If it's not working then the Electronic Range control has gone bad and should be replaced, if it is working then the door lock circuit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 15, 2010 | Frigidaire Ovens
F9 Flashing on Frigidaire 30" range
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
Dec 31, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire electric drop in oven has blinking door locked light on. F9 error message. Tried to self clean, oven never got hot, door locked and can't get open. Been 2 days. Self clean light will not come...
http://b2b.frigidaire.com/support/manuals.asp
this is a free download site from frigedaire if you have your model number you can download your complete manuel i was unable to find the F9 code for an oven
but suspect it has to do with door lock switchs if you can download your manuel from site it may help you can try shutting off breaker for oven and see if it will reset
good luck ron
Dec 11, 2009 | Ovens
Oven door locked.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!$%!!!%!%
Oct 26, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
F9 code comes on frigidaire stove when self clean operation starts, i cleaned around door lock, what should i do next
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!#!#!#
Oct 13, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven f9 code
Here's the info from the service manual:
"Fault Code: F9
Likely Failure Condition/Cause:
1. Door motor failure / jammed. Latch
motor switch failure.
2. Control software failure, or component
failure (relay stuck).
3. Wiring Problem.
Suggested Corrective Action:
1. Press CLEAR key.
2. If CLEAR key does not eliminate problem, turn off power for
30 seconds, then turn on power.
3. Check wiring of Lock Motor, and Lock Switch A and Door
Switch circuits.
4. Unplug P4, apply power (L1) directly to the Lock Motor, if the
motor does not rotate, replace Lock Motor Assembly. Plug
P4.
5. Check Lock Switch A for proper operation (do they open and
close, check with ohmmeter). The Lock Motor may be
powered as in above step to open and close Lock Switch. If
the Lock Switch is defective, replace Motor Lock Assembly.
6. If all above steps fail to correct situation, replace control."
- www.fixyourboard.com
Jul 25, 2009 | Frigidaire FEB30S5D Electric Single Oven
Self Cleaning problem
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question)(*&^%
Oct 21, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Self Cleaning error F9
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
371 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
