Question about Denon 3910 Progressive Scan DVD Player
CODE 54 - Denon 3910 Progressive Scan DVD Player
  • 10,421 Answers
I'm working on the 2004 Jeep Grand Cherokee 4.7 showing error codes
lashes 52 and 54 ,you do mean flashes ? What flashes ? Check engine light doesn't flash codes .
Apr 24, 2017 | Jeep Cars & Trucks
Paint code for vw golf sdi mk5 54 plate
On the boot floor or in the front of the service record you will find a data sticker the paint code is on that sticker.
Oct 19, 2014 | Volkswagen Golf Cars & Trucks
What this cdes maen36/46/53/54
code 36 air switch solenoid circuit non turbo or wastegate solenoid circuit on turbocharged models.
code 46 battery voltage too high. code 53 module internal problem SMEC SBEC failure internal engine controller fault condition detected. code 54 problem with the distributor synchronizer circuit.
Jul 15, 2013 | 1991 Chrysler LeBaron
Got a 1997 Dodge Grand Caravan w/3.3L V-6. Computer threw codes 12, 54 and 55. i am a 26 yr vet of Chrysler parts and been removed from it for over 7 years. Can you enlighten me on what needs to be done...
ok code 12 is start code and 55 is end code they will always be there but code 54 refers to cam shaft sensor no continuity check wiring at sensor if looks ok replace sensor does the van run if so how well no power misfire stalling let me know like to make a note of the symptoms for code 54 for my records thank you hope this helps you
Jan 15, 2011 | Dodge Grand Caravan Cars & Trucks
I did a diagnostic check and it came out with codes 12 13 and 54. What do I need to do to get my truck back up and running?
code 12 means the battery was disconnected within the last 50 key cycles. ignore this code. code 13 means no change in map reading and the baro reading at start up. check for vacuum line break or loose connection. If vacuum lines are ok, replace the map sensor if the codes still exists after the code 54. Code 54 is no fuel sync to the pcm. Replace the camshaft sensor under the cap, then when the vehicle is running, check and see if code 13 is still there (erase the codes first).
Jan 11, 2011 | 1995 Jeep Grand Cherokee
WONT START WHEN COLD CRANKS FINE. HAS CODE 54 CAM
ok, any obd code means the sensor concerned is not detected by the ecu, or is way out of range of the normal signal the ecu expects. I would therefor check the electrical path between the sensor and the ecu terminals, it may be just a chafed cable or wire.
Jan 14, 2010 | 1997 Dodge Caravan
Eurovox codes 54 01 needed for 2/11/2008
Make sure u get the rite NTL codes
These codes are from the 4th of December. nt the 2nd as u reuested. have changed sinc :)
LATEST KEYS ALL AREAS
EX C&W KEYS -- KEYROLL 04/12/2008
PROVIDER CODE: 5C 01
KEY 00 = D4 A3 5D EB 7B F3 69 59
KEY 01 = 27 77 A1 FC 8F 9D 34 76
TELEWEST KEYS -- KEYROLL 04/12/2008
PROVIDER CODE: 5A 01
KEY 00 = C0 F6 61 87 91 F9 67 57
KEY 01 = F0 83 35 E5 28 40 49 B2
PURE NTL KEYS (UK) -- KEYROLL 04/12/2008
PROVIDER CODE: 54 01
KEY 00 = 3F B8 36 62 72 E5 E2 76
KEY 01 = 35 5E D6 40 6E AA 99 41
IRELAND CHORUS KEYS -- KEYROLL 29/06/2008
PROVIDER CODE: 5E 01
KEY 00 = 51 0F 32 A7 D9 34 BE 3E
KEY 01 = 8D A3 88 1B 4E 32 C5 8F
IRELAND NTL KEYS -- KEYROLL 18/06/2008
KEY 00 = 75 92 B1 CC 6F 23 20 F1
KEY 01 = F2 46 B1 59 04 61 77 71
Dec 02, 2008 | Euro-Pro 534DX Mechanical Sewing Machine
Trouble code 54 on a 1995 Jeep Grand Cherokee
Carb'ed Engines:
Code 54 - Mixture Control (MC) solenoid is shorted or the ECM is faulty.
Fuel Injected Engines:
Code 54 - Camshaft (or distributor sync.) reference circuit - No camshaft position sensor signal detected during engine rotation.
Hope this helps
Mike
Jul 02, 2008 | 1995 Jeep Grand Cherokee
Agk 101-54 code
i need the code to synchronize my philips freeview box with my agk universal remote modal 101-54
May 13, 2008 | Directed 434MHZ Remote Control
Denon 3910 Progressive Scan DVD Player Logo
63 people viewed this question
Top Denon Televison & Video Experts
Jonathon summesfield
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
