When i connect my headset, the sound come from both headset and speakers and my mic is not working
    Brigadier General:
  • 10,406 Answers
When you insert the headphone jack into the "audio-output" jack,
which should be GREEN coloured, it should mechanically disable the built-in speakers. If that does not happen, you're connecting it to the wrong socket.
Be sure to insert the microphone's jack into the PINK socket, which is the "microphone-input" socket.
Posted on Sep 27, 2010
My headset is not wireless. the built-in mic isnt working
Did you check it is inserted in the Mic socket and not Auxillary Inout which is the other socket on the back of your computer?
Also go to Control Panel/Sound and check that the settings don't have the microphone Muted. You can sometimes get to this location quicker if you have the speaker icon down on the right side of the screen by the clock. Just double click it.
Dec 15, 2015 | Radio Communications
Skype not working
Sir,
Click this link for more information........
http://support.skype.com/index.php?_a=knowledgebase&_j=questiondetails&_i=35
Also Check........
On a PC with external speakers and also a headset with microphone. Windows XP is configured so that standard audio are external speakers and standard microphone is the headset. Skype is configured to use the headset for audio in and out.
This way one can listen to sound from the PC and from MP3 players through external speakers and if there is a call to make or take, this is going through the headset.
But now there is the problem that the noise level for the headset is too low. Increasing volume has no effect on the headset, it only affects the external speaker's volume.
Now the solution: Going to the control panel and opening the sound setting, go to the audio tab. The external speakers are selected as default. Just temporarily select the headset and then click on volume just below. You can now set the volume for the headset, click OK and click cancel (!!!) on the sound control dialog box. This way the external speakers remain as default output.
Skype-->Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
You can also tick the ring pc speaker check box as this is a good backup to alert you even
if the main speakers are off or turned down.
Windows:
Start-->Control panel-->Sound and Audio devices
On the audio tab set the default playback device to your main soundcard(AC97/Audio-chip/add-on-adapter), etc.
Your installed audio device must be present there.
If not, reinstall audio device
thanks
good luck
Oct 29, 2008 | Altec Lansing Stereo Headset with...
I have trouble connecting my headset to the mac. I don't know which wire goes to which plugin, and when I do connect it, no sound comes from my computer. And yes, I made sure the volume is up. May I...
GENERALLY... ONE jack goes to AUDIO or SPEAKER... the second goes to MIC INPUT or something similar...
SO ONLY ONEjack should give you AUDIO from your headset is your MIC !
THIS Link MAY help you! "I" had to convert it to English ! Thank you "Chrome". At least you can glean some HELP telephone numbers...
https://www.logitech.com/assets/46742/3/usb-headset-h390.pdf
Dec 23, 2017 | Logitech ClearChat Stereo Headset Headset
My speaker stopped working after some time!
may be problem in lose wire connection ,
check that first.
may be there is a problem in mic from where u talk,
open the mic cover smoothly,check all the wires are joint if not join it properlt,
still problem take off ur mic and check with speaker or with other equpiment like ur mobile headset,if mic is ok then put back, if not do *
join wires again properly,next
open joiner where the speaker and mic are joined,may be there are some wire disconnection join it ,if properly joined,
* then there is a problem in mic
replace the mic with same type of mie or u can use the mic of ur mobile head set or find it someware ,
join it ploperly.
it works.
goodluck
email rushi_jky@yahoo.com
Apr 28, 2010 | Cyber Acoustics AC401 Consumer Headset
Headset Problem Rosetta Stone
I found the answer. Rosetta Stone has a problem detecting the mics if the speaker input is not in someway connected to the mic. I'm not exactly sure how it works, but I don't care and neither should you.
Follow these steps each time you want to use it and you should be fine.
*I'm on Vista, but this should work for every one.
1. Open Control Panel
2. Open Hardware and Sound
3.Open Sound
4.Set Line 1 as your Default Speaker
5. Refresh the Mic list
*All of your mics should now show up.
6. In Rosetta Stone, apply the mic you want and finish the setup.
7.Start whatever language you're using and switch back to the Sound menu.
8.Set whatever speaker you want to use as default.
*Rosetta Stone will continue to work fine until you close it, switch Users, or remove the mic.
In short you have to set the default speaker to LINE 1 to get the mics to appear. Then when you apply the settings switch the default speaker back.
Dec 27, 2008 | Rosetta Stone Chinese Mandarin Level I &...
Jabra bluetooth adapter A210
hi,
you have to connect the jabra audio jack to the audio source, to the speaker output of your receiver for example. If jabra detects the source it will work. If you cut the connection, jabra watch for a while if something happend and than stops the transmittion. Hope that helps
Oct 26, 2008 | LG Jabra A210 Bluetooth Adapter for...
Headset
You use headsets to have conversations over the internet .. or to have a personalised audio equipment,.
You should have used the mic to start with, as you heard over the speaker your voice,
There are two pins. One for MIc and other for the headphones.
Use mic only when recording. other times keep it muted in control panel-> sound and audio...
you can use headphone for hearing when you don want the audio stream to be on speakers., TO use so, you have to take of the output from the CPU to the headphone pin after removing the speaker pin or configuring the audio controls control panel-> sound effect manager to have sound always in both theh speakers and headphones.
This requires you to have an appropriate configuration so that all 3 pins are aptly placed fot output from the CPU.
Hope you got what you asked for!
Apr 12, 2008 | Labtec C-322 Headset
Sx66 cant hear people and they cant hear me
i encountered this problem after i started using a bluetooth headset. when the headset is not in use (not turned on, not even with me), sometimes there is no sound from the speaker, and the other party cannot hear me. meanwhile, the call timer is clicking away indicating the call connected. it seemed there was some issue in the bluetooth stack, and the phone thought it should be communicating with the BT device rather than it's onboard speaker/mic. to resolve, i disconnect the call, go to the main screen; in the bottom right corner, use the bluetooth manager icon to turn BT On then Off again. this resets the phone's speaker/mic usage, and calls can be made like normal. i hope this helps you.
Jan 07, 2008 | Siemens SX66
I get no sound and my my microphone doesnt work.
man this is all **** i got same problem no one knows how to fix !!!
Jul 22, 2007 | Logitech 250 Headset
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
