Question about Maytag Neptune MDG5500AW Gas Dryer
Why is the control panel warm when not running on the mdg5500?
  • Maytag Master
  • 17,130 Answers
If there are no issues of fault on the dryer then there is no immediate concern but the warm board can be because the power supply is on and the regulator and supply components are heating up.
If there is no malfunction and it is only warm, then ignore the whole issue.
Posted on Sep 27, 2010
  • jimbilodeau Sep 28, 2010
    But.... Why should anything be powered up if the last cycle has completed. Heat means power consumption, and I don`t want to waste elect. plus I am concerned with the potential of fire seeing that the gas line runs right behind the panel.
My maytag mdg5500 dryer isnt heating up. It all works but no heat.
Thier are several things that could cause a gas dryer to not heat, i have written a tip covering the most common ones http://www1.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Oct 11, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Profile GE PS123Sc about 6-7 yrs old. Freezer side seems fine. Fridge side is too warm, but is cooling (about 40F). Fridge side lights are intermittent and control panel at top is intermittently dark or...
Sounds like a bad motherboard and probley need control board. You can put in self dianoss. Press all the buttons on panel for 5 seconds. This will start the program. It will check all sensors. Come back with codes and I will help you. Wait to hear from you. I hopes this helps. david_gra582
Aug 27, 2011 | GE Profile PSS26NGS Side by Side...
Maytag neptune Model # mdg5500 AWW when i push
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 10, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Built in oven front panel gets too hot
No. There should be a fan that runs and blows cool air from a gap at the top of the door and over the controls.
Feb 15, 2010 | Ovens
Water spilled down the stove top causing the oven
ater spilled (4-5 cups) on the stove top running down into the stove control panel face (where you view oven temp, timer, etc). No water ever dripped into the oven or oven window. The stove top still works but the oven, warming drawer, clock are all non responsive after three days. No buttons on the control panel work at all. What repair is needed?
Jan 06, 2010 | KitchenAid KDRS807SSS Dual Fuel (Electric...
The fan is running and blowing air but the inside is at 52degrees. I unplugged the unit for a half hour and then plugged it back in to see if this workes. So far no luck . any ideas?
With unit running,
There are two areas to look at, the back behind the removable panel to see iif the compressor is running(you can put your hand on it, it should be warm to very warm) If it is cold you have a electrical control problem, thermostat or control board on the newer stuff, If the compressor is running you may have a freon leak or other sealed system problem.
If the back of the freezer panel on the inside was snowed up you have a defrost problem. Don't know if this helps much, but it is in general what needs to be looked at........
Dec 27, 2009 | Whirlpool ED2FHSS Side by Side...
Replace maytag belt, how to disassemble maytag dryer
The link to the Service Manual is below. The pages related to belt replacement are pages 6-3 and 6-4. Be sure to pull plug before attempting disassembly. Good Luck:
MDG5500 Service Manual
Sep 01, 2009 | Maytag Neptune MDG5500AW Gas Dryer
After use, fan keeps running and control panel not working
Hi, this is a major chip fault. this chip is located on the control board and, it is responsible for initiating the cooking cycle correctly. you will need to replace the control board asap. it has failed.
Jun 19, 2009 | Kenmore Microwave Ovens
Pilot Lighting for Neptune Dryer
there is an electric igniter but no pilot light in the Maytag 5500 gas dryer. you can change it yourself.. let me know
Aug 23, 2007 | Kenmore 67082 Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
51 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
