We have a samsung lcd tv we do not have cable right now but have an antenna however we are unable to get abc, how can I fix this?
  • 130 Answers
Hi
there is no way to get ABC they do not transmit any more on the air you will have to get cable witch you should do to get the best result from your tv
Posted on Sep 27, 2010
My ABC TV reception became bad two weeks ago with the pictures and!sound breaking up. All other stations were fine. Tonight ABC ceased to operate at all and the no signal sign is displayed.
Not enough information to assist on this. Using a cable provider or over the air (antenna)? If it a provider, call the cable company, ABC may not have renew a contract with the provider..
Nov 07, 2017 | Televison & Video
I AM UNABLE TO CONNECT USB ON MY SAMSUNG LCD TV MODEL NO.LA40D503F7R
you need to switch the input to USB from antenna or cable probably
Sep 14, 2015 | Samsung LA40D503F7R 40 Full HD 1080P...
I have a venturer 19" digital lcd tv -PLV36199S1. Removed cable and brought an antenna. How do I add channels? Can not get ABC and CW
go to the menu button of the tv screen, and proceed to the input signal: u will see air and cable..go to air and scan it first. It should immediately pop up all the channels in your screen depending on the signal strength pulling through the antenna. Repeat the process as needed.
Oct 04, 2014 | Televison & Video
Samsung lcd tv problems
TV IS OK RETUNE THE SET TUNUNG CABLE CHANALS DIGITAL AND ANALOGUE IT IS ON SET UP MANU
Sep 07, 2014 | Samsung Televison & Video
I just bought a m221nv from ebay tv dealer an he said i could jus plug it in in my kitchen, bedrm or ? and watch it via my router cause it has wifi no need connect cable, antenna or anything but i cant get...
The wifi connection will allow you to access content via the Vizio Internet Apps (Netflix for example) but not tv broadcasts.
Your tv can access tv broadcasts (CBS, NBC, FOX, ABC) over the air but w/o an external antenna the signal and therefore the quality will probably be weak.
To access cable/direct tv/fios content you will need to connect the tv via a cable.
Mar 01, 2011 | Vizio M221NV 22 in. HDTV LCD TV
Two Samsung LA40A450's, purchased within days of eachother, located in two different houses. Last few weeks both families get no sound when switching channels to ABC. Have to reselect ABC maybe a couple...
If you are receiving the signal from the same cable service provider rather than through an antenna, I would suspect the cable service is having a problem with its retransmission of the ABC channel in that suburb. I don't know if Australia is still broadcasting analog TV signals or if ABC is digital, but if the latter, perhaps the receivers are having trouble decoding the sound format identifier information. This could be something as subtle as a timing tolerance issue or as crude as noise or low signal level on the cable that has the receivers operating at the margin of sensitivity.
Oct 23, 2010 | Samsung LA40A450 40 in. LCD TV
Jerky video on antenna feed of ABC network programming
You didn't say so but I believe the TV you're using that having the problem is a TV that uses motion compensating frame interpolating technology... a common feature with 120hz and 240hz LCD TVs. I have one of these types of TVs and I have this issue with ABC as well. ABC has begun dropping video frames from some of their primetime shows (the ones that start at the 8e/7c time slot seem most effected) to speed up the broadcast to a point where they can get an extra commercial in. On normal TVs, including the older 60hz LCDs, this is not really noticeable. However, for the motion compensating frame interpolating technology, the TV's video processor must sync up with the 'telecine' processing (conversion from the originally filmed 24fps to broadcast 60fps) so that it can eliminate the copied frames that the telecine processing produces before it can create the interpolated frames between the original frames. When the TV's processor hits a missing frame, it loses sync and has to rejoin and causes the jerky motion you're seeing.
For a solution, you can turn off the motion compensating frame interpolation tech on your TV. Each manufacturer calls it something different but the name will have something to do with smoothing out motion like 'Smooth Motion'. In this case, you need it off for the motion to be it's smoothest (not the case with most TV though).
For a better solution, send a complaint to ABC and your local ABC affiliate.
Dec 12, 2008 | Proscan 47LB45H 47 in. LCD TV
Cannot get local channels back after dropping cable.
Are you positive that your city has not done the Digital Conversion? Some Cities are doing it early before the February deadline. Also make sure you are tuning in to the correct channels. Meaning that if on your Cable Provider ABC was on Channel 3 that does not mean that ABC with still be on Channel 3 after you have your Cable turned off. Most of the Time the Local Stations Tag will let you know what channel its on. It will be something like "KWAS ABC 27" So on your TV you would Tune it to channel 27 to get ABC and the same fore NBC , FOX, CBS , etc...
I hope this helps Take Care =)
Dec 07, 2008 | Televison & Video
Lost ba channel
if You have cable maybe you have a bad line
but if you just have an over the antenna lots of station are switching to digital early so maybe your station is not brodcasting analog then you would have to buy a Digital Converter Box
Sep 07, 2008 | TruTech PM1919BXA1 19 in. LCD TV
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
