Question about HP Office Equipment & Supplies
Hello, i keep getting error #6 message on my printer...i clean the glass both top and bottom with a micro-fiber cloth with no results
  • 823 Answers
What do you mean "top and bottom"? Are you removing the glass from a flat bed printer and cleaning the bottom side?
Please clarify if this is an all in one machine or provide the model number so I can give more detailed information.
If its an HP printer with a flat bed (printer that you place the paper on the glass in order to scan, copy or print) then the place you need to clean that it is refering to is not the glass where you place your document. It is a small square of glass that is usually under the rollers off to the side on top of the flat bed area. You should be able to put your hand under the hood of this area and pull upwards to release it. You will find the small piece of glass to clean under the rollers right there. Wipe it off and this should solve your problem. After wiping it, unplug the printer from the computer and power supply for a couple of minutes. Plug the power supply back in before connecting to the computer and allow the printer to warm up and then connect to the computer. This should remove the error code.
Posted on Sep 27, 2010
When making copies af a document a black line is showing on the bottom of the copied page. How can we fix it.
Clean the document laying flat glass with micro fiber cloth.
Pull out the toner/drum assrmbly and clean the drum with same cloth. Turn the drum using black circular dial on the side and clean it. Do not touch the drum. Also, change the toner cartridge if you have not for long time. This mostly happens when the cartridge is about to run out of toner ink powder.
hope this helps.
Dec 15, 2015 | Samsung SCX 4521F All-In-One Laser Printer
Tip
Clean glass tip for copiers in general
Keep your glass Super clean.
If you can access Both sides of the glass, that is even better.
Be sure to use LINT free cloth to clean the glass with.
DO NOT use Tissues -- tissues are made of wood fibers which cause small scratches on the glass and mirrors.
IF you can get to the mirrors, Super carefully clean them, also -- again with LINT free SOFT cloth...(do not leave finger prints on them).
(do not leave finger prints on glass, either -- at any time.)
(if this has been helpful, please rate my tip help++++Thanks for using FIXYA)
on Sep 02, 2010 | Office Equipment & Supplies
How do I clean the TV screen?
Pleadge has a new product out that is just for cleaning electronics like tv and computer screens. it works great
May 08, 2011 | Samsung Televison & Video
No problem...just wondering what to use to clean the screen
a small amount of water or lcd cleaner on a microfibre cloth very gently
Feb 25, 2011 | Televison & Video
The outside of the screen has finger prints and dirt due to my three year old what is the best way to clean it
Tries websites like Amazon.com,Ebay.com to buy a pack of clothes call the Miro Fibers clothes.Use these Micro Fibers clothes,with some water clean the picture screen panel.These clothes are not adbrasive,it for used to clean like eye glasses and exspensive camera lens and for shinning and buffering expensive jewleries.
Nov 28, 2010 | Hitachi 61SDX01B 61" Rear Projection...
Hitatchi lcd tv model 32LD6600 B can I clean
Yes,take a cotton cloth damp it with some water nothing else,softly move all around the LCD screen to clean the dust off.Or tries Ebay.com,Amazon.com to buy a package of cloth call the Micro Fiber clothes to clean.These Micro Fiber clothes are for cleaning eye glasses,deligate surfaces,and electronic devices screen.
May 18, 2010 | Televison & Video
Smudge, streaks, rays imac 24 monitor clean inside LCD
Yep, you can clean the LCD and the inside of the glass, but you will need two suction cups for glass. The ones for picking up window glass work. Lay the computer on its back. Place the suction cups at the upper corners and pull straight away from the table. The glass is held on by magnets and may have tabs at the bottom, so once the magnets are loose you may have to lift the glass away from the bottom edge. Be careful, it isn't safety glass and can break if dropped. The hardest part is keeping dust from getting between the screen and the glass during reassembly. Try working in a dust-free environment. I use two micro-fiber cloths, one with screen cleaner and one dry. You can't believe how much static builds up on the inside of the glass. It just sucks in dust. Don't wear fleece or you'll end up with fuzz as well. Stand your iMac up to reinstall. Clean the outside of the glass so you can see any dust on the inside. Place the bottom in place first. As you prepare to move the top into place, have light behind and above you and view the glass with the black screen behind. You can see most of the dust that way. Good luck.
Apr 23, 2010 | Apple iMac 24" Desktop
Hp2110 psc
The scanner head is unable to find start position.
You may have to clean the black & white strip under the glass.
HP has a document of how to clean the scanner glass.
Go to http://h10025www1.hp.com
You will be at the can't find page.
Enter c00553775 into the search block.
At the search result page, click on Hp All in one how to clean scanner glass.
Oct 09, 2008 | HP PSC 2110 Color Printer
Use scanner copies print not solid
Clean the optical path. Remove glass and use very fine quality micro fiber cloth with no cleaning agents to wipe mirrors and glass. reassemble and test. If no better then maybe focus is off!
May 29, 2008 | Ricoh Aficio AP3800C Laser Printer
63 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
