Question about Panasonic KX-MB781 All-In-One Laser Printer
En el KX-MB781 al sacar copias se traba la hoja
cTech1
  • 66 Answers
SOURCE: How do I make two
Section 5.2.2 inside the users manual here :
http://service.us.panasonic.com/OPERMANPDF/KXMB271.PDF
...speaks of the feature that will copy both sides of a document onto one side.
Possibly this is helpful for you.
Posted on May 16, 2008
ginko
  • 19396 Answers
SOURCE: Como quito la llave que bloquea mi copiadora FP 7735 Panasonic
Hola Elvira,
la llavecita de bloqueo sinifica "LLamar Servicio" esto pasa porque algo en la maquina esta estropeado.
Intenta antes desenchufar el cable de alimentacion para unos cinco minutos, a veces esto puede resolver el problema.
Tambien intenta quitar y volver a poner las cartuchas de tinta, y inspecciona todas las portas y cajones.
Si esto no sirve contacta panasonic, ellos te diran lo que hay que hacer. Ponga "contacta panasonic" en google para encuentrar el numero.
Suerte.
G.
Posted on Jul 02, 2009
  • 224 Answers
SOURCE: hi ihave a panasonic kx-mb781 and it say on
Fuser unit cannot heat up. Replace fuser unit.
Refer to CALL SERVICE 3 (P.120).
Posted on Mar 31, 2010
  • 19 Answers
SOURCE: Panasonic KX-MB781 drum reset
That trick from HobbesVT WORKS!!!! The gear he's reffering to is the litlle white gear with a crossed slot. I turned it to the left and the "replace drum soon is GONE. Thanks HobbesVT
Posted on Jul 05, 2010
SOURCE: how to reset the drum on a panasonic kx-mb781
How to disable the COPY option of KX-MB781 all in one laser printer?
Posted on Apr 09, 2011
Como puedo corregir en una impresora worcentre pe 16 que al sacar una copia o impresion se bloquea .
you have to unblock it,or ask the it man to allow you.
tienes que desbloquearlo, o pedir el es hombre que pueda. https://www.bing.com/search?q=spanish+to+english&PC=U316&FORM=CHROMN
Jul 19, 2015 | Cars & Trucks
LANIER LD135 CODIGO DE ERROR SC990
Depends on the associate engine code. Most of the time it means that maintenance is overdue. Otherwise, it is an electronic issue.
Jun 10, 2014 | Lanier Office Equipment & Supplies
Preguunta d una inpresora
you must configure the page size, because the configuration jams have a page shorter than the product that you put to print.
Apr 25, 2013 | Kyocera Mita KM1620 Black Toner Cartridge...
Buenas tardes, mi equipo es una EOS Rebel XSi, al querer sacar el flash no se acciona y me envia un mensaje en la pantalla solicitandome Err 05 "Se obstruyo la salida del flash, Desconecte y conecte el...
tal vez el boton del flash esta en off apagado o en automatico y esta en un lugar con mucha luz por eso no se acciona busque en el cuerpo de la camara el boton del flash y accionelo hasta que se prenda o se ponga el dibujo en la pantalla de el falsh
Sep 28, 2010 | Canon Cameras
TENGO UNA COPIADORA XEROX 1012, CUANDO TRATO DE SACAR UNA COPIA TARDA EN CALENTARSE Y NO HACE LA IMPRESION Y ASI UNA SEGUNDA OCACION, HASTA LA TERCERA VEZ QUE TRATO DE SACAR LA COPIA SALE, CUANDO INTENTO...
Esta maquina es viejo, pero si la quiere usar, buenos.
Hay algunos alambres en centro de abajo, limpa los. Tiene cuidado porque los alambres se cebran faci.
Otra cosa es la tinta. La tinta tiene una cosa que media la tinta en el roldono palo. Si esta cabado, no va poner tinta muy bien. Se puede acer copias malas.
Otra cosa tambien es si el papel se tora.
Las jantas pueden ser mal. O otra cosa es si la maquina esta cebrara. Cuando abre la machina, mira adetro donde los dos partes se pegan. Si estran cebranan, el cloche en la atras puede pegra la ariba del metale de ariba de la machina. Usa unas pinsa a planar el metala de el clotche.
Buen suerte! Ojala que entiende esta mensaje.
Aug 12, 2010 | Xerox FaxCentre 1012 Plain Paper Laser
The playback voice is giving eco effect?
Tu problema es el conector de audifonos de tu mp3 sony nwz b142f , lo que tienes que hacer es abrirlo y apretar un poco las placas doradas del conector yo lo hice y ahora me funciona perfecto...
Este mp3 tiene tres tornillos, dos a la vista al sacar la tapa protectora y el otro bajo el plástico de la pantalla donde dice sony con letras grandes tienes que despegarlo con cuidado para no quebrarlo , despues de sacar los tornillos habre cuidadosamente la carcasa para no romper la trabas plásticas.
Una vez abierto evita moverlo mucho para que los cables que van a la bateria no se desconecten.
Para localizar la falla, teniendo abierto el mp3, conecta los audifonos y enciendelo, luego con alguna varilla plastica o de madera delgada(brocheta) presiona las placas doradas del conector hasta suene correctamente, sabiendo la que esta suelta, desconecta los audifonos y presionala suavemente solo un poco, ahora conecta los audifonos, y comprueba que entre sin problema al conector y que se escuchen correctamente.
Para armarlo debes sacar los botones BACK y ZAP y ponerlos cuando tengas todo listo
IMPORTANTE: antes de manipularlo debes descargar la electricidad estática que tengas en tu cuerpo tocando algun metal desnudo que tenga contacto directo con la tierra por ejemplo alguna cañeria de cobre para el agua , para evitar dañar algún componente del mp3.
Por ningun motivo manipules tu mp3 abierto sobre alguna mesa metalica o con herramientas metalicas al tenerlo encendido, si lo haces puedes producir algún cortocircuito y dejar inutilizable el mp3.
suerte.
Atte Daniel Améstica
damesticaz@gmail.com
Apr 15, 2010 | Sony Walkman NWZ-B142 MP3 Player
LA FOTOCOPIADORA XEROX 1025 COPIABA BIEN DE REPENTE ME MANDA U2
U2 = Memory failure.
moz-screenshot.jpgClear U2 error
Enter diagnostic mode
To enter diagnostics:
  1. Power on
  2. Press 'Clear' > 'Exposure' > 'Clear' > 'Exposure' buttons within 4 seconds.
  3. All the lamps on the control panel will go out.
  4. Enter the service mode using the 1 button.
Enter code 16
Press Start button
Exit diagnostics, by switching machine off.
If the error returns, you will need to replace the main board.
Good Luck!
Dec 05, 2009 | Xerox Office Equipment & Supplies
La computadora se traba cuando conecto el cargador de la pila
Tal vez hay un problema con el cargador. Normalmente, usted puede cargar la batería con la computadora. Trate de comprar otro cargador. Pero antes de comprar, probar el cargador de nuevo en primer lugar.
Sep 14, 2009 | Toshiba Satellite R15-S822 Tablet PC
HOLA
Ya revisaste que el "candado" este abierto? es decir esta un seguro que no permite sacar copias si lo movieron
Aug 14, 2008 | Sharp AL 1631 Copier
Panasonic KX-MB781 All-In-One Laser Printer Logo
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
