Question about HP Officejet Pro L7680 All-In-One Printer
Pick motor stalled - HP Officejet Pro L7680 All-In-One Printer
    Scholar:
  • 107 Answers
Hello, did you recently have a paper jam, if so, turn machine around, take off duplex unit if its installed, if not remove the back cover, now if your looking at rear of machine, there are several small gears, check that there is no paper debris stuck in there, its hard to really gage if paper is in gears. the grey roller with the white gear should move freely to a point, if it does not move at all, then yes something is stuck. now if it does move freely, then go ahead and put back piece on, lift up front cover as if you where going to replace printheads, move the carriage to the left, look into machine from the left side, and check to see if there is any paper bunched up in that area on the right. if nothing go ahead and close and allow machine to cycle or power up. if the machine has gear crunching noise, turn off, and take to repair. its a little tricky to pull apart, you will need 2 type of torq bits to use.
Posted on Sep 27, 2010
  • koilady2 May 10, 2011
    It worked for me.. don't know how much longer my printer will last... but for now.. its good.
How do I fix "pick motor stalled?
You have to open it to see what us actually stalling or jamming it first, and try to restart and Resset your device..
Oct 05, 2014 | HP Officejet Pro 8600
How o I fix the "pick motor stalled"?
If printer within warranty period then contact customer service....it is faulty!
if not then reset by un plugging at mains for 30seconds then plug back in, turn on and wait till warm up and silent.......has it cleared error? If so then print test sheet!
hopefully good to go!
When i accelerat my mazda pick up the motor seem to staull
If it only stalls when you want to speed up! Your fuel filters must be starting to block sometimes if you blow down the fuel line it might clear it but that's only a quick fix. I recommend that you change the fuel filters.
Feb 26, 2014 | Vehicle Parts & Accessories
08.045.43.39496 I keep getting this error code and my machine goes into a cleaning mode daily wasting all my ink
8,045.43 The media path motor stalled while moving the cap/wipe DOWN.
Initial Actions
• Check for paper in the paper path.
• Check the condition of the Pick and ****** Rollers.
Aug 02, 2011 | Xerox Phaser 8560MFP Laser Printer
When i pick up revs it dies and motor stalls, it then is hard to start, there are no fuel blocks
Could be flooding motor. Mabey carb needs thurough cleaning and a new plug wouldn't hurt
Aug 06, 2009 | Boating
Motor stalls when driving then starts and stalls right away.
Replace the distributor's magnetic pickup located inside the distributor surrounding the distributor shaft, the only other thing thankfully on this ignition system if memory serves me on the f 150 straight six 300 cu inch is the dura spark ignition control box, of course do the obvious tune up parts replacement dist.cap rotor,plug , sparkplugs before spending the $40.00 - $50.00 bucks on the dist.. pick up, you may have a weak a fuel pump check for adequate fuel pressure at carb 7 - 10 lbs.
Aug 06, 2009 | Ford F-150 Cars & Trucks
Oil pressure drops to nothing and engine stalls
it has worn rod bearings . motor needs rebuild
Jul 08, 2009 | 1989 Chrysler LeBaron
My !995 Cherolet Truck Turbo Diesel will stall going down the road or just idling but will always restart. Changed glow plugs, fuel filter, air filter. Service Engine light will come on and it will run...
Pick up a copy of Haynes Diesel Engine Repair Manual, Part # 10330, at your local auto parts store. It has an excellent diagnostic section, check page 1-44. It's a must have for a diyer with a diesel motor. It costs about $20.
Jun 25, 2009 | 1995 Chevrolet C/K 2500
Car stalling and shaking
Check for vacumn leaks. Replace coil. Check plug boots for oil or water on them. PCV hose from intake manifold will get soft and collapse. Replace motor mounts. The passanger side mount is a fluid filled mount.
Mar 03, 2009 | 2000 Ford Focus
93 s10 2.8 wants to stall out after restart
You probably have a clogged fuel filter. There should be an inline fuel filter between the gas tank and motor, replace that and your good to go. I have the same problem with my c10 pick up.
Dec 28, 2008 | 1985 Chevrolet Chevy
HP Officejet Pro L7680 All-In-One Printer Logo
992 people viewed this question
Seeker5211
Seeker5211
