Question about Cross Cst Stanley No.CL2 Fatmax Line Self Leveling Laser
One of the lasers stopped working however ervery once in a while it will work for less than a second
LG washing machine shuts off randomly, why?
only suggestion, next time it happens, unplug like you've done and then hold in power button for 15 seconds to see if that resets it.
Aug 30, 2015 | LG WM3470HWA Front Load Washer WM3470HWA
Xbox 360 drive spins then stops after a couple of seconds
Mine does the same thing i pot tweaked the laser on mine then it spun for a second then stopped so i switches lasers between the hard drives i have still does the same thing both lasers work just spins for a second then stops are there any suggestions you have that could help me fix this myself?
Jul 16, 2012 | Microsoft Xbox 360 Console
Today when I wanted to print something the following problem appeared on my Phaser 6125: Error 061-370 My printer is rather new and has about 2000 copies done. I've turned the printer off, waited a...
An internal error has occurred. Turn the printer off and on. If the problem is still there the laser needs to be replaced. If the machine is less than a year old then the machine will be fixed under warranty.
Mar 04, 2011 | Xerox Phaser 6125 Laser Printer
When I insert a disc into my console it reads for a second then it says open tray I've had this problem before.
You need to clean your laser with qtip and rubbing alcohol if that doesnt work replace the laser. They cost less then $10 on ebay.
Dec 31, 2010 | Microsoft Xbox 360 Console
Recent I have installed hp laser jet p3005d and was working fine for some time,but now i get a problem that when u power on the printer the printer starts to boot and after some seconds stops and there is...
Yes! Of course Printers are the most difficult machinery in the hardware world. Just turn of your printer restart your computer and now once you reeboot your printer and computer it should be able to recognize your devices your printer once that happens just respond back to me Ok!
Mar 26, 2010 | Laser Jet P3005d Printer
Indicators wont work when I have the light on. Yamaha SR125
Sounds like a bad earth at the battery. Check the connections and replace battery if it measure less than 12 volts across the terminals.
Sep 16, 2009 | Yamaha SR 125 Motorcycles
No Disc message
Turn off the power.
Open the lid and gently push the laser mechanism to the outermost point of the slot.
Power on and try a disc again.
Also try cleaning the laser lens with a mild foam cleaner and cotton swap. Leave to dry and re-try a disc.
If neither work, then the laser is probably faulty. If the unit will play CDs but not DVDs, then this is a good sign of a faulty laser.
Mar 16, 2008 | Philips PET824
Cd player
Sounds like the laser slid is sticking. it's not the CD that's the issue, but solidified grease on the CD laser rail. The sled motor has to work harder to push the laser past the lump of grease but once it does the sound continues. Does it get better after you've played 3 or 4 cd's? Same time into a CD each time? If so it's easy to fix by cleaning the old grease off the laser rails and re-greasing.
Jan 23, 2008 | Audio Players & Recorders
Frozen screen
First make sure your hold switch isn't on. It's on the top and slides back and forth. It needs to be switched to the left. If it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Dec 25, 2007 | Apple iPod nano 3rd Generation
Cross Cst Stanley No.CL2 Fatmax  Line Self Leveling Laser Logo
27 people viewed this question
Top Cross Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Cross Measuring Tool and Sensor Expert? Answer questions, earn points and help others
