Question about HP Laserjet M2727nf Multifunction Printer
MY HP2727MFP PRINTER LOCKING UP FREQUENTLY AND I HAVE TO TURN IT OFF AND ON VERY OFTEN DO YOU HAVE ANY IDEA WHAT HAPPEN
  • 223 Answers
This is a problem with either the formatter board or the dc controller, try doing an nv ram ( turn off the printer and hold down the right arrow and the cancel button, turn the printer back on and continue holding until you see permanent storage init). If this doesn't work call hp tech support 1800 334 5144 and ask for a case number. This printer has a service note which will cover the formatter for 2 years.
Al
Posted on Sep 30, 2010
My Canon Printer MG 6250 wont turn on can you please help.
Disconnect the printer from your power source. Open the lid as if to change an ink cartridge. See if the print head cartridge moves freely. If it does not move, you will need to partially disassemble the printer to remove the print head. If the print head moves, remove the cartridges. Lift the locking lever and remove the print head. Then lower the locking lever again. close the printer. Connect it to the power source and see if it will now turns on. If it does,it will give an error message (as there is no print head installed). If it does not power up up without the print head, it is not worth repairing. If it powers up, there is a possibility that a new print head will fix things. But that is just a chance as what damaged the print head may have damaged the logic board. It is simply a gamble. These failures can occur without warning and without apparent reason. Sometimes, it is not a bad idea to just buy another printer. It is up to you whether to gamble or not.
Jun 12, 2017 | Canon Office Equipment & Supplies
Catrage is intalled but the message is not installed
there is a microchip located at the front base side of the toner cartridge which the printer reads when initializing, if the chip is non responsive then the printer will assume no print cartridge is installed- This does happen quite frequently - please contact your toner supplier and inform them of the fault and they should replace free of charge if they are a reputable firm.
Jan 29, 2014 | HP LaserJet 2420dn Printer
Xerox phaser 8500
Did you install the cartridge correctly? Sometimes (and it does happen frequently), is that when installing a cartridge, often you forget to remove the plastic strip that separates the toner from the inner drum, check for that.
Dec 30, 2013 | Office Equipment & Supplies
No paper pickup from tray 1 or tray 2
Pickup roller is likely worn out. If you look right where the paper would feed into it, there'll be a cylindrical shapped roller with maybe a flat side on it. If its glazed and shiny, it needs to be replaced. You can kind of scuff it up with something like a scotch or Brillo pad that you would scrub a kitchen pot with and it might work a little longer. Otherwise, you can just buy a new roller, they're not too expensive
Dec 23, 2013 | HP Laserjet M2727nf Multifunction Printer
My printer tx110 series has a general error it says "delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes turn the printer back on"
If your printer jams frequently, you may be loading too much paper. This can also occur if you’ve had jams in the past and have a piece of debris still stuck in the printer.
Use a flashlight to examine the entire mechanism to ensure no paper is still inside. This can also happen if an internal gear is damaged. You will often notice one side being fed faster than the other.
This could me the printer is physically damaged and needs to be replaced or repaired. You may need a professional help and send it out for repair.
Let me know for any clarifications.
Jun 28, 2010 | Office Equipment & Supplies
Purchased 36xlcartridge
If this is a refilled cartridge, most likely the electronics have been turned off on the cartridge. I own a cartridge refilling store and I don't refill the Lexmark 36 or 37 because the printers turn off the electronics on these cartridges when they get empty so they can't be refilled. If this is an original Lexmark cartridge, I think that Lexmark is making their printers so extremely sensitive to refills that they even kick out some original manufacturer cartridges. I have had a couple customers that this has happened to and it seems to happen more frequently with prebate cartridges. I recommend exchanging your cartridge for a new one (Lexmark brand).
Nov 02, 2009 | Lexmark X3650 Printer
2001 vw jetta automatic transmission problem
Have you checked your transmission fluid?
May 19, 2009 | 2001 Volkswagen Jetta TDI
Waste motor error
The wate motor transfers (you guess it) waste toner to the waste toner bottle. If the bottle fills up, the motor cannot transfer more waste to it. This is rare, for the printer should ask for a new waste toner bottle when the previous one fills. However,it happens frequently when users try to empty and clean the bottle instead of replacing it.
If a new waste toner bottle is in place, then the printer needs a new motor, which can only be purchased through an Authorized Service Center.
Oct 24, 2007 | Samsung CLP-510 Laser Printer
HP Laserjet M2727nf Multifunction Printer Logo
169 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
