Question about Kenmore 22422 Top Load Washer
My kenmore 22442100 top load washer will not stop filling I have to watch it and manually stop water and advance timer past fill cycle please help advise.
    President:
  • 512 Answers
Your load select switch, has a hose connected to it, it goes to the bottom of tub. This tells water to shut off when it reaches desired water level for load size you selected. This hose gets clogged with soap, you have to open area where switch is, take hose off of switch and blow it out. This should solve your problem. If it does not, then load selector switch should be replaced. I am going with first solution, more common. Thanks
Posted on Sep 27, 2010
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Washer will not cycle
    The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
    My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
    My Kenmore wash cycle stops between rinse and spin
    Hi, Does the washer fill in the rinse cycle and then stop? Does it fill and agitate before it stops? If you advance the timer manually past that point, will it finish the cycle?
    Question I need to ask in order to help you.
    Please let me know so I can assist you further.
    Vic
    Jun 20, 2009 | Kenmore 22422 Top Load Washer
    Stops in the middle of wash cycle
    Hi!
    If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Kenmore will not agitate
    The timer is the most common problem. Call any appliance parts store and tell them the model number and ask for price for new timer. Also call sears appliance parts and get price. But a new timer and install it.
    Apr 15, 2009 | Kenmore 24032\24036 Top Load Washer
    We just purchased a top load Kenmore 800 washer machine. We have washed 2 loads of clothes and Now it has stopped filling up with water. It will not do it to wash or to rinse. We have gone thru the mannual...
    The first thing seems to be the timer,or the water level switch. Try filling the washer with water by hand, if it starts to agitate after being filled its the timer, if not it is the water level switch, let me know if you need further assistance.
    Mar 13, 2009 | Washing Machines
    70 series Kenmore washer
    POWERUP, YOUR WASHER COULD BE THE LID SWITCH OR THE COLD WATER VALVE. AT THE END OF THE WASH CYCLE, THE MOTOR WILL SPIN OUT THE WATER, BUT ONLY IF THE LID SWITCH IS ACTUATED. IF THE SWITCH IS BAD, IT WILL NOT SPIN OUT THE WATER AND THE TIMER WILL NOT ADVANCE FROM THAT POINT.
    IF THE WASHER SPINS, THE NEXT STEP IS TO FILL WITH WATER FOR THE RINSE CYCLE. MOST WASHERS USE COLD WATER FOR RINSES. IF THE COLD WATER VALVE IS RESTRICTED OR FAULTY, THE WASHER WON'T FILL. IF THE WASHER WON'T FILL, THE WATER LEVEL SWITCH WON'T ACTIVATE AND THE TIMER WON'T ADVANCE TO THE NEXT STEP.
    Mar 31, 2008 | Kenmore 22422 Top Load Washer
    Washer fills/agitates and stops prior to draining
    If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
    Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
    Kenmore 22422 Top Load Washer Logo
    Sal DeAngelo
    fordexpert
    Ed Mac
