Question about Philips Televison & Video
How do i tune a phillips vcr - Philips Televison & Video
  • Philips Master
  • 5,487 Answers
If you visit the Philips website I am certain you should be able to download the user manual for free. You just need the model number!
Posted on Sep 28, 2010
I have an older Phillips VCR which I am tryuing to get tape playback through to my older sanyo small tv. Can you tell me how to please,
Either you can use the composite signals which is to connect the video out / audio OUT from your VCR to the video /audio IN of the TV and choose the input select to be LINE IN or VIDEO IN.
If there is no input then you can connect the RF OUT from the VCR and play a tape or use the test signal found on many sets on the RF panel. Now tune the TV, manual is better or the entire presetted TV channels will be erased off. Once the signal is found it will be memorised.
Hope you get this right.
Sep 03, 2011 | Televison & Video
Progam phillips RC144 remote for verizon fios
the remotes usually to program combos ...but you may want to try the dvd ...and vcr codes ...as well
May 22, 2010 | Philips 19MDTR20/99 19 in. TV/VCR/DVD...
VCR MANUAL
Easiest way to connect is with a scart connector from VCR to TV, then just select AV1 from TV (this will depend on what type if TV you have). If you dont have scart, put your aerial into the rear input of VCR, take supplied flylead & connect that from rear output of VCR & connect other end into TVs aerial socket. Insert a pre-recorded tape, press play on VCR & then on TV select channel 0 & tune your TV until the play back picture appears, then store this on TV tuning settings.
Jun 19, 2009 | Philips Televison & Video
Dvd hookup to phillips tv without inputs
Have yourself a VCR that has a Scart input, or Video in, and feed the DVD in there. Connect your TV to the VCR, and tune it in to the video channel, using aerial lead and tuner.
When you flick VCR to AV1 (or similar) you should see the DVD appear on the TV Video Channel :)
Mar 14, 2009 | Philips Magnavox 27MS343S 27" TV
LG VCR GC480W can't tune in to tv
Any vcr I know of usually is tuned through channels 3 or 4 unless they are hooked up directly by RCA patchcord. 3 pronged- 2 audio and 1 video. With the patchcord you'll be tuning through an auxilary input in the tv.
Jan 27, 2009 | LG XBR446 DVD Recorder/VCR
Problems tuning TV and SLV-900
the video recorder has it's own tuner you do not actually record from the tv... think of the vcr as like a tv but without a screen... connect to your tv via a scart lead and while you are on the vcr's 'channel' (so you could see a tape playing on your tv) and access the menu on you vcr (not the tv's menu) choos auto tune if the vcr supports it or manual tune if it has no auto tune and tune in the required channels on your vcr... it is simply then a matter of selecting on your vcr which channel you wish to record
Oct 13, 2008 | Sony SLV-D900 DVD Player / VCR Combo
Can,t record from digital channels
You’re dvd/vcr only has analogue tuner so the only way to record is by using the Phillips tv but as said tv will need to be switched on.you would need a sky or cable box or a free view box separate to the tv to record with tv off.the vcr will recieve only on the av channel av1 when connected to tv.a sky box or cable can be connected to av2 on sharp using a second scart lead and box
Feb 05, 2018 | Sharp Televison & Video
Vcr won't record tv
You have to plug the antenna to the VCR, in the "Antenna IN" plug, from there it goes to the "TV OUT".
You use the VCR to tune the TV and choose record according to your VCR model.
Hope That Helps!
Jan 26, 2008 | Televison & Video
Tuning a VCR into a digital tv set
Switch to using the A/V (Audio, Video) connections to watch your vcr
Dec 18, 2007 | Televison & Video
Phillips VCR 550
it only the time setting not cable
Jun 05, 2007 | Philips VR550 VHS VCR
Televison & Video Logo
32 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
