Question about Siemens SX66
Can't hard reset
Screen black says: USB or Serial v2. 07
Take the battery off. hold the power for 10 sec. Then put the battery back on. Push the reset button 1st then hold the power for 6sec. let off the power button 1st and it should do A hard restart. Take out any memory cards before you do this.
Posted on Sep 08, 2008
I enter a password and forgot the same.I tried to hard reset the pda as given in the manual by pressing the power button and the soft reset button for 6 secs.But the instrument goes only to the password window.I tried many times the hard setting but no success. Instuct me how to solve this
Posted on Jun 23, 2008
Do i need to buy an ide to ubs adapter
Better to buy a new hard drive. IDE drives nowadays are mostly found on surviving old pc's. They are slow and usually of low capacity. I feel that any money spent would be better directed at replacing the hard drive.
Apr 17, 2014 | BYTECC ME350V4-ISA-BK Aluminum 3.5' Black...
Computer not recognising hard drive
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
hope this helps
Sep 16, 2012 | Toshiba Canvio 500 GB USB 3.0 Portable...
My external hard drive is not being recognized by my computer.
Try using another USB cable or different port on your PC. It also may be that it needs external power, Check to see if its plugged in to the wall, if it is, it may be that you need a new power supply.
Jun 03, 2010 | Galaxy Metal Gear GMG 2518UAS External...
Im getting a rainbow screen it says serial 0 and that is all
That happened to me today pull out the battery and put it back in turn it on .that happened after i did a hard reset
Mar 17, 2010 | HTC Google G1/Dream Cell Phone Black...
Hx4700 wont work after failed update on ROM v1.10
Try hard reset: pressing and holding the calendar and iTask buttons and doing a soft reset for 2 seconds.
Hard resetting a WM 5 HX 4700 is to press and hold the Contacts and Mail buttons and then doing a soft reset. The boot screen will popup with a message “To perform a clean reset, which will clear all data in memory, press the [Calendar] button”
If that fails, try upgrading to wm 6 or wm 6.1 then downgrading afterwards.
I've upgraded from wm2003SE to wm6.1 alkor rc2.2 rom.
ROMs: http://wm6.winmobile.us/hpmain.htm
Jul 15, 2009 | HP iPAQ HX4700 Pocket PC
Not mounting
TRY GOING TO COMPUTER MANAGEMENT IN CONTROL PANEL AND FORMATTING THE DRIVE FIRST THEN IT SHOULD MOUNT
Jul 06, 2009 | Acomdata Samba USB Enclosure Kit Black:...
Zune wont load
This is how this problem should be resolved:
  1. Disconnect your Zune from USB and AC power sources.
  2. Because the player is frozen, its battery will drain—this is good. Wait until the battery is empty and the screen goes black. If the battery was fully charged, this might take a couple of hours.
  3. Wait until after noon GMT on January 1, 2009 (that's 7 a.m. Eastern or 4 a.m. Pacific time).
  4. Connect your Zune to either a USB port on the back or your computer or to AC power using the Zune AC Adapter and let it charge.
I cannot believe the savvy programmers for Zune did not identify this problem in advance
Jan 08, 2009 | Microsoft Zune JS8-00001 Digital Media...
Jasjar stuck in serial / usb v1.01 screan
reset the jasjar by pressing the reset switch. you can also do a hard reset by opening the keyboard, see the functions keys, there are two that are labeled - and - hold them down and press the reset button, follow on screen instructions for hard reset.
Dec 28, 2008 | i-mate JASJAR Smartphone
Can't reset
Do a hard reset take the battery out leave it for sometimes may be 15 20 minutes and then put the battery in and turn on it should work fine
May 23, 2008 | Siemens SX66
Lost password for my Imate Jasjam
HTC TyTN(Hermes,Qtek9600,JasJam etc)
Always switch off the device before to execute a full reset. The full reset is the Hard Reset of the device an to
execute it push and hold at same time both the SoftKey left and right on the front of the unit while you use the
stylus to press the soft reset button at the bottom of the device.
Sep 24, 2007 | Griffin Technology iMate - Universal ADB...
Siemens SX66 Logo
282 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
