Question about Canon imageRUNNER 2000 Copier
HOW WOULD I CLEAR OUT THE COUNTER CHECK? - Canon imageRUNNER 2000 Copier
    Sniper:
  • 51 Answers
No you can't unless you change the counter pcb attached to the ip main board. ;)
Posted on Oct 05, 2010
From meter counter how can I remove code m2 of minolta 6001
stop 0 stop 1 , counter, clear the drum and developer. ARE YOU REPLACING THE DRUM AND DEVELOPER,
The copier works on the counter clear the counter and not replace the parts that counter is monitoring and you will have codes and image problems the counters tell the copier parts are new and to adj assigned voltages as required.
Nov 20, 2015 | Minolta Office Equipment & Supplies
Bizhub c350
Before replacing the IU select Utility - Meter count - Check details- Stop 00 Stop 01,enter 00000000 END,select Tech.Rep.Mode - Counter - Special parts counter-PC life.Press the Clear key to clear the counter value.Select IC life and clear the counter value.Turn OFF the copier and remove IU unit.After installing the new IU unit select Tehc.Rep.Mode -Function-F8 and press START.After 2 minutes the developer is initialized to make a copies. fcf3fced-96eb-4483-840f-8de548aa8045.jpg 378b39ea-2f19-4cf6-887c-617430da4931.jpg
Jul 14, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
5570 error code e000005
That's a Cleaning Web Counter error code.
To clear it press * 2 and 8 * in that 2&8 are pressed simultaneously.
Go to the Web counter and clear the counter back to Zero (0).
The machine will reboot and Ur problem will be solved.
Please check the below service manual for ir5570 it will help u much in the future if u will have other problems the link is below:
http://goo.gl/nXRXBt
All the best....
Jul 18, 2013 | Canon imageRUNNER 5570 Copier
E005 error
this error is related to web roller in your machines fixing unit.You must be check your web roller condition or replace it.try to clean all the sensor related to the same. if still not working then you clear error through service mode.for service mode press "addition function" then press 2 and 8 at the same time and again press "addition function". then go to COPIER > FUNCTION > CLEAR > ERROR. and press ok.and you clear web counter also in COUNTER .in under misc field > counter >web conter.
Jan 13, 2011 | Canon imageRUNNER 400S Copier
I REPAIR THE MACHINES IN AFRICA SO I NI THE ERROR RESET CODES
Perform the following procedure to enter the simulation mode.
"#" key Interrupt key "C" key Interrupt key
Main code Start key Sub code Start key
Usual "reset" codes:
14 - Trouble cancel (except for U2)
16 - U2 trouble cancel
20 - 01 Maintenance counter clear
24 -01 Jam total counter clear
02 Trouble memory clear
04 SPF counter clear
06 Paper feed counter clear
07 Drum counter clear
08 Copy counter clear
09 Printer counter clear
13 Scanner counter clear
14 SPF jam total counter clear
42 01 Developing counter clear
There are codes and subcodes.
example if yiu want to clear the maintenance counter , you have to enter simulation mode and then enter 20 / Copy key /01 /copy key.
I hope it helps you.
regards,
Adi
Nov 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
Need to reset the drum counter on the AL 1740 sharp while changing to a used drum
Entering in the simulation mode:press Clear - Interrupt - 0 - Interrupt -Main code - Start -Subcode - Start.
When the clear all key is pressed the simulation mode is cancelled.When the interrupt key is pressed,the proces is interrupted and the screen returns to the subcode entering display.After cancelling the simulation mode be sure to turn OFF/ON the power and check the operation.
Main code 20 subcode 1 =Maintenance counter clear.
Main code 21 subcode 1 =Maintenance cycle settimg
subcode 2 =Mini maintenance cycle setting.
Maincode 22 subcode 1 = Maintenance counter display
subcode 2=Maintenance preset value display
subcode 3=Jam memory display
subcode4=Total jam counter display
subcode 5=Total counter display
subcode 6=Developing counter display
subcode 7=Developing preset counter value display
subcode 9=Paper feed counter display
subcode 12=Drum counter display
Maincode 24 subcode 1 =Jam counter clear
subcode 2=Trouble memory clear
subcode 7=Drum counter clear
subcode 8=Copy counter clear
Maincode 26 subcode 22=Language setting
Maincode 42 subcode 1=Developing counter clear
Maincode 43 subcode 1=Fusing temperature setting
Maincode 46 subcode 1=Copy density level adjustment
subcode 19 AE mode picture quality change
Nov 20, 2009 | Sharp AL-1641CS Laser Digital Copier
Sharp ar 405 u2-11 error
Content Counter check sum error (EEPROM)
Detail Checksum error in counter data area
Cause EEPROM defective
Control circuit hung up due to noise
Defective EEPROM access circuit on
PCU PWB
Check Check EEPROM for proper set-up
and To prevent the erasure of counter data
remedy and adjustment values, write down the
counter data and adjustment values by
simulation. (If there is a printer option,
execute SIM23-1 and note counter
data/adjustment values.)
Clear U2 trouble with SIM16.
Replace PCU PWB.
May 22, 2009 | Sharp AR-405 Printer
Service mode
Hello:
All I have access to is the Toshiba Version of your machine but I think maintenance mode is the same.
This is the excerpt from the relative info in the service manual.
Example:
Basically you press # * c * ( to get into maint. mode
Press 20 Start 01 start (then the maintenance counter will clear)
I hope you can figure it out
The drum and dev counts are below
To enter the serviceman test command mode, press the keys as follows:
[#] key [*] key [C] key [*] key
To cancel the test command mode, press the [CA] key.
[10KEY]:(number pad) Entry of MAIN CODE/SUB CODE
Selection of an item
Setup of an adjustment value in case of test commands for adjustment
[/]: Selection of MAIN CODE/SUB CODE
[OK (ENTER)/START]: Settlement
<In case of test commands for print>
[OK (ENTER)]: Settlement (Without print)
[START]: Settlement/Print
[C]: (Interrupting operation check) Returns to the upper hierarchy.
In case of test command of operation check, terminates the operations.
[CA]: Exits from the test command mode.
For a test command of adjustment, the display returns to the initial display (00-00).
20 01 Maintenance counter clear (M-CNT CLR.)
24 06 Developer counter clear (DVLP CLR.)
24 07 Drum counter clear (DRUM CLR.)
Mar 12, 2008 | Sharp AR-168D Copier
Drum light
Check a service manual on resetting the drum counter. You have to reset this counter to tell the machine it has a new drum
Aug 25, 2007 | Sharp AL-1641CS Color Copier
B8300 toner error
From Oki's site: Symptom: The toner counter did not clear after installing a new toner cartridge. Cause: The printer was not powered off when the new toner cartridge was installed, Therefore the counter did not cleared. Resolution: 1. Enter the PCU Diagnostic Mode, By turning off the printer and holding down the MENU and OK buttons on power up. (Release the buttons once you're in the PCU DIAG MODE) 2. Press the MENU button 14 times until the operator panel reads " Counter Display " 3. Press the MENU button and the BACK/C button at the same time, This will put the printer into the Feed Counter Clear Mode (Release the buttons once you're in the Feed Counter Clear Mode) 4. Press the up arrow 5 times until the operator reads " Toner Counter Clear " 5. Press the OK button, The operator panel will now display " Toner no " 6. Press the up arrow once and the operator panel will display " Toner yes". Now press the OK button and the green data light will flash to indicate that the clear process is complete 7. To exit the PCU Diagnostic Mode, By turn the printer off and then back on this will allow you to exit the PCU Diagnostic Mode Hope that helps. If it does not please let me know Ed
Jun 12, 2007 | OKI B8300 Laser Printer
Canon imageRUNNER 2000 Copier Logo
old marine
old marine
