POWER WINDOWS DO NOT WORK. FUSE IS GOOD , CONTACTS HAVE CONTINUITY AND +12v AT CONNECTOR OF MAIN SWITCH AT TERMINAL 10.IS THERE ANOTHER FUSE OR RELAY IN THE CIRCUIT?
Check for corrosion in the wire harness!
Inspection: Connect the motor terminals directly to battery voltage (12V) and check that the motor operates smoothly. Next, reverse the polarity and check that the motor operates smoothly in the reverse direction. If the operation is abnormal, replace the motor.
