Question about PSC Quickscan GP5385 Handheld
Configuration cable keyboard psc gp 5385 - PSC Quickscan GP5385 Handheld
MLR FX 312
I got this for myself a few months ago and it works a treat. You can plug in two USB devices while it's connected to your car lighter.
http://www.amazon.co.uk/gp/product/B00CAVRIHU/ref=oh_details_o02_s00_i00?ie=UTF8&psc=1
May 05, 2014 | GPS
Type of usb cable
Sure thing, I have found the exact cable you need here. I have the link at the bottom of my answer...
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
This is the cable, only $3.99:
http://www.amazon.com/gp/product/B001MXLD4G?ie=UTF8&tag=dependascient-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B001MXLD4G
Oct 14, 2010 | HP PSC 750 All-In-One InkJet Printer
I buy the one but there is no cd driver can it go without driver
hi :
Your PSC QuickScan 6000 should not require any drivers. If this unit plugs into your keyboard port, you should be able to scan a barcode and view the data results in a text editor, such as Notepad. This technology is called "Keyboard Wedge" and consists of a cable with three ends. The first is plugged into your hand-held scanner. The second and third are rather close together and are at the end of the cable. This cable is called a "Y" cable because it resembles the uppercase letter "Y". The bottom part of the "Y" plugs into your scanner, while the first upper part plugs into your computer. The second upper part of the "Y" should be a female plug, allowing you to plug your keyboard into it.
Now if you are using a Keyboard Wedge scanner with a USB keyboard, the female end of the "Y" cable would not have anything plugged into. Unfortunately, the scanner will most likely not operate properly if no keyboard is attached to the keyboard port.
I suspect you may have an RS232 or "serial" scanner. Does your scanner have a power supply that plugs into a standard wall outlet? If so, you may have a serial interface scanner. You could use a program called Com to Keyboard, which would convert RS232 or "serial" data into keyboard data. This is a free program, however, it is a resource hog and may slow your system down
Aug 13, 2009 | PSC QuickScan 6000 Plus Handheld Barcode...
USB Cable Vivitar for ViviCam 5385
Most probably find a Vivitar Vivicam 5385 manual here. Just send them a search request. Search service is not for free, but worthy.
Apr 09, 2009 | Vivitar ViviCam 5385 Digital Camera
Driver for psc quickscan 6000 plus scanner
Hi!
I suspect you may have an RS232 or "serial" scanner. Does your scanner have a power supply that plugs into a standard wall outlet? If so, you may have a serial interface scanner. You could use a program called Com to Keyboard, which would convert RS232 or "serial" data into keyboard data. This is a free program, however, it is a resource hog and may slow your system down.
Feel free to call if you have any additional questions.
Good Luck & I Hope this helps!
-Dave
Dave Krause
Founder, Bluesky America's GetOpen.com
720.771.5194 Direct 888.7.GETOPEN Toll-Free
Mar 31, 2009 | PSC QuickScan 6000 Plus Handheld Barcode...
Need a usb cable for my vivicam 5385 digital camera
Usually I find Walmart the best place to get items like this, especially if you can readily get to a Walmart Supercenter.
Also, you might find it online at www.pricegrabber.com to get a good price. Take care, & good luck!
Nov 27, 2008 | Vivitar ViviCam 5385 Digital Camera
I need an owners manual
You can download a manual (06656 User's Guide/Programming Guide) at the DataLogic site. They bought PSC in 2005.
http://www.scanning.datalogic.com/sitefiles/result.aspx?m=Product%20Manual&p=53XX&l=english&d=1&t=search&s=NonCurrent
If your cables are connected between your keyboard and PC, be sure to set up the correct Keyboard Wedge Parameters, beginning on Page 34, to allow connectivity.
I'd start by scannig barcodes "CE" and "ZA" to reset to default wedge values. If that doesn't work, I'd procede to sc an "CF" for PC=AT,PS/2.
Pages 36 & 37 address the Caps Lock issue, where the scanned value is in the wrong upper or lower case.
Have a nice day,
Label_Guy
Jun 12, 2008 | PSC Quickscan GP5385 Handheld
Please Help me
MOTOROLA GP-2000 Programming Instructions
Switching between Dealer and User Configurations
- Turn off radio
- Press PTT + Monitor Buttom and + buttons together and turn radio on
- LCD Displays PRO-CLR
- To confirm switching to Dealer configuration, Press PTT. To cancel, press any other button
- Turn off radio. The radio now operates in Dealer configuration
From Dealer to User
- Turn off radio
- LCD Displays PROTECT
- To confirm switching to User configuration, Press PTT. To cancel, press any other button
- Turn off radio. The radio now operates in User configuration
ENTERING PROGRAMMING MODE
If the radio is turned on, turn it off. Press and hold the MON button and turn the radio on. A ringing tone will be heard,which indicates that the radio is in Programming mode. The PW and [] indicators are displayed.
EXITING PROGRAMMING MODE
To exit programming mode, turn off the radio
ACCESSING PROGRAMMING MODE PARAMETERS
In dealer config., Programming mode parameters are grouped into 3 (three) main categories.
RW = Radio Wide
Channel (001 to XXX) and
VFO (Variable Frequency Operation)
User + or - buttons to move from one category to another.
RW < >CH 001 < > CH 002 < > …. < > CH XXX < > VFO
Note : Radio operating in User Configuration is only restricted to PW parameters
Once you have selected the category and wish to view its parameter, use PTT or MON to move from one parameter to another.
Nov 06, 2007 | Radio Communications
PSC Quickscan GP5385 Handheld Logo
108 people viewed this question
Top PSC Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Jax Planet
Jax Planet
Electric Dime
Electric Dime
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
