Question about ASUS P5G41M LE Motherboard
My CPU Fan and Power Fan is spinning just a moment!! firstly , i check RAM, CPU Fan and CPU and then Power Supply... but all of parts are good !!! i think , this problem is possible because of my motherboard. Please Advice Me!!
    Brigadier General:
  • 10,406 Answers
It's not the RAM.
It's not the CPU.
It's not the power-supply.
Turn the computer off.
Disconnect the power-cord.
Disconnect the power/data cables from the 3.5" diskette drive, the disk-drive, and the CD-ROM drive.
Disconnect the mouse.
Disconnect any printer.
Remove any USB devices.
Reconnect the power-cord.
Turn the computer on.
If you still have the problem, then it MUST be the motherboard.
Posted on Sep 27, 2010
I rebuilt computer with new parts, now won't start up. No POST. Power LED lights up, no cpu fans spin, no beeps. Psu works with paper clip test. New mobo, ram, psu, cpu.
Check display without cabinet maybe motherboard getting short with cabinet and try new Power supply check all the power supply connectors connected or not .
Nov 14, 2016 | Computers & Internet
CPU not getting started
Hi chandrashekhar,
When you say not getting started, do you mean that it will not turn ON?
If your PC will not turn on and you already did try a known good power cable then you must check inside to see what is the issue, this can be a bad power supply or a bad motherboard, to isolate things we need to find out first if the processor Fan inside is spinning if the power is turned ON.
If the Processor Fan spins when turned on but the system does not boot at all then next we need to check what could be causing the system not to boot, if you have more than one Memory RAM on *********** board remove all of them and try one ram at a time on each memory RAM slot to see if one ore more of the memory RAMS can be damaged or one of the Memory RAM slots can be busted.
But if the issue is there is no power at all, then this can just be 2 things, it is either the mother board on your computer is not receiving power anymore or the power supply of the computer is not supplying power anymore.
I hope that this help,
Good Day.
Aug 01, 2012 | Intel Computers & Internet
HP D7-1245DX Motherboard part number 506124-001 Power supply went bad, was running fine off of battery until battery went dead. Replaced power supply with good HP 463958-001 power supply, but it will...
I would first double-check the "known good" power supply. If there is something bad wrong with the MB, it could have blown the fuse in the power supply. I have seen very few fuses on motherboards, they are normally in the power supply. If the power supply checks out OK, then double check the connectors between the power supply and the MB.
Oct 02, 2017 | HEWLETT-PACKARD Hewlett Packard 506124-001...
Plug power cord in to computer, power supply starts up system fan and cpu fan starts and runs no other indication that the computer is booting up. this happens with all cobles diconnected, even the frount...
Try swapping out the RAM first since it's easier then changing out the CPU. If that doesn't work, then the probably most likely lies with the CPU.
Regards,
Matt
Mar 30, 2011 | HP Computers & Internet
On board led indicators are red in motherboard TF7100P-M7 power supply works cpu fan works both fans of the CPU heat sink assembly and power supply fan spin It shows no display, No beep
remove all ram memory wait 5 min,make sure to unplug from a/c,reboot with no mem should hear beeping unplug reinstall mem should boot ok if mem good,good luck!
Jan 08, 2011 | Biostar TF7100P-M7 Motherboard
A fan is making a horrible noise
hello
if its the CPU fan is making loud screech noises, its time to replace it
if the power supply fan is making the noise, its time to replace power supply , 5188-2859 is HP part number $25-$40
CPU fan = 5188-3722 HP part number , costs about $40-50
please rate my service with 4 thumbs up
Dec 09, 2010 | HP Pavilion Elite m9510f PC Desktop
Dell 4700c will not power on white light on motherboard
Is there any chance for you to check if the power supply blows air from inside of the power supply? If yes, on your motherboard, do disconnect the P1 cable or the main power supply cable that connects to the motherboard and the P2 cable which. and try to plug the power cord of the power supply and if the fan did not spin, power supply is the one causing the problem
You may also try to remove the RAM or memory card module from the motherboard and all of the PCI card connected to the motherboard. Try to turn on the system and check the power supply fan and the CPU fan if it will spin. If not then I recommend you to replace the power supply.
On the other hand, if the fan is spinning on the power supply after you remove all the RAM and PCI cards. And the power button light is flashing amber or solid amber color. Try to install RAM 1 by 1 to isolate the problem.
Let me know if the problem persist
I
Sep 23, 2009 | Dell Dimension 4700C PC Desktop
System will not start up. Cpu fan spins once, then nothing.
It is more than likely that when your old power supply died a death, it damaged some components on the motherboard. Replace the Motherboard and chip, and you should be back in business. You can pick up some good value bundles to save money on buying the parts seperately. The power supply working again after turning off and on, is because there is a little trip in the power supply that triggers when it detects a fault. Powering down resets that trip allowing it to try and work again.
Mar 05, 2009 | MSI K7N2 DELTA2-FSR NVIDIA nFORCE2 ULTRA...
Power supply Ok.But CPU fans started with seconds It's stop.
sounds to me like your mainboard is bad, i bet if you closely inspect the capacitors around the cpu one or more is bulged out or leaking
Feb 15, 2009 | Asrock P4S61 Motherboard
DFI Infinity NF4 SLI won't start
Hi steve, PC repair is trial & error. I suggest you replace the power supply or test the power supply in another PC that also uses 4 SATA drives & two PCI-E slots for starters. Two boards with the same problem is odd. You must have the CPU & fan connected, memory installed, ATA 24_pin main power plugg connected (Page 17 in manual). 4-pin_12v power connected which is located (Just to the left of DDR1 memory slot). Looking at you're board the power supply should be no less than 500w.
CPU must have thermal grease between CPU & heat sink.
Even though you have fans running & LED's on & flashing, the power supply seems to be the first item to check. Make sure the bottom of the motherboard is not touching the PC case.
Try the above & post you're finding here.
Good Luck!
Mike
Jun 28, 2008 | DFI Computers & Internet
ASUS P5G41M LE Motherboard Logo
52 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
