Question about HP LaserJet P4015 Printer
Will not feed paper from tray 2., display reads paper jam have switched trays. inspected rollers. seems that feed roller on top is hanging up. remove tray and push lever on right side and roller comes down
    Champion:
  • HP Expert
  • 202 Answers
See the position of feed roolers in tray 1 they didn't come out cross check them properly & set them in proper position also check the paper path from tray 2 may be sencor blocked or dirty check them.your problem will be resolved 100%
Posted on Sep 27, 2010
Paper tray jam
I would first go to the manufactures web site and ask for support. In the mean time, I would open up the paper tray and inspect where the paper feeds into the rollers. If there is another access point, where the paper comes out, inspect that area as well looking for paper or fragments. Sometimes if you can turn the print rollers by hand a paper jam will reveal itself
Jan 20, 2015 | Dell 3765dnf Colour Multi-function Laser...
X4270 paper feed jam
You may have remnants of torn paper left in the feed rollers or beyond -from a prior jam. Other causes include:
  • Overheating
  • Wrong Paper Type
  • Printing Labels
  • Cracked or Dirty Rollers
  • Use of Wrong Tray
  • Incorrect Loading of Paper
  • Paper Overload
Nov 21, 2013 | Lexmark X4270 All-in-One Multifunction...
Sir my printer problem is on printer menu write a clearing paper path what is this massage and give me solution.
Thank you contacting FixYa for your printer inquiry.
This error is associated with either a sheet of paper blocking the paper path or a partial piece of paper that blocks path or trips a sensor. The printer will usually throw up a error code 13.XX on the display and the XX is a number that will indicate where in the paper path this error most probably occurred. Just follow the steps for your error on the below chart.
This link will take you to the user guide which will be helpfull identifying components and providing guidelines for most of the helpful hints and things you will need to know about this printer.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00218691/c00218691.pdf
Locate your error on the matrix below and follow the steps. Comment back if you need more help. Thank you again for contacting FixYa.
TF
HP Laserjet Error Codes 0 - 19 Message on printer Display Panel What it means. What to do. 13.XX PAPER JAM [LOCATION] Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken. For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation. 3.0 PAPER JAM [LOCATION] A non-specific paper jam occurred. 1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation. 13.1 PAPER JAM OPEN INPUT TRAYS Paper-delay jam at paperfeed area. 1. Ensure that paper trays are loaded and adjusted properly so media can feed from the tray. It might be necessary to reduce the stack height of media in the tray. 2. Check the input area for obstructions such as media in the path. Also check to see if the registration assembly damaged or unseated. 3. Replace any defective sensors or flags. 4. Verify the media meets the specifications. 5. Check the pickup feed and separation rollers for unusual wear. Replace as needed. 6. Rotate the media in the input tray by 180° and/or turn it over On NX engines this is most likely the fuser flag or the ACPM. The ACPM has a photosensor hard-wired to the back of it. 13.10 PAPER JAM CHECK DUPLEXER Jam at duplexer. 1. Check the duplexer and the rear area of the printer for obstructions or damage. 2. Check the duplexer for proper operation. Replace the duplexer if a sensor is defective. On a 5si, 8000, or 8100 series laserjet a Duplex Jam can be caused by a tray 2 and 3 feed assembly failure. 13.14 For Laserjet 5si. This error is caused by a defective paper control PCA Replace paper control PCA. 13.2 PAPER JAM OPEN INPUT TRAYS Paper-stopped jam at paper-feed area. 1. Check the input area for obstructions such as paper in the path. Also check to see if the registration assembly is damaged or if the transfer roller is out of place. 2. Replace any defective sensors or flags. 3. Ensure the media does not exceed the maximum length. 4. If multiple sheets are feeding, it might be necessary to fan the media and reduce the stack height. Also, replace separation pad. 5. Verify that the fuser is properly installed. On NX engines this is an input jam. 13.20 PAPER JAM CHECK REAR DOOR Media stopped in the paper path during power on or when the top door was closed. 1. Remove all media in the paper path, and then open and close the top cover. 2. If the message persists after all media is removed: Check if media is jammed in the prefeed area. Replace any defective sensors or flags 13.21 DOOR OPEN JAM The top cover was open while printing. 1. Clear the jam and close the top door. 2. If the message persists, check the top door switch for proper operation. 13.5 PAPER JAM CHECK REAR DOOR Paper-delay jam at fuser. 1. Check the transfer roller and small media belt to ensure they are operating and can feed print media. 2. Check the paper path for obstructions at the transfer roller, toner cartridge, paper feed assembly, and fuser. 3. Replace any defective sensors or flags. 4. Turn the media stack over and/ or rotate it by 180° in the input tray. If still persists - replace fuser, then DC controller. 13.6 PAPER JAM CHECK REAR DOOR Paper-stopped jam at fuser. 1. Check the paper path for obstructions at the fuser and output/delivery area. 3. Replace any defective sensors or flags. 13.99 PAPER JAM [LOCATION] A non-specific paper jam occurred. 1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation
Jun 09, 2011 | HP LaserJet 4350 Printer
I removed a jammed sheet of paper through the front opening, Had to pull real hard. Since then, when printing or copying, printer feeds up to 4 extra sheet with each printed page. I suspect some piece of...
Please see this solution from Canon. It is recommended you check your manual for the proper procedure for clearing paper jams. Incorrectly removing jams could damage your printer. Trust the following helps resolve your current issue.
If you do not have a manual it can be downloaded from here:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx300#BrochuresAndManuals
Issue: More than one sheet of paper feeds while printing
Solution: Clean the paper feed rollers using the MX300 operator panel
sikaku.gif Cleaning the Paper Feed Roller (Roller Cleaning) Clean the paper feed roller if paper is not fed properly. Cleaning the paper feed roller will wear the roller, so perform this only when necessary.
1. Make sure that the machine is turned on, and then remove any paper from the Rear Tray.
2. Clean the paper feed roller.
(1) Press the Menu button repeatedly until MAINTENANCE appears.
(2) Press the l_mark_s.jpg or r_mark_s.jpg button to select ROLLER CLEANING, then press the OK button.
The paper feed roller will rotate as it is cleaned.
3. Repeat step 2 twice.
4. Open the Paper Output Tray.
(1)Put your finger in the rounded indent beside the Paper Output Tray and open it gently.
(2) Open up and set the Output Tray Extension completely by pressing down the hollow on its front side.
5. Make sure that the paper feed roller stops rotating, then load three or more sheets of A4 or Letter-sized plain paper in portrait orientation in the Rear Tray.
Set the Paper Thickness Lever to the left.
6. Repeat step 2 three times.
The paper cleans the paper feed roller as it feeds through the machine.
If the problem is not resolved, wipe the paper feed roller (A) located on the right side inside the Rear Tray with a moistened cotton swab or the like. Rotate the roller (A) manually as you clean it. Do not touch the roller with your fingers; rotate it with the cotton swab.
Dec 25, 2010 | Canon MX300 Office All-In-One Printer
I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
Dec 25, 2010 | HP LaserJet 4250 Printer
13.01.00 paper jam tray 2
The pickup rollers are worn out. Replace them and your problem will be gone. While you are sourcing them, use some alcohol. This may give them a little more life.
Jul 23, 2009 | HP Color LaserJet 3500 Printer
Error message keeps appearing "paper jam in tray 2" although there is definitely no paper jam.
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If you don't find anything you may need to disassemble the printer to find it.
May 02, 2009 | HP LaserJet 2300dn Printer
HP 2840 printer paper jam
does the paper feed at all(1/2 way) no feed,if not pick-up paper most likely will be feed motor if 1/4,1/2 or 3/4 fed will be sensor at falt or 2nd tray conectors dirty or making false contact.
Sep 08, 2008 | Office Equipment & Supplies
Doesn't Print - Says "Paper Jam"
That is the problem, machine will show printer jam if paper feed rollers fail to pick up paper when requested, your machine sounds like it needs new paper feed roller or you can clean the paper feed roller with a slightly! damp cloth.
If no jam light shows when power is turn on and machine comes to ready and then you send a job to printer and it then shows jam then it is the feed roller or sometimes the feed clutch
If on the other hand it always show jam then there is or a switch is stuck.
Oct 25, 2007 | Kyocera Mita FS 1200N Laser Printer
HP LaserJet P4015 Printer Logo
246 people viewed this question
Seeker5211
Seeker5211
