Question about Thermador SC302T Electric Double Oven
Thermador SCD302 NO Illumination on Display window
  • Thermador Master
  • 8,220 Answers
Bullet fuse to control panel Melted due to excessive heat from self clean mode. Just a guess> Typical fuse:Thermador SCD302 NO Illumination on Display window - 49b75ce.jpg
I have a manual around here somewhere Oh yeah in my TIP
Thermador 301/302 wall oven repair manualHelpful?
Posted on Sep 28, 2010
The control panel display is so light that it can not be read. I have a double built in oven SCD302. What can be done?
Hello, welcome to FixYa.
There are two common scenarios with these Thermador wall ovens fitting what you've described. The harness to the display from the control board is loose (not likely) or the display itself is failing (most likely).
The issue with these displays is they lose their intensity over time because of the fluorescent tube technology they use, hence the only remedy is to replace the control/display kit...the display only is not available, but a "kit" is.
You can find these "display kits" at "repairclinic.com" and similar to what I've attached here...
**Your other option, and the one I recommend, is to have the existing display and control rebuilt...the down side is this will require the parts to be removed and sent away**
You may find other suggestions or "band aid" remedies on-line, but in my experience this is the sure way to go. Here you'll find all the info pertaining to this option by clicking on the link I've provided below
http://www.corecentricsolutions.com/CCSWeb.nsf/published/bosch
Hope this helps move you forward. Let me know if I can assist you further and good luck.
Regards,
Macmarkus :)
Oct 14, 2011 | Thermador SC302T Electric Double Oven
I'M LOOKING PART OF THIS MODEL Thermador SCD302TP
Hopefully the info below will supply you with the assistance to get the door seal for your SCD302 series Thermador double wall oven. They should have anything you need.
http://www.repairclinic.com/Model-SCD302TP-ID-642642-Parts
Thank you for choosing FixYa and good luck. Please take a moment before leaving to rate the assistance provided here and your experience at FixYa.
Regards,
Macmarkus :)
Sep 19, 2011 | Thermador SC302T Electric Double Oven
Thermador Built in oven scd302 not heating upper oven, lower oven fine. Heating element not glowing red as the oven below it does.
Hi.
Problem is usually either temperature probe or heating element.
Grab a multimeter and set it on impedance (Ohms).
Remove first temperature probe and then heating element.
If either probe or element is reading open (ohms infinity), then replace the part.
If both probe and elements are not open, then the problem is either wiring or oven electronic control. The most common fault resulting in no heat is the temperature sensor located inside the oven cavity.
Regards.
Ginko
May 31, 2011 | Thermador SECD302BPSS Electric Double Oven
The control panel is very dim on my Thermador RDSS30 oven
Cannot Read Display or See Temperature Thermador RDDS30
FixYourBoard.com repairs this failure and back their work with a two year warranty.
May 14, 2011 | Thermador Ovens
The control panel on my Thermador scd302tp will not light up. The oven works fine. The appliance company wants to replace the entire control panel. Can it be fixed for cheaper?
Hello, welcome to Fixya. To answer your question "Is there a cheaper fix?" In a word...maybe. **Turn off the breaker before attempting any service suggested here please** The first thing to look into is to check the harness which comes from the main relay board to the display head, they can become unsecured from the display or the main relay board/control and that will affect the display in a negative way, i.e. faded or no display illuminated. You may or may not be surprised how much those things vibrate under normal use with the cooling/convection fan running etc. and over time the harness becomes unsecured. Check "J1" on display head as well as "J1" on relay board of the display power harness and insure they are secure in place, wiggle them a bit to see if the display illuminates when turning the power back on. If that doesn`t yield any positive result`s you`ll need a new display head kit part # 492067, it comes w/harness and main relay board ( see image below ) and it is typically about $250 or so, but I haven`t had to purchase one in 4-5 yrs. I`ve checked repairclinic.com and their site says it is discontinued, but if it turns out you need one I may have one in my garage. ( I used to have my own appliance business, hence I still have some "new old stock". we can communicate via email if need be ) Let me know what you find and how it goes with the harness check, I`ll watch for your reply on your post here. I`ll cross my fingers for you it`s just a loose harness. Hopefully this was helpful to move you forward and shed some insight on what to look for at least. Good luck macmarkus :)
Jun 17, 2010 | Thermador SC302T Electric Double Oven
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Thermador oven display is dimming
replace the capacitors on the display unit. Just did this and it now works
theblog
Nov 29, 2007 | Ovens
Thermador Display
Have 2 Thermador ovens, SMW272 and SC302. Both have display failure. Just repaired one with replacement display. It did not require a new control unit or harness. Have not opened up second unit yet as display is still dimly/slightly visible.
Called Thermador and received no offer of replacement parts or service. Numerous other web reports of similar failures. My neighbor has 2 dead ovens also unfixed because of outrageous repair estimates ($600 each). Do not recommend this brand.
Full kit including display, control, and harness ordered on Ebay for $170.
Sep 21, 2007 | Thermador SMW272 Electric Double Oven
Open Questions:
See all Thermador SC302T Electric Double Oven Questions
Thermador SC302T Electric Double Oven Logo
655 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
