Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
I have a 2005 fatboy and i replaced the battery. when i hit the start button the starter relay clicks and nothing happens. all my lights work and the fuel pump kicks on like normal. it just wont start
    President:
  • 512 Answers
Sound like starter is stuck. Try giving it a tap with a rubber mallet, while pressing start button. If this does not work, put bike in gear and push it forward a few feet, then try again to start it. If still nothing try using jumper cables on battery, then start. If no go you have a bad starter.
Posted on Sep 27, 2010
Harley will not start .battery fully charged relay pulling in but will not start 2005 model fatboy
Check to make sure voltage is getting to the starter while you have the start button pushed. If you have battery voltage then you need to repair or replace the starter
May 03, 2016 | Cars & Trucks
When it rains car doesn't start
READ THIS ALL BEFORE YOU DO ANYTHING
NOTE: some vehicles have the starter relay and starter mounted together as 1 unit. Sometimes the starter relay and starter are seperate. When I refer to "relay" it could also mean the starter and relay as 1 unit.
Note: "starter switch" is not to be confused with "key switch", although sometimes they are all one unit. The starter switch is usually mounted on the steering column and actuated by a metal rod. On units that are all one unit, the keyswitch/starter switch (both one unit) will have to be replaced. (this is a rare problem, so don't get worried just yet)
1. Check battery voltage, should be between 12.5-14.5 volts. if low voltage replace or charge battery, and try to start car, if it don't crank with new or charged battery, move on.
2. Check connections on the starter relay, even the small one coming from your starter switch. if loose or corroded, clean with a brush and reconnect them. Try to start your car. Did it start? if not, Move on
3. Well now we know the connections aren't the problem. How about a click? did you hear one? If a click is heard, go to #4, if nothing is heard, go to #5
4. Well at least the relay is clicking, but nothing else is going on. The relay is working, so the starter must be bad. Replace the starter and start your car!
5. Humm, connections aren't the problem, maybe the relay is bad, replace your relay with a new one. Move on
6. Now we have a new relay, with clean and tight connections. Start your car. Does it start? If yes, then HORRAY! we fixed it. Does it click? If so then goto #7, If it don't click, then goto #8
7. So here we have a new relay, with good connections that will click when trying to start the car, but nothing else happens. Starter is faulty, replace the starter, and off you go, see ya!
8. So here we have a new relay, with good connections, but it still won't click when we try to start our car. This means that your starter switch is faulty. Replace starter switch and try to start your car. Vroom! finally done with this car problem!
List of shortcuts: if you remove the starter switch lead (small wire) from the relay and apply +12v to its respective prong or lead on the relay, and your starter cranks, your starter switch is faulty. You can actually hook up a starter button this way. If you jump the two large wires together on the relay and it cranks, then the relay is faulty. If you jump the two large wires together and nothing happens, then starter is faulty, or wires to starter are loose or broken.
Dec 11, 2013 | 2005 Ford Ikon 1.6i
Which fuse is the main fuse for a 2003 harley fatboy
Hi Anonymous, on a Softail remove seat and directly behind the battery is a black plastic box. The cover slides up and off revealing the starter relay and the system/fuel pump relay for you injected folks and the various assorted circuit fuses. Good luck and have nice day.
Apr 10, 2013 | 2003 Harley Davidson FLSTFI Fat Boy
Suziki Boulevard C90 wont start, when hitting the ignition nothing happens, but the lights dim
Your starter button is a two position switch. The lights are supposed to go dim when the button is pushed halfway in. When pushed in all the way it should activate the starter solenoid. The starter solenoid is located under the seat next to the battery. You can follow the positive battery cable directly to the starter solenoid. If you push the starter button and the starter solenoid clicks, then the starter button is good. If the you unplug the two smaller wires going to the starter solenoid and connect a voltage meter to the main harness leads , the needle should jump whenever you press the starter button. If it does not clean the button contacts or replace the right switch assembly. If the starter button is good then take a jumper wire and short across the two battery cables on the starter solenoid. This will put power directly to the the starter. If the starter works now replace the starter solenoid. If your starter still does not work, try holding the starter button and tapping on the starter with a plastic hammer. If the starter works now then you probably need to replace the starter brushes. If anything else is wrong with the starter you will need to replace the assembly as the dealer will usually only offer the starter brushes for repair purpose.
Jun 18, 2011 | 2005 Suzuki Boulevard C90
Went to start bike after sitting for a few weeks starter turned did not start then i tried it again and i could here it spinning which did not stop when i hit the kill switch or when i took out the key now...
starter relay/solenoid stuck open and drained the battery. charge the battery and replace the relay/solenoid. Sometime you can tap on the relay lightly with a hammer and get it to unstick and work but it's best to replace it.
Dec 09, 2009 | 1991 Yamaha XT 600 E
Having starter or starting system problems
i would normally say check the bat. connections but since you tried jumping it off i will lean towards starter solenoid.
Jul 02, 2009 | 2001 Boss Hoss BHC 190 Hp
06 s83 won't start. Rode for 70 miles, parked in
replace your battery although you have 12 volts your battery is producing very little amps not even enough to energize your start relay let alone your starter motor
May 03, 2009 | 2005 Suzuki Boulevard S83
Lands Phones Logo
342 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
