Question about Dryers
What does the spark ignitor look like and how hard is it to replace my dryer runs great just no heat i have the front off and can run the dryer but i dont see any flame or spark underneath of it
  • Dryers Master
  • 43,501 Answers
Most modern dryers use a hot surface ignitor...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 27, 2010
I had the " dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
May 07, 2011 | Roper RGX4634KQ Gas Dryer
Whirlpool dryer(LGQ9557HQ0), ignitor ignites but flame does not light
mounted on top of the gas vavlve is black electrical coils when energized it opens the gas valve,if one of the coils are defective it wont open and let the gas thru,its hard to test the coils so most repairmen just replace them all
Jul 07, 2008 | Whirlpool Dryers
Dryer is not heating up it runs does the ignitor heat up before gas valve opens because the ignitor never heats up
On my gas appliances, either there is a pilot light or the ignitor sparks (like a car spark plug) or glows after the gas valve opens. The ignitor does not heat up.
I've had some gas appliances that have had the valve stick. (On an oven, we tested this by tapping on the valve when the unit should have called for gas. This confirmed that the valve was bad and not the thermostat.)
I hope this helps.
Dec 07, 2010 | Amana NDG7800AW Gas Dryer
No heat in gas dryer..replaced the ignitor..worked..then when he pushed it back into place it quit heating..the ignitor is lighting up but it is now not getting gas...and we have gas in the tank
If the ignitor glows then shuts off but does not lite (it will do this over and over) then the problem is one of the coils on the gas valve is not working. The coil kit is easy to replace the part number is 12001349 and should run about $30.00. They secure to the top of the gas valve just in front of the ignitor you replaced.
If the ignitor continues to glow and does not turn off then the part you need is the sensor part number Y303377 which mounts to the burner box real close to the ignitor and runs about $25.00
I hope this helps.
Apr 23, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
No heating?
If the unit runs and heats for a short time, then only runs without heating, it may have bad gas coils(2 solenoids that are screwed on to top of gas valve)
If the unit runs without any heating would check the ignitor or the thermal fuse.(ignitor is fragile)
Check it is not accidentally set in air fluff....
Most all whirlpool dryers are front serviceable by lifting the top(two screws by air filter and putty knife pushing in about two inches on each side in front) Some have a lower front panel, most you remove the front to access parts. Sharp edges and unplug while servicing. The ignitor and thermal fuses can be ohmed out at a service store. There are other possibilities, these are the most common, good luck.
Apr 19, 2010 | Whirlpool GGQ8831L Gas Dryer
It's run but there's no heat
The gas dryer has a spark ignitor that starts the burner to heat up. Upon switching on the dryer you should hear the ignitor clicking to light the burner. If you do not hear the clicking noise the ignitor needs to ne replaced
Mar 27, 2010 | Whirlpool LGR5636L Gas Dryer
Dryer doesnt blow hot air.
I find that quite often the ignitor is out of alignment or the glass window is covered with lint.
a gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes.
There are two common styles of ignitors, glow ignitors and spark ignitors. The ignitor ignites the gas either by heating up and glowing, or by sparking. If the ignitor fails, the dryer will not heat.
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working.
Aug 19, 2009 | Kenmore Dryers
Kenmore series 90 no heat
Check the glow ignitor on the right side of the dryer if you are looking at the front on the bottom side and make sure that it is not cracked
Feb 09, 2009 | Kenmore Elite HE4 Electric Dryer
Gas dryer is not heating up, after being moved
BE SURE THE GAS IS TURNED BACK ON. CHECK THE TEMP SELECTOR SWITCH TO BE SURE IT IS SETTING ON A SELECTION AND NOT BETWEEN SETTINGS. BE SURE IT IS NOT ON FLUFF AIR/NO HEAT. IF THAT IS ALL O.K., THERE ARE FOUR ITEMS TO CHECK IN THE HEAT CIRCUIT.
1. IGNITOR. CHECK FOR 120 VOLTS AT THE IGNITOR TERMINAL CONNECTION WITH DRYER RUNNING.
2. WATCH THE IGNITOR. IF IT GLOWS, CLICKS, GOES OFF WITH NO FLAME, ONE OF THE SOLENOIDS IS BAD. REPLACE BOTH.
3. IF THE IGNITOR COMES ON BUT NEVER SHUTS OFF,
THE RADIANT SENSOR IS BAD.
4. IF THERE IS NO RESPONSE FROM ANY OF THE CHECKS ABOVE, THERE IS A THERMAL FUSE ATTACHED TO THE EXHAUST PORT. IT MAY BE BAD. CHECK FOR 120 VOLTS ON THE TWO TERMINALS OF THE THERMAL FUSE WITH THE DRYER RUNNING. IF YES, THE THERMAL FUSE IS BAD.
Apr 21, 2008 | Dryers
Dryers Logo
56 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
