Question about Jura Capresso 555 Electric Burr Grinder
I need to find an instruction manual for a Jura Capresso 555 burr grinder for coffee? Where can I get one? Thanks, Tony Cecere
3 Suggested Answers
mark24354
  • 776 Answers
SOURCE: Because it seemed to be
The manufacturer never made any parts available means the manufacturer never released any exploded views either. No need to create/publish parts diagrams if no parts are going to be sold. Sorry.
As far as your lost ball bearing, you may be most successful at a bicycle store. They commonly handle loose ball bearing and, if they are good, should be able to measure one for you and sell you a replacement. Most hardware stores only sell bearings that are sealed or in a set (cage). Most autoparts stores are also limited to cage bearing sets.
Good luck getting it back together. However, if it needed to be taken apart and the manufacturer views the product as "disposable" (since they don't sell parts), then you might want to limit your anger and losses and just buy a replacement grinder.
-Mark
Posted on May 31, 2011
SOURCE: Hmm, I have Capresso Infinity Burr Grinder #560,
Yes! I had the same issue with putting the burr in upside down and then twisting it an effectively "locking" it in there incorrectly. I tried the "knife" solution that worked for some people here, but it was placing the bean container back on and twisting counter clockwise that did the trick!
So glad I found this thread and didn't give up trying to fix my burr grinder (which we love).
Thanks to jaybayca!
Posted on Aug 20, 2012
Grinder stopped working today. Tried to clean with no result. Anything I can do to trouble shoot? The timer goes, but no grind...
check to see if the grinder is jammed. Most likely, there was something that's gotten caught in it, and jammed the mechanism.
Feb 27, 2016 | Jura Capresso Capresso Infinity Conical...
How do I remove the outer casing of the grinder?
I have a Bodum grinder and the screw was under one of the rubber feet. Not sure if your brand does too.
Feb 15, 2015 | Jura Capresso 560 Electric Burr Grinder
How to reset the grinder burrs?
I took the grinder apart and found to have to replace the two metal grinding tools (inside cone and outside ring.
The parts for it were quite cheap. Just get yourself a proper instruction how to do it and follow it religiously. There are marks left by Jura engineers to calibrate the grinder assembly. Changing the actual grinder bits inside does not alter these if put together in the same position. The calibration is essential for a decent taste. After 7 years I would recommend a full service anyway. This will not be cheap, but all seals get replaced or just the brewing unit and the machine will be physically cleaned inside. Only a clean machine will give a decent taste. And the usual cleaning and de-scaling you can do is not enough to maintain a squeaky clean machine over the period of a few 1000 cups of coffee.
Mar 08, 2013 | Jura Capresso Impressa Z5 Espresso/Coffee...
Hmm, I have Capresso Infinity Burr Grinder #560, and I accidentally placed the upper burr back in upside down. Now it is stuck. I do not see the "black section with a long slot" around the blade.
Thanks to jaybayca!
Jan 08, 2011 | Jura Capresso 560 Electric Burr Grinder
I accidentally placed the upper burr in upside down. Now it is wedged in and I can't get it out. Any suggestions?
I've posted this in a few other places on this site (there are many ways to ask the same question), but try putting the clear bean container back on and untwisting as if to unlock it -- the problem isn't just that we put the upper burr in upside down, but then we locked it into place with the bean container. More info at http://www.fixya.com/support/t4009992-upper_burr_stuck_upside_down or try Capresso at 800.220.5701.
Spring loaded ball bearings - does the ball bearing sit on top of the spring or below the spring??
The ball bearing is a check valve. The ball should be in the input side of the water with the spring underneath.
input side ----->( O/////)-------> output side
Feb 21, 2010 | Jura Capresso Capresso Infinity Conical...
I need a new manual for my Capresso 452 coffeegrinder/maker
Fantastic deal! I'm jealous. I'm on my second one and I paid about $200 each time! Here's the manual
http://www.capresso.com/pdf/inst_coffeeteam_s.pdf
Aug 17, 2008 | Jura Capresso 452.01 Coffee Maker
Jura Capresso 555 Electric Burr Grinder Logo
78 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
