Question about Dell Latitude D600 Notebook
S-Video no picture on TV
I tried to use the S-video connection to have TV as monitor. The screen display did not show on TV. Dell Latitude has S-video so I used a connector and a cord to Panasonic TV with choice of HP-J or Video. I used the video (where DVD player is usually hooked) and set TV to Video-3 whic I usually use for DVD, rebooted PC, but did not get picture on TV
  • FiveCents May 27, 2008
    I actually had to go into my setup, find the various monitor options and activate TV before this would work.
    Thanks for your help!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Champion:
  • 202 Answers
Please right-click on my computer and click on the properties, there click on hardware to see hardware that are not properlly installed or driven. if all hardware are driven than get back for further directives. but it might that the s-video is not driven that is why it is not functioning or responding. good luck
Posted on May 24, 2008
    Genius:
  • 1,027 Answers
Did you "toggle" between internal LCD and external video display with the FN key and the F key for monitor?
My os is vista how can connect to my jvc flat tv as a second monitor?
How you connect to your tv is not so much a matter of OS as it is dependent on what type of video connections are available on your laptop whether RGB, S-Video, mini-display port to DVI, or HDMI.
Once the tv is connected then you will need to right click your desktop and choose whether you want the tv to be a clone display (desktop to show on both your laptop screen and the tv, or use the extended desktop setting to have half the screen be on the laptop and the other half to be on flat screen tv.
Mar 10, 2014 | Dell Latitude E6400 Notebook
I've connected by Dell Latitude D620 VGA to my HDMI LCD TV but there nothing displaying on the TV
Try lowering screen resolution on TV. There is a chance your video card can't handle HD like 1080 dpi or higher. Plus make sure TV input is set to VGA.
Aug 31, 2012 | Dell Latitude D620 (D620-rfb1.6) PC...
How to connect my dell latitude laptop to my symphonic tv via s-video cable
Run the S-Video cable from the laptop to the tv. Take the tv's remote control and hit the Select Input button. Select S-Video or PC as your input source. Reboot the laptop and the video might show automatically.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 23, 2012 | Dell Latitude D610 Laptop Computer -...
Dell Latitude D630 Problem With The Screen has a D630 with nvidia nvs135 and it dont show nothing on the screen, i tried to connect it to a lcd monitor none works. The displays are working, but its just a...
If you don't get a display on the external monitor, then most likely your video circuit is the problem. If your laptop has a plug-in video card it can be replaced. However if it's integrated into the motherboard then you'll have to have that replaced.
Jan 26, 2011 | Dell Latitude D630 Notebook
When i turn on my dell latitude D505 the backlight
Either the video cable has been damaged or unplugged or the video processor is malfunctioning. Check this by connecting an external monitor. If the video is all there then press the Fn(function) and F4 key. This should switch the video from the external monitor to the internal screen. If this doesn't happen or if the external monitor shows no video then the laptop needs to see a reputable repair perso or check my website www.micromendllc.com
Feb 25, 2010 | Dell Latitude D505 Notebook
Connect Dell Latitude D600 to TV
try holding down the fn button and pressing at the same time the button with a small screen on it will do monitor switching
Aug 06, 2009 | Dell Latitude D600 Notebook
Dell Latitude D600 with video projector
Hi there if you have plugged into your external vga port all you have to do is press fn + f8 that should now show the image on both laptop and external ie projector
Regards Al "alstech"
Display Functions
<Fn><F8>
Switches the video image to the next display in the following sequence: the integrated display only, the integrated display and an external CRT monitor simultaneously, an external CRT monitor only, the integrated display and an external DVI monitor simultaneously, and an external DVI monitor only.
<Fn> + up-arrow key
Increases brightness on the integrated display only (not on an external monitor)
<Fn> + down-arrow key
Decreases brightness on the integrated display only (not on an external monitor)
May 29, 2009 | Dell Latitude D600 Notebook
Problem connecting my dell latitude laptop to my tv
Check the monitor settings under "Display Properties/Settins/Advenced/Monitor" (right click on desktop).
Dec 02, 2008 | Dell Latitude D600 Notebook
Cannot connect tv s-video
not quiet sure if the svid takes it picture on the same as the display but you can try this along the f1 row of buttons you should see a button which shold have a picture of two monitors
press the fn key down and then press monitor key
this works if you want to put your display onto a bigger screen
hope this helps
Apr 12, 2008 | Dell Latitude C640 Notebook
Dell Latitude D600 Notebook Logo
1,212 people viewed this question
Alun Cox
