Question about Dell UltraSharp 2001FP 20.1" LCD Monitor
Vertical lines LCD Dell 2001fp
I have 2 inch wide vertical band of red and mulicolored lines on my LCD Dell 2001fp from top to bottom what can be done?
  • Anonymous Jun 09, 2008
    Same problem, colored stripes on the left side of the display - about 5cm (2 inch).
    Color of stripes changes alond the x-axis (horizontal), but not along the y-axis (vertical).
  • icr8stf Mar 22, 2009
    I have a series of vertical bars (primarily a 2 inch Blue one on the left side) at times they "dance" around the screen.
I had the same problem until I decided to go in to figure out what was happening. I am not a technician but I'm a pretty handy engineer...anyway I opened up the panel and separated the big bulky electronics board which is encased in a metal enclosure from the LCD panel itself. After carefully doing so you will find that the electronics which actually control the LCD is covered by a long and thin aluminum plate. This cover can be easily removed by unscrewing 3 or 4 screws. Now here is where the problem arises. I believe that there is one chip (the biggest one you will see) that gets very hot. I measured temperatures in excess of 110 degrees F. It makes sense that temperature is the problem since the lines begin after the panel has been on for some time. My simple solution to this was placing a fan right over this chip. In doing so you wont be able to place back the thin aluminum cover but that's a small price to pay in getting your screen back to normal. The fan should also be small enough for you to put the LCD Panel back together (without this thin aluminum cover). You can hardwire the fan to the Speaker voltage output. I made this fix to my LCD panel about 2 weeks ago and since I haven't seen the lines again. In my opinion Dell knew that this would be a flaw in the LCD because if you notice the power supply for the panel is external which is uncommon in my opinion. The power supply tends to get really hot so in an effort to prolong the life of the panel they made this an external attachment. Well this obviously didn't solve the problem and they went ahead and put it out into the market. If you would like more details send me an email at Mike28ML(at)optonline.net Good luck, with this issue cus I know it way annoying the hell out of me.
Posted on Oct 02, 2009
This fault is a tab fault on the lcd board under the shield attached to the back of the lcd. I worked with a company that repaired lcds in a clean room and it takes a lot of special equipment. the special "tape" that is placed between the tab and glass and pcb has to be kept in a refrigerator until used. The solution though temporary is to keep the heat from rising to the tabs, top of the lcd, as much as possible. the solution with the fan is good. it seems just removing the shield is 85% effective. this was poor manufacturing by the lcd makers. the second tab from the left when facing the monitor is the main culprit though a few others have failed. you can move your finger over it while powered and make the fault occur
Posted on Mar 24, 2010
Superwowfantabulous...
I had the same problem, the left-side banding. It started about 3 days after I got the monitor at an auction.
Read Francisco's solution (above) after I had taken it apart 3-4 times, sprayed it, jiggled it, gave it a slap, etc. I couldn't get the fan to work, not on the audio plug, not even after trying it with about a dozen old black 12vDC adapters.Finally ran some wires in parallel to another fan inside the computer. The fan was only .08 amps, that was the problem, I guess.
Finally got the fan mounted (you need a hacksaw, drill, and screws) and turned it on. I still get a tiny bit of a ghost of a band when the screen is, say, all blue background, but who cares? Probably because of my tiny fan. The monitor is 98-99% okay, and very usable. I have been using it since the patch-up for about 5 weeks with no problems.
Now I am trying to figure out how to re-attach the monitor stand, or to attach another stand to it. I have it resting against some glass bricks now.
Muchos Gracias, Francisco (Mike)
Posted on Feb 04, 2010
  • 40 Answers
Replace the lcd matrix or replace the monitor.
srich
Posted on May 23, 2008
  • 46 Answers
The LCD panel itself is bad, most likely the welds between the glass and the tab board. Probably not cost effective to repair.
Posted on Jun 21, 2008
2 Suggested Answers
viziks
  • 220 Answers
SOURCE: I have 2 inch wide
Seems to be a problem of LCD panel? Cannot be cost effectively repaired. Samir
Posted on Feb 17, 2011
Vertical Lines Dell Ultrasharp 2001fp
Sorry to say that it is a permanent damage of your monitor screen. Usually you can do nothing. But if you want to change the monitor screen, you have to visit a monitor & television specialist.
Cost will be 1/4 of a new monitor.
Sep 22, 2017 | Dell UltraSharp 2001FP 20.1" LCD Monitor
I have a 2001FP Dell LCD monitor with an intermittent 2" wide gray stripe down the middle (you can see through it) that I was told was a back light failure. Is that true? If so, what is the correct...
Bad lamps will either does not light up or have pinkish color. More likely to be T-CON board, check out the connection between the T-CON board and the Logic board. If the lines are vertical lines from the top of the screen to the botom of the screen, then that will be bad T-CON board and not much you can do, new LCD panel will be needed.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 23, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell 2001FP vertical band issue
I'm having the same problem... there's also going to be about 5 years of dust sitting in there, so I hoping it might just be a failure of convective cooling. My first attempt to remove the bezel was unsuccessful, so I wasn't able to go in and look for any swollen capacitors or such. I have blown canned air in the sides, and it's actually doing a little better right now. Probably won't last... having a rather warm summer.
Jan 22, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Suffering from EXACT same problem. Also Dell UltraSharp 2001FP
This is heat, and is a common problem; it affects two of mine. You can verify this by having a can of Dustoff available and catching it when it first starts. Blow in at the top of the monitor through the holes in the back in the same region as the band. The color aberration should go away.
My solution was to make a shroud from black foamcore and use a spare power supply fan to blow air into the case at the top. This has worked for my two monitors for about 18 months. You can also just buy a 12v computer cooling fan for this purpose.Should be somewhere around 75mm in size and quiet, 'cuz you'll be putting up with it if it's not.You can either get a general 12v power supply, or an adapter that fits the 12v power out at the back next to the USB input connector.
Sep 04, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
Jul 26, 2009 | Mitsubishi LT-52244 TV
Connect Digital and Analog cables at the same time.Any use?
does not help. keep dvi connector (white one) on computer and in the back of monitor.
and surely it will not take away those vertical stripes.
those vert stripes... hmm... your monitor might have a problem which you can't fix by your own.
Feb 22, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Verticle blue lines, left side
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new one.
Mar 07, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell 2001FP
Chances are the driver tabs inside from the panel to the internal controller board have failed. This is the actual controller board that the internal video card connects to (hidden under the silver cover on the back of the physical panel).
It is not a cheap repair, and it is normally best to source another panel, or just replace the monitor all together.
Oct 17, 2007 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell UltraSharp 2001FP 20.1" LCD Monitor Logo
4,243 people viewed this question
Alun Cox
